Bought a DSL 15h Today, First Impression VERY COOL
Discussion in 'Marshall Amps' started by Chris Sheppard, Nov 23, 2019.
Tags:
  1. Chris Sheppard
    Chris Sheppard New Member
    Oct 16, 2019
    19
    23
    I bought a really clean DSL 15h today for $250.00. I am really pleased, I got what I was looking for in many ways. The Classic gain channel has an incredible amount of head room. With the volume on 10 and the gain on about 4 you could barely get it to breakup which pleases me greatly. The Ultra gain channel is very useful with the gain turned on low (1 to 2, 3) also. So surprising how useful this little Amp truly is.
    Suggestions on a proper inexpensive cab would be greatly appreciated. Cheers!
  2. Mitchell Pearrow
    10,260
    17,155
    I really can’t recommend a cab for you, because I am not familiar with your amp, but on the cheap side, if you’re amp doesn’t dwarf those small 1-12 mg cabs, grab one and install a better speaker
    Chris Sheppard likes this.
  3. Kinkless Tetrode
    Aug 17, 2017
    1,247
    1,618
    I found that the DSL15 likes Vintage 30s. Maybe it is because I like Vintage 30s, but the Vintage 30 helps tighten up the low end of the DSL15 which reminded me too much of a Fender, and it added some mid range complexity to the red channel.
    There are some affordable cabs loaded with Vintage 30s, such as the Harley Bentons. Also a used cab loaded with a V30 might be within budget.
  4. scozz
    scozz Well-Known Member
    Jul 20, 2008
    3,236
    7,341
    Congrats on the new amp @Chris Sheppard, Great price too, glad to hear you're liking it. Like @Kinkless Tetrode said, Thomann has some real inexpensive cabs, like a Palmer 1-12 cab that's unloaded for $96.
  5. scozz
    Jul 20, 2008
    3,236
    7,341
    Hey @Mitchell Pearrow,....I didn't know there were MG 1-12 cabs, I've only seen the 4-122. Unless you're talking about the MX112 cabs?
  6. Mitchell Pearrow
    10,260
    17,155
    The ones I am referring to are the ones that come in those small stacks , like the lead 12 stacks.
    My bad scozz there not 12” speakers they are either 10” or 8”..
    scozz and Chris Sheppard like this.
  7. Mitchell Pearrow
    10,260
    17,155
    It has been a long time since I had looked at it the little cab is the same size as the mg 15.
  8. Mitchell Pearrow
    10,260
    17,155
  9. Mitchell Pearrow
    10,260
    17,155
    This a pic of the little cab
  10. Chris Sheppard
    Oct 16, 2019
    19
    23
    There is a Vox 2x12 cab for $250 with 2) g12h30’s aren’t those akin to a greenback?
    It has an open back which I was a bit uncertain about. Thoughts anyone?
  11. tmingle
    tmingle Well-Known Member
    Jan 24, 2008
    316
    261
    Mifflintown, Pa.
    "The Ultra gain channel is very useful with the gain turned on low (1 to 2, 3)"
    I believe there is a simple MOD that involves installing 1 resistor(the board even has a place for it) to tame the gain some. I almost bought a 15C combo(sounds great at low volume) the other day, but wound up with a Line 6 HX Stomp instead. It works pretty well with my 40C. I think I'm going to sell off my pedals to fund a full blown HELIX.
  12. scozz
    Jul 20, 2008
    3,236
    7,341
    Oh yeah I remember them, you’re right they came with the little Lead 12 mini heads, as a mini stack! I think they were 10s but I’m not certain, definitely not 12s.
  13. Mitchell Pearrow
    10,260
    17,155
    True it had been quite while since I had looked at it and I had a 12” speaker sitting on the shelf and grabbed it and it is wider than the little cab DOH
    scozz likes this.
  14. JeffMcLeod
    JeffMcLeod Well-Known Member
    Sep 28, 2017
    1,482
    2,080
  15. Mitchell Pearrow
    10,260
    17,155
  16. DragonSarc
    DragonSarc Active Member
    Jun 17, 2008
    739
    49
    San Leandro, CA
    check out blackstar htv112, it comes with celestion 70/80 you can find it cheap 2nd hand around 50-70 bucks good and big sounding cab.
  17. Robus
    Robus Active Member
    Jan 12, 2013
    235
    242
    Chicagoland
    Grab a Harleu Benson 2x12 with V30s.
  18. Kinkless Tetrode
    Aug 17, 2017
    1,247
    1,618
    Yes, the G12H30 is akin to the G12M25. In the 60's and early 70's they both had green magnet covers, so they are both GBs. However, today on the internet is common to refer to the G12M25 mainly as The Greenback speaker. The G12H30 has a heavier magnet which gives it a deeper and punchier bass than the G12M. The heavier magnet also gives more treble. G12H's have a lot of bite. The 70th anniversary versions of the G12H30 in particular are very bright. Both GBs have some grit in their tone. This really works well with amps run with just a bit of break up.
    The Vintage 30 has a focus on the upper mids. And the mids are shiney and clear. This is why many perceive them as brighter than GBs, and they can be annoying until they break in thoroughly, but the G12H has more treble. Nonetheless, the Vintage 30 has some advantages over G12Ms and G12Hs, once broke in, especially when used with high gain amps. The lows are never flubby which can often be a problem with G12Ms. The high highs are rolled off compared to G12Hs.
  19. EADGBE
    EADGBE Well-Known Member
    Dec 13, 2009
    524
    410
    What about a 4x12 with greenbacks? Maybe you could take the amp to a music store and try it out with various cabs and see which one you like best. Just make sure you match the amp and the cab's impedances.
    Another tip: Before switching the pentode/triode switch make sure the amp is off. That's straight from the owner's manual.
  20. Chris Sheppard
    Oct 16, 2019
    19
    23
    I picked up an AVT 1x12 can today, it has a g12m25 greenback speaker in it, very happy. I’ve been playing the Les for several hours. Clean mainly (you really can’t get the classic gain channel breakup much) and also with overdrive. I picked up this (Chinese?) pedal a while back. It’s yellow by Tone City, Model M. Sounds really pretty along with the Carbon Copy Analog Delay (the perfect amount of knobs )
    thanks for all the advice and feedback. CBS
