Bugera 1960 Motorboating Problem
Discussion in 'Other Amps' started by andomando, Apr 21, 2019.
  1. andomando
    andomando New Member
    Jan 31, 2016
    My bugera 1960 infinium amp is motorboating,when i switch it on it does it till it warms up then its fine,,,but it has started doing it about an hour into a gig,so i had to change amps,
    Does anyone have any idea what may be causing it to have this problem
    any help would be appreciated.
  2. ampmadscientist
    11,702
    5,726
    Left Coast
    Ask Shane Sipe your resident Expert Bugera Dude:
    http://www.marshallforum.com/members/shane-sipe.46869/
  3. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,741
    4,623
    Because its a Boogera.
  4. ampmadscientist
    11,702
    5,726
    Left Coast
    That does appear painful...
  5. Buzzard
    Buzzard Well-Known Member
    Sep 14, 2016
    656
    616
    Best solution. Drop it off the back of a motorboat.
    charveldan likes this.
  6. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    475
    320
    Tough crowd...
    In a new build, motorboating can be due to lead dress causing parasitic oscillation.
    But in an amp that was previously working correctly, it's usually due to an electrolytic cap that's drying out and going bad.
    I'm guessing that if "electrolytic cap" didn't pop into your mind the first time you heard it motorboating, you may not want to work on the amp's guts yourself. And you were wondering if there's some easy fix or if it's time to put it in the shop.
    Time for a tech to look at it. Simple, common repair, not super expensive.
    Some electrolytics last amazingly long, but replacing them is considered "normal tube amp maintenance".
    mAx___ likes this.
  7. charveldan
    Jan 31, 2010
    7,741
    4,623
    They're like $150 used. Just buy another.
  8. andomando
    Jan 31, 2016
    Thank you for your help, I have heard of older amps with this condition and needing electrolytic caps renewed but did not think an amp as old as mine would need new caps,I will check the caps out, thank you again..and as for the jokers,,just shows their knowledge,or lack of it.
  9. Garrett
    Garrett Well-Known Member
    Mar 5, 2015
    543
    309
    Well, Bugera got the reputation due to a poor connector choice for the power section, thus the fire jokes.
    I have a 333XL and the amp sounds great. Hope you get it sorted out and please update the thread when fixed.
  10. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    726
    706
    How does that guy manage TWO poles???
    Or did the first small one jam his rudder and unexpectedly put him into #2?
  11. anitoli
    anitoli Well-Known Member
    5,765
    5,922
    That is natural selection in it's finest hour. Target fixation. This is what killls newbies on motorcycles.
  12. ampmadscientist
    11,702
    5,726
    Left Coast
    It won't be too unusual for a voltage regulator to fail from overheating, as Bugera tends to have poor thermal management for the solid state components. (particularly the voltage regulators).
    Cap failure is a distinct possibility.
    Did you try messaging Shane?
    Send him a private message.
    I found that if I installed heat sinks on the voltage regulators, etc...the amp would keep working pretty good and sounds good.
    "...They're like $150 used. Just buy another...."
    :lol::lol::lol: Well, there's that.
    We tried getting any help or service / parts from "Music Group," there is no customer service or parts support that we could find, even from the service centers.
    Too bad because the amps do have potential.
    After I fixed it, it sounded pretty damn good. But I fixed it with no help from Bugera.
    JohnnyN likes this.
  13. ampmadscientist
    11,702
    5,726
    Left Coast
  14. JohnnyN
    JohnnyN Member
    May 30, 2012
    95
    80
    Denmark
    I did that on a V55 head (pre Infinium) and it worked fine for the rest of the time I had it :)
