Code Fx Loop
Discussion in 'Marshall Amps' started by David Elliott, Apr 28, 2017.
  1. David Elliott
    David Elliott Member
    Jun 22, 2016
    65
    31
    Is there any reason why you couldn't just wire in an FX loop to the CODE, provided you can find the separation point between preamp and amp?
    Anyone have thoughts on this?
  2. Dogs of Doom
    18,906
    18,352
    the CODE100 (if it ever gets released as anything other than vaporware) is supposed to have a line out & insert, which can be effectively used as a poor man's loop...
  3. Plectrum
    Plectrum Active Member
    May 11, 2016
    258
    176
    UK
    You're assuming that such a physical point exists, which is unlikely. Eeven if it did you'd need something to convert from digital to analogue for the sent then convert back from analogue to digital on the receive side.
    @Dogs of Doom the spec for the CODE 100 on Marshall's web site says the amp will have an FX loop.
    https://marshallamps.com/products/amplifiers/code/code-100h/
    Jethro Rocker likes this.
  4. David Elliott
    Jun 22, 2016
    65
    31
    Interesting, thanks for the info Plectrum.
  5. Dogs of Doom
    18,906
    18,352
    they must have changed it since the initial launch over a year ago...
