Code 25 with Code 50 amp?
Discussion in 'Amplified Parts' started by johncart, Sep 16, 2019.
  1. johncart
    johncart Member
    Aug 20, 2017
    33
    20
    western ma usa
    will the code 50 amplifier section be a direct plug in into the Code 25 control panel? i want to bring the smaller cab of the 25 to a jam but would like the extra power....(the 25s speaker has already been upgraded)
  2. jstich
    jstich Well-Known Member
    Dec 18, 2016
    436
    291
    The 25 watt has a smaller display than the 50 watter. I don't know if that matters in what you're trying to do. You could take both apart and see if the connections are the same.
  3. South Park
    1,477
    1,111
    It depends on the power supply for drivers .the ss drivers might want more amps than power supply can handle. Things might heat up
