C19- where's it gone???
Discussion in 'The Workbench' started by merdenoms74, Apr 2, 2020.
  1. merdenoms74
    merdenoms74 New Member
    Mar 16, 2020
    5
    5
    So, I have a fairly new DSL40cr that I was determined to do the C19 mod on, only to find there are no capacitors (C20 is missing too) behind the Ultra Gain's gain pot. If they've moved it in the newer versions they must have renamed it as well because I couldn't find a 'C19' anywhere.
    Have they done away C19 and C20 altogether?
  2. Micky
    Apr 29, 2010
    20,754
    17,182
    Vermont
    C19 mod is only for the DSL40c, not the CR
  3. merdenoms74
    Mar 16, 2020
    5
    5
    Ahh... that would explain it. I just assumed they were the same except for the addition of the Master Volumes.
    FracStrat likes this.
  4. FracStrat
    FracStrat Well-Known Member
    Jan 22, 2020
    385
    997
    Water Side of WA State
    The location is C74 but it’s been omitted by Marshall already …… The changed a few other things as well … Pot Values and who knows …… The CR is fantastic stock …… Unless you have the ‘Burnin Yurnin’ to turn it into a Head like me!!!
  5. merdenoms74
    Mar 16, 2020
    5
    5
    It IS fantastic stock, but it's so f$%king bright!
    MarshallDog likes this.
  6. ampmadscientist
    17,861
    11,898
    After you spill a few beers in there it will mello out.
  7. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    1,010
    711
    Turn down the treble and mids.
  8. merdenoms74
    Mar 16, 2020
    5
    5
    Thank you for stating the obvious :applause:. The trouble is that the treble needs to be around 1 or 2 and it takes a wide range lot of upper frequencies with it. The Classic Gain on green seems fine, it's only when you introduce more gain that it becomes a bit ear-splitting. At the moment I have a vocal shield that I'm using as a beam-blocker. It actually works quite well. I'll play around with a parametric EQ but I was thinking the removal of a bright cap would give me what I'm looking for.
