Breakup Decay Observation
Discussion in 'Marshall Amps' started by coyote, Sep 16, 2018.
  1. coyote
    coyote Active Member
    Sep 20, 2015
    79
    105
    Much as I’m liking my DSL40c, something has been bothering me. It’s not unique to this amp, or to this brand.
    It’s that compared to yesteryear, the drive generated in many of these modern amps seems, uhhh.... synthetic. And the signature is in the note decay. If you sustain a note/chord til it fades out, in the old amps that drive would gradually fade into clean and then fade to zero.
    Now? With the newer amps, the note/chord sorta “falls apart” into crackly fizz instead as it fades.
    That explanation is not perfect, but it kinda gets the idea across.
  2. Mitchell Pearrow
    8,032
    11,724
    Ahhh interesting observation I am going to have to give it a better listen, I am trying to get that harmonic feed back at the end of some of the songs, with out the squeal, between volume and gain, there is a sweet spot,:band:
    Trelwheen likes this.
  3. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,033
    359
    Netherlands
    I have that same observation... I really enjoy an amp that fades slowly to a clean note. its in the design.
    mickeydg5 and Mitchell Pearrow like this.
  4. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    969
    500
    Probably because the newer amps have diode clipping?
  5. Micky
    Apr 29, 2010
    20,343
    16,482
    Vermont
    It is a function of the power section, PI & finals...
  6. Jr Deluxe
    Jr Deluxe Well-Known Member
    Sep 12, 2017
    274
    265
    Almost nobody let's a note fade into silence because you hear your system noise rise at the end.
  7. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,306
    1,721
    Texas
    Do the new DSL series use diode clipping? I would guess not, since there are plenty of 12ax7s in there for several gain stages. However, I've noticed that the overall distorted tones are fizzy/buzzy compared to other high gain amps.
  8. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    1,090
    1,243
    Chicago Suburbs - USA
    I think I know what you’re talking about. When I let a note or chord ring out I hear a fuzz start to come in before it fades. Only on Crunch though. Clean and Ultra Gain don’t do this. I think I might have a recording of this. I’ll look for it later when I get home.
  9. tmingle
    tmingle Active Member
    Jan 24, 2008
    283
    216
    Mifflintown, Pa.
    I started to notice the same thing a couple years ago. I now change strings with much greater frequency. It may be a Placebo effect, but works for me.
  10. mickeydg5
    22,451
    9,819
    What is in the signal chain?
  11. coyote
    Sep 20, 2015
    79
    105
    Nothing. It happens regardless of whether I have effects running or not. It happens in music stores when I’m checking out instruments. When I was choosing this amp three years ago, I was comparing it to a Blackstar 40w combo... and the blackstar had the issue even worse.
    But I will re-validate this by unplugging everything, and running the guitar straight into the amp again.
  12. headcrash
    headcrash Active Member
    Jun 19, 2015
    65
    101
    Being both a longtime modern amp user (Dual Reverb, DSL50, JCM800 SPlit Channel, Jubilee, ENGL Savage & Blackmore, Diezel VH4) AND a hobby DYI ampbuilder having built around 11 or 12 amps up to now I have to agree with the thread opener and I have discovered the same on some - not all - modern amps. As far as my obervations are concerned it has nothing to do with the signal chain - we're talkin guitar-cable-amp.
    I consider the ability to fade out gradually as an important sign of quality of the tone or sound of an amplifier, especially when doing clean or crunch sounds on medium or higain using the guitar volume.
    So far I have neither found the cause for that "crumbling" of decay, nor have I attempted to search for it seriously. I was lucky enough that most of my DYI amps decay rather smoothly.
    That being said; for the moment my Jubilee clone is my go-to amplifier and I really love it, although it doesn't decay smoothly. So in a band situation it does not seem as important to me :D
  13. tschrama
    May 15, 2010
    1,033
    359
    Netherlands
    It us a preamp thing.. once you get it, you also end up with an amp that cleans up spectaculairly with the guitar volume pot.. very cool.
  14. Mitchell Pearrow
    8,032
    11,724
    I am not sure if it would be confused with decay, but the harmonic feed back that KK Downning gets in the live unleashed in the east, Judas Priest album is where I like to set. And the end of Glen Tiptons solo on beyond the realms of death, where he sustained his note to the point of feedback, I know I am a bit off topic:cool:
  15. KraftyBob
    Sep 5, 2017
    1,090
    1,243
    This is the recording I was talking about. This was my first DSL and when I sent this to Sweetwater they swapped out the amp for another one. It's still present in the new amp but not nearly as noticeable. You can hear the fuzz come in right after I strike a note.
    This was guitar straight into amp and nothing in the loop. It was definitely coming from the speaker - nothing in the cab was vibrating. Also, as I mentioned above I only heard/hear this on the Crunch channel - clean and Ultra Gain are fine. Additionally, when I plug the same guitar and cable into my Vox AD120VT and try all different settings I cannot replicate it. So I know it's not the guitar or cable.
  16. Micky
    Apr 29, 2010
    20,343
    16,482
    Vermont
    Try different bias settings
  17. KraftyBob
    Sep 5, 2017
    1,090
    1,243
    When I got my replacement amp it was biased at around 41-42. I lowered it to 38. A few weeks ago I replaced my power tubes and biased at 34. I still hear some buzzing as the notes decay. At least for my amp it doesn’t seem to be bias related.
  18. Nik Henville
    Jul 18, 2018
    957
    1,457
    And modellers, profilers, simulators and even effects all seek to emulate a technology that depends on glass bottles filled with wires in hot gas - without any clipping diodes or LEDs in feed-back loops or hard-wired to ground.
    Coincidence... I do NOT think so.
  19. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    8,680
    4,389
    Lakeland, TN
    New unbroken in speakers could lend to that artificial decay, just my thoughts.
    mickeydg5 likes this.
  20. jamesm
    jamesm Active Member
    Jun 4, 2009
    114
    35
    3rd rock from the Sun
    I have spent my life wondering why other people don't hear the fade out crackle (you have restored my faith in guitar playing humanity). I have found it to be caused by different mechanisms. It can be crossover distortion in the output stage, but is often due to circuit tuning or PCB design.
    It is very common on amps and pedals. I reckon you can tell this when you watch some Youtube demos when the player never lets the note fade naturally. I think they don't actually know they are doing it. The only problem is that once you have noticed, you can never un-notice, and there is a whole bunch of equipment out there that will never make you happy.
    From what I know of the DSL40, the problem is likely to be in the circuit tuning of the preamp. I suspect that the ultra gain does it too, but it is masked by the level of 'proper' overdrive.
