Capacitor help!!
Discussion in 'Marshall Amps' started by MichaelOBrien, Mar 28, 2020.
  1. MichaelOBrien
    MichaelOBrien New Member
    Feb 22, 2020
    7
    4
    Hello all,
    I am working an old Marshall Jubilee and it has a blown capacitor. For the life of me I can't seem to find the right capacitor. Its a 4700uF with 80WV and contains 4 pins. Does anyone know where I could find a capacitor like this? Attached is the photo.
    Thanks for your help!
  2. Kelia
    Kelia Well-Known Member
    Feb 26, 2018
    851
    799
    The great tone from the Jubilee doesn't come from the secret diodes but from this special
    secret capacitor !!..:thumb:
    Jokes aside ,...someone will chime some time soon !
  3. MichaelOBrien
    Feb 22, 2020
    7
    4
    Haha im starting to think that actually. :)
    Kelia likes this.
  4. ampmadscientist
    17,847
    11,883
    This capacitor has 4 pins, but it's only a 2 terminal normal high current single filter capacitor.
    The other 2 pins are for mounting.
    80WV refers to the max "working voltage" voltage and ripple current allowed across the capacitor.
    Will he find an exact match that fits the footprint of the board?
    I rather doubt that but a regular filter cap can be substituted easily.
    It's just a regular filter cap.
    Wenander, Sapient and HOT TUBES 70 like this.
  5. MichaelOBrien
    Feb 22, 2020
    7
    4
    Genius! thank you so much!
    HOT TUBES 70 likes this.
  6. Matthews Guitars
    1,799
    2,378
  7. ampmadscientist
    17,847
    11,883
    If you can, get 100 volt instead...(replace both 4700 uF can caps)
    Sapient likes this.
  8. ampmadscientist
    17,847
    11,883
  9. MichaelOBrien
    Feb 22, 2020
    7
    4
    Oh wow! Thank you so much! Thats a huge help. :) :) :)
    Kelia likes this.
  10. ampmadscientist
    17,847
    11,883
    wakjob likes this.
  11. Matthews Guitars
    1,799
    2,378
    That is higher. 100 wv vs 85 wv. There's really no benefit to going to even higher voltage ratings. In fact, capacitors are rated by their capacitance AT their rated working voltage. If you were to pick a cap with a very different voltage rating, it may not function as well as one chosen for the actual circuit voltage.
    Just go to digikey and start searching in the aluminum electrolytics. Start with capacitance then pick your voltage ranges and then start weeding out the candidates.
  12. Matthews Guitars
    1,799
    2,378
    And, when you want to constrain yourself to a four-lug snap-in cap that is going to fit up to that PC board and is at or close to the specs listed, that's pretty much the only one that fits the bill.
  13. Matthews Guitars
    1,799
    2,378
    The life span of the cap would not be directly related to a higher voltage rating. But a cap like that might be available in a long life form. Rated for X hours at 105c, maybe.
    By preference, I'll spend the extra bucks for long life/high temp types. When I rebuilt my Krell power amps, I was able to find some caps that were 10,000 hours @ 125c. Those should be lifetime parts.
    This four lug snap-in canister type is going to have relatively few options. Whenever a company chooses somewhat unique parts it will cause parts supply issues in the future.
  14. mickeydg5
    mickeydg5 Well-Known Member
    24,633
    11,573
    My question is why does a new(er) Jubilee require a capacitor replacement already?
    Please tell which model you have and the date for it.
  15. HOT TUBES 70
    Oct 13, 2008
    11,215
    5,704
    Nichicon seem to be the " Go to " cap brand from what i know .
    Opinions may vary ...
  16. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,374
    914
    Adelaide, South Australia
    He did say it was an 'old' Marshall so, presumably, a 1987 year.
    mickeydg5 likes this.
  17. Matthews Guitars
    1,799
    2,378
    I think there's enough evidence to show that the blue Daly capacitors of the JMP era have a very long working lifespan.
    But when it comes to PC board mounted capacitors, I'd advocate being much more religious about a 15 to 20 year replacement cycle,
    and in many cases, even shorter cycles. I've seen equipment that wasn't 15 years old yet and the caps were leaking and corroding the traces off the board.
    Without a doubt, ANY amp made in the 80s is now quite ripe for capacitor replacement.
    Sapient likes this.
  18. mickeydg5
    24,633
    11,573
    If I recall correctly there is no 4700uF in a 1987 Jubilee.
  19. ampmadscientist
    17,847
    11,883
    I doonoo.
    I never saw a cap like that from China, in a 1980s Jubilee.
    Maybe I wasn't paying attention.
    I was too broke to pay attention.
    Sapient and marco_giampa23 like this.
  20. mickeydg5
    24,633
    11,573
    It is not on the schematic either.
