Can I power my amps with a UPS battery-backup?
Discussion in 'The Tone Zone' started by SonVolt, Dec 29, 2013.
  1. SonVolt
    SonVolt Well-Known Member VIP Member
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    I've got a few of these laying around from work and being free, they're whole hell of a lot cheaper than buying a standalone power conditioner. It claims voltage regulation and line noise suppression for clean power - I'm no electrical engineer but that sounds just like a $500+ Furhman unit. Would this offer me the same benefit?
    [​IMG][​IMG]
    Tripp Lite OmniVS Series 1000VA Tower Line-Interactive 120V UPS with USB port (OMNIVS1000)
    • Automatic Voltage Regulation (AVR)
    • Surge suppression
    • 1000VA/500 watt power handling ability supports PCs, audio/video equipment and home theater systems
  2. HOT TUBES 70
    Oct 13, 2008
    11,083
    5,472
    Interesting ... :scratch:
  3. HOT TUBES 70
    Oct 13, 2008
    11,083
    5,472
    The more i read .... the more i wanna say YES !
    SonVolt likes this.
  4. SonVolt
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    I'm powering a Mesa Mark V (90 watts) and a Triple Rec (150 watts) right this second... seems to be working ok, very quiet too. The more I read the box and compare it to a Furhman unit, i'm starting to think us guitar players are being ripped off... unless I'm missing something.
  5. HOT TUBES 70
    Oct 13, 2008
    11,083
    5,472
    I'd say your in business !!
    Run the hell out of it ...
    I like the price too ..... LOL !
    SonVolt likes this.
  6. Micky
    Apr 29, 2010
    20,250
    16,342
    Vermont
    As long as the current rating is greater than the load (amp) you are fine.
    The price difference comes from filtering and regulation. Furman units have more of that than just a simple UPS.
    hazmat7719 and johnfv like this.
  7. Riffraff
    Riffraff Well-Known Member
    Nov 26, 2008
    1,703
    754
    Dutchess County NY
    ^ This. I'm not sure how much of a filtering/regulation difference there is. You would need to look into the specifications on both to determine if there is a big difference or not. The convenience of a rack mountable configuration, output indication and rack lights would be some of the other added cost. I say if you got them for free by all means use them.
  8. Vinsanitizer
    Vinsanitizer Well-Known Member VIP Member
    Oct 19, 2012
    25,317
    17,505
    How much jam time before shutdown? 15 minutes?
    johnfv likes this.
  9. SonVolt
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    I'm not sure, I've never pulled the plug to find out.
  10. scat7s
    scat7s New Member VIP Member
    Nov 19, 2010
    13,867
    7,287
    keep in mind, 90 /150 w ratings are the amps output capability. not its consumption requirements.
  11. mott555
    mott555 Well-Known Member
    Mar 25, 2013
    3,466
    2,639
    Omaha
    Some UPS's go all square-wave when they're unplugged, I'm not sure what that would do to an amp.
  12. SonVolt
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    How do I determine consumption requirements?
  13. scat7s
    Nov 19, 2010
    13,867
    7,287
    i dont know. typically its printed on the back panel or in the manual. but i briefly scanned thru the triple rec manual and couldnt find it.
    im sure your safe at 500w. but im not sure id run them both off the same supply. that might be cutting it close.
  14. Adwex
    Adwex New Member
    Sep 12, 2006
    9,021
    4,080
    I'm not sure.
    Should probably appear on a label in the back. If I remember correctly, my 100 watt jub says 375 watts input power.
    SonVolt and scat7s like this.
  15. mott555
    Mar 25, 2013
    3,466
    2,639
    Omaha
    Get a Kill-A-Watt.
  16. damienbeale
    damienbeale Well-Known Member
    Mar 1, 2013
    3,798
    1,752
    Oxford ish sorta...
    1000vA is more than sufficient for any 100W or less Marshall. Could be in trouble with a Major, or the JCM2000 amps, or a VBA400 but I've never measured any of those for current draw.
  17. mott555
    Mar 25, 2013
    3,466
    2,639
    Omaha
    I measured my JCM2000 DSL 100 at 140 watts from the wall. That was at idle/low volumes though.
  18. SonVolt
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    Why would a JCM 2000 be different?
  19. Stillhouse
    Stillhouse New Member
    Aug 10, 2013
    18
    17
    Deep In The South Of Texas
    That's what I was thinking. Not a issue with PCs. For amps it may be a horse of a different color.
    *EDIT*
    Did some reading and found some info saying that an UPS with sine wave output should do fine. Looking at the specs of SonVolt's UPS, it looks like it'd be good to go, at least while on AC:
    http://www.tripplite.com/en/products/model.cfm?txtModelID=2656&gclid=CJnI99GD17sCFQbl7AodD1oA7g
    SonVolt likes this.
  20. SonVolt
    Oct 7, 2011
    15,564
    15,894
    South of Nashville
    Great, so it sounds like I won't damage anything. Now, do I have the same protection/regulation as a Furman unit? I'm wondering if there's a racket in the musical biz and we're paying too much for something that could be had for $150 at Office Depot.
