Cabinet buzz
Discussion in 'Cabinets & Speakers' started by style0, Aug 23, 2006.
  1. style0
    style0 New Member
    Aug 23, 2006
    20
    I recently got a 70's checkerboard 4 X 12 that now has 70 watters. I love this cabinet, and it adds so much to my rig. The only problem is I can hear a deffinite sympathetic buzz coming from the handles when I hit certain notes. Any way of damping this besides taking the handles off, wheatherstripping them and re-riviting them?
  2. Artist3203
    Artist3203 New Member
    Aug 23, 2006
    6
    MPLS MN USA
    Duct tape? Just a thought.
  3. KM1959
    KM1959 New Member
    Aug 23, 2006
    10
    2
    SoCal
    If your sure that it is the handles (and perhaps not the back panel that isn't tight against the post), couldn't you use carefully-applied silicone to the handles? Perhaps from the inside?
  4. Outlaw1969
    Outlaw1969 Member
    Aug 23, 2006
    85
    14
    Jacksonville , Florida
    I thought about the silicone idea too, or maybe some of that "foam in a spray can" stuff for around handles, inside the cab. (You know that stuff that comes out like a spray, from the straw-like attachment on the can, and expands into a plyable foam when the air hits it.)
    Just a few quick ideas........
  5. JMP Master
    JMP Master New Member
    Aug 24, 2006
    8
    3rd stone from the sun
    I had a similar experience with my 71' 120W red cabinet. I have tightened the screws on the back panel and the buzz was gone.
    JMP Master
  6. style0
    style0 New Member
    Aug 23, 2006
    20
    Thanks, I will try the screws on the back first. I wonder if I can smash the rivits on the handle to tighten them up? I would imagine the possibility of breaking the plastic handles is pretty high on that operation.
  7. style0
    style0 New Member
    Aug 23, 2006
    20
    Well, a bead of glue from the hot glue gun did the trick.
  8. Guv'nor
    Guv'nor New Member
    Aug 4, 2006
    243
    50
    Most of the times the best solution is the easiest.
