Building A Dual 2204/1987 Preamp
Discussion in 'Building the Classics' started by Crunchifyable, Nov 28, 2017.
  1. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    939
    558
    Södertälje, Sweden
    Cool.
    9 volt is fine for 12ax7 heaters (in series). Just look at all the DSL's and 900 series amps out there..cathode stripping is not a problem for low power, indirectly heated cathodes.
    J
    Crunchifyable likes this.
  2. Crunchifyable
    Crunchifyable Active Member
    Oct 28, 2011
    409
    180
    Georgialina, USA
    I guess I don't understand how or why Marshall used 9v instead of the usual 6.3v.
    I decided to go with the dual preamp layout for now. A little more creativity required, but more preferable to a half empty turret board.
    Some caps are too big. Some resistors too small. I realize I'm missing a cathode resistor.
  3. johan.b
    Feb 21, 2015
    939
    558
    Södertälje, Sweden
    They rectify 6.3 vac into ~9vdc to reduce hum. In the first preamp tubes.i guess it was necessary with the pcb layout.
    Off board twisted wires would have worked to, but more labour building ta amps
    J
  4. Crunchifyable
    Oct 28, 2011
    409
    180
    Georgialina, USA
    I see. Makes more sense now that it's explained as an ac vs dc thing. Well it's good info in the event i need to use a 9v input.
    I'm hoping the desktop power supply works out instead.
  5. Crunchifyable
    Oct 28, 2011
    409
    180
    Georgialina, USA
    It lives!
    I may have a loose wire or something in my tonestack and a lot of noise from breadboarding it out and not having enough shielded cable...but for a broken amp, it sounded good to me.
    I'm using my Class 5 as a power amp (2k2 input resistance)
    As a side comment...using a PC powersupply is very handy. It has many 12v wires...and many ground wires too.
  6. Crunchifyable
    Oct 28, 2011
    409
    180
    Georgialina, USA
    Realized what my problem was, sort of. Layout I was using didn't include a .022uf on output like most 2204 layouts have. added that and it sounds as expected.
    But bass control does nothing. Wiring seems ok.
  7. Crunchifyable
    Oct 28, 2011
    409
    180
    Georgialina, USA
    Ran it into a 100w amp (my bugera 333xl - EL-34 x 4) for the first time.
    No impedance matching used...so might have lost some high freq. The Bugera has a handy FX return level knob that I conveniently lowered all the way. But I still love how it sounds.
    I sense it has too much gain but I like the way it sounds.
    RickyLee likes this.
