Can Someone Tell Me Which One Is The V1 Tube In The Dsl 40
Discussion in 'The Workbench' started by OzoneGP, Jun 14, 2018.
  1. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Sorry for the noob question.
    Thanks
  2. ampmadscientist
    14,985
    8,812
    It's the tube closest to the input jack.
    solarburnDSL50, Len and OzoneGP like this.
  3. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Thanks.
  4. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,743
    1,668
    Wilton NSW
    and it it probably inside a metal can.
    OzoneGP likes this.
  5. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Thanks. I just bought a JJ 12ax7. I'm going to try to exchange the V1 tube. I want to smooth out the gain alittle.
  6. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    this one right?
  7. ken361
    ken361 Well-Known Member
    Aug 30, 2009
    3,492
    2,571
    detroit rock city
    yes
    OzoneGP likes this.
  8. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Thanks :thumb:
    ken361 likes this.
  9. Rick Lee
    Rick Lee Active Member
    Jan 24, 2012
    455
    135
    AZ
    Pretty sure it's marked on the board in white.
    OzoneGP likes this.
  10. paulorr8179
    paulorr8179 Active Member
    Oct 1, 2013
    360
    147
    Syracuse, NY USA
    I believe it is in the slot marked V1.
    Kidding !!
    OzoneGP likes this.
  11. ampmadscientist
    14,985
    8,812
    If you don't like the massive gain: you can replace that V1 with 12AT7, 12AU7, etc...and it will lower it down.
    OzoneGP likes this.
  12. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Really? I thought the preamp tube V1 could only a 12ax7 style tube. I might have to do that. Is the 1st and 2nd channel affect by the V1 preamp tube. Because my main objective is to clean up the 2nd channel. the 1st one sounds incredible as it is.
  13. ken361
    Aug 30, 2009
    3,492
    2,571
    detroit rock city
    you will lose fatness though
  14. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    Huh. Something to experiment with I suppose. Thank
  15. ampmadscientist
    14,985
    8,812
    OK looking at this second channel: We do not have a schematic (yet) to DSL40C.
    Or it was removed possibly...
    In order to really analyze how to change the channel to find what you are looking for, you need to find the schematic to work from.
    (or draw one)
    Yeah, you need to get really specific about how the channel gain (sensitivity) is switched in / out.
    By changing parts in that switching circuit, it is possible.
    If you do find the schematics, please post the link and we can continue.
    12AX7 is the highest gain, 12AT7 (and others) are a replacement with lower sensitivity.
    So, you can use any 12__ __ 7....
    12AT7
    12AU7
    12AY7
    "Because my main objective is to clean up the 2nd channel...."
    you can do that with some tweaking, but a bit complicated. Can still be done.
    JJ gain is a little above average typically. There is a very wide range of 12AX7 tubes.
    Sino is way above average gain...(like, double or more)
    JJ is a little above average typically.
    Then if you use a "low noise" "low microphonic" you are also looking at much lower gain, typically....like a hi fi / broadcast tube.
    Hi fi tubes are lower gain because they need lower noise. (makes sense)
    So, you would probably not use a Sino tube in a Hi Fi !
    OzoneGP likes this.
  16. CraigP
    CraigP Well-Known Member
    Jun 26, 2016
    646
    739
    Sent you a PM
  17. ampmadscientist
    14,985
    8,812
    What are you trying for?
    To change lead 1, lead 2, clean crunch, I'm not sure what you mean by "second channel."
    Exactly which one sounds good? and which one needs to change? (the switch settings)
    and what do you want to do to the one that needs changing? (lower the gain?)
  18. CraigP
    Jun 26, 2016
    646
    739
    I am not trying for anything other than sharing a diagram in that PM that I have on my computer :) I like my amp just like it is thank ya LOL
  19. ampmadscientist
    14,985
    8,812
    Thanks for the mail. Sorry I though you were changing something.
  20. OzoneGP
    OzoneGP New Member
    May 10, 2018
    22
    4
    The Classic Gain Clean crunch is the one I mainly use. That to me has the best sound. So when I select the Ultragain
