Clone Kits For Jtm50
Discussion in 'Building the Classics' started by 6string, Feb 20, 2018.
  1. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    463
    365
    If I’d be looking for a JTM50 which I’ll be soon , the only tranny’s that would go in
    for the 3D warm overtones are the Marstrans !
  2. Mike.Welch
    Mike.Welch New Member
    Sep 25, 2017
    4
    2
    ampmadscientist said:
    it is not legal to use the aluminum chassis as a current path​
    What does it mean to use the chassis as the current path? I only use the chassis to attach my preamp ground on one end of the amp and attach the power amp ground on the other end. I have never hear of the "signal" going through the chassis. Can you give an example?
    Mike
  3. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    972
    503
    Old marshall amps where wired this way... Pin 8 of the power tubes were attached to the chassis as a return path; so in essence, the chassis in these amps were a current path for the amp.
    This is bad design as it makes for a noisy amp.
    You should also attach power supply and audio ground to chassis at only one point in the amp... I usually use the negative (-) end of the main (1st) filter cap and attach this point to chassis ground, only. This is to eliminate any potential ground loops.
    Metroman likes this.
  4. Mike.Welch
    Sep 25, 2017
    4
    2
    Thanks danfrank. That makes sense. I've never done that, but I have seen some builds like that.
  5. S.Marshall
    S.Marshall New Member
    Oct 31, 2016
    12
    16
    Built this JTM 50 awhile back with Marstran iron. Hand made a custom polished SS chassis. Amp sounds amazing. PC152497 - Copy.JPG JTM50-7 - Copy.JPG
    coldengray, Metroman, v846 and 2 others like this.
  6. S.Marshall
    Oct 31, 2016
    12
    16
    Don't let anyone tell you what you can't do. Here's another JTM 50.... kinda. Kits are ok but it's more fun to build what you want. This was a fun one. DSC_0786 - Copy.JPG DSC_0794 - Copy.JPG
    Guitar-Rocker, v846, neikeel and 2 others like this.
  7. TAZIN
    TAZIN Active Member
    Mar 18, 2013
    496
    169
    Nice work Steve.
    BowerR64 likes this.
  8. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,628
    2,549
    I like where the rectifier is mounted
  9. v846
    v846 Member
    Mar 28, 2015
    39
    17
    Rockville , CT
    Steve,
    Wow very nice builds, did you use the 784-139 or the 784-128 output ?
    Love those grey RS cap thingies.
    David
  10. S.Marshall
    Oct 31, 2016
    12
    16
    Thank you sir!
  11. S.Marshall
    Oct 31, 2016
    12
    16
    Thanks! I used the 139. One amp has Marstran the other Merren.
    The RS caps are my clones.
  12. v846
    v846 Member
    Mar 28, 2015
    39
    17
    Rockville , CT
    Nice cap clones :), amps are beautifully done.
    I have a 784-128 in mine using a very early version as example , will post some pics soon..
