Boss GT8 discussion ?
Discussion in 'The Tone Zone' started by guzzis3, Oct 22, 2019.
  1. guzzis3
    guzzis3 Member
    Aug 24, 2019
    80
    81
    Brisbane Australia
    So I've dug out my GT8 after it collecting dust for years and it seems the old Boss GT forums are dead.
    Is there some obscure corner of the interweb where people are still discussing them ?
    I tapped through some of the stock patches the other day. I can really understand why people hate the GT8. The stock patches are just awful, and I suppose it requires a lot of reading and experimenting to properly understand the beast. There are good sounds in there if you are prepared to dig, but dig you must...
    SkyMonkey likes this.
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,281
    2,165
    Wa State
    I guess I’m glad I don’t own one ………
  3. SkyMonkey
    853
    868
    Sheffield, UK
    I think that is the opinion of all the preset patches, of all BOSS GTs, ever.
    I have had the 8, 10 and the 100. There is a swathe that all sound the same and the rest are ridiculous and aimed at no-one. I think some of the more ridiculous ones are there to showcase one of the more useless effects modules (e.g. slow gear) that 1 in a million buyers bought the GT for.
    Go 4CM, turn off the pre-amp sims, and just use it as an OD with time based effects in the loop. Good for MIDI though if your amp has it.
  4. SkyMonkey
    853
    868
    Sheffield, UK
    There is a fan generated manual called GT-8 Brilliance that may get you further than the BOSS one.
    Jon C likes this.
  5. Sir Don
    Sir Don Well-Known Member
    Aug 9, 2009
    1,259
    624
    Adelaide, South Australia
    It's been part of my live rig for over 10 years now. I don't use any preamps just the effects, 4 cable method and midi switching with my JVM. Never had a problem.
    HOT TUBES 70 likes this.
  6. Filipe Soares
    Mar 8, 2019
    488
    688
    I've used the GT8 for many many years... never used a single pre amp or drive, 4 cable method, boost in front of my amp and happiness.
  7. guzzis3
    guzzis3 Member
    Aug 24, 2019
    80
    81
    Brisbane Australia
    I have GT8 brilliance but thank you. I just remember the old forum and it was really interesting reading.
    I like the 1959 model just for fairly clean practice into the 8008 but as you say you really need a proper amp to use with it. I remember when I bought it there was another board that was supposedly better for amps, possibly had a 12ax7 in it but I can't remember the brand, but the GT8 was considered the best for effects. I've never really been into effects so I figured it'd do me for life, and it probably will.
    Mostly I use the jc120 full range because that is the cleanest model and I don't know how to turn models off altogether. I've thought about writing out the full menu trees on paper to help navigate the thing...so easy to get lost.
    Thank you for the replies.
  8. SkyMonkey
    853
    868
    Sheffield, UK
    It should be straightforward to turn a pre-amp off.
    From p18 of the manual:
    From page 26:
  9. guzzis3
    guzzis3 Member
    Aug 24, 2019
    80
    81
    Brisbane Australia
    Well ok. I realise that's how you switch off effects. I thought I'd tried that on the amp models and it didn't work but I'll go through it again carefully.
    EDIT: I tried it again and it seems to have worked! I got to say though there still seems to be a bit of colour in the sound so it says it's off but there might be something I've missed. Or it could be the speaker cabinet. On really clean settings like this I switch back and forth between linear and valvestate on the 8008 and for the life of me I can't hear any difference, but maybe there isn't enough volume. Dunno.
    I found a youtube video where he shows how to change your input level and I tried that and couldn't seem to get it either. Maybe I'm just dumb. Maybe I'll have a day with a clearer mind soon and I'll sit down and try to be more methodical. I have been thinking of writing myself a manual that takes a more linear approach to the thing, and probably making it available online in case it helps others. Most of the resources on the GT8 are about tweeking and even those which are more linear only give you bits and pieces. It'd be great to have a series of steps to make a sterile patch and then build it up step by step, understanding each addition fully before moving on to the next. The result would need tweeking afterwards but at least you'd have a better idea of how to diagnose and fix issues.
    Anyway thank you for the comments.
  10. Lance Chambers
    Jun 23, 2019
    627
    835
    The Land That Time Forgot
    I have one buried in my closet somewhere.:hmm:
  11. Goldfinger
    Goldfinger Active Member
    Oct 10, 2019
    86
    129
    A friend used one with his plexi... Great tones!
  12. SkyMonkey
    853
    868
    Sheffield, UK
    You probably need to do some extensive tweaking in the Global settings (EQ, output vol, etc.) and A/B the un-effected GT-8 tones with the amp set to dry.
    I am far less fussy with my GT-100. I have just found settings I like that improve my DSL EQ, then add switchable OD/Reverb/Chorus/Delay. NS out front and first in the loop is invaluable too.
    As for the manual. I keep mine tucked away in the W.C.!!!!
    Any time I have in there to "Sit & Think", I scour the different sections. You'll be surprised what you miss sometimes.
    HOT TUBES 70 and guzzis3 like this.
  13. HOT TUBES 70
    Oct 13, 2008
    11,111
    5,524
    I'm not kidding when i say " Get rid of it " and get a different one .
    I've at one point owned several of these GT units , and the the best Boss GT tones are from the GT3 or the GT5
    They use the most true analog circuits of all the GT series floor units .
    As mentioned above , turn off all the Amp sims , and pre amp crap , use only the effects , Tweaking is a MUST !!
    Running the 4 cable method gives you the best possible effect tones .
    IMO of course ...
  14. HOT TUBES 70
    Oct 13, 2008
    11,111
    5,524
    I may have been a little hasty with my above comment .... ^^
    It's just my experience after rowing though several GT units that i stumbled upon a GT3 , and was immediately shocked at how much cleaner or real sounding than the GT6 and GT8 that i had run for several years .
    After doing some reading on a Boss GT web site i learned they got rid of a lot of digital / COSM stuff and went back to the old school analog circuits . If you do a read online , many players agree that the GT3, and GT5 can still hang with many modern units . Not to say that the newer units don't have some key features of their own , but at the heart or core of the Drives and Effects they sound pretty good . ( GT3 /GT5 )
    Just to put things in perspective even my biased opinion might be .... Nuno Bettencourt still runs a Boss GT8 in his live rig thats been around the world countless times . lol And he's got killer tone live !!
  15. Dmann
    Dmann Well-Known Member
    Dec 28, 2008
    1,848
    1,673
    Calgary, Canada
    My drummer gave me a GT8 but missing the power supply. It's old and clunky and weighs a ton lol. Definitely a tank. I've mulled over ordering a new power supply for about 6 months now ...
  16. SkyMonkey
    853
    868
    Sheffield, UK
    Useless and hard to sell without one. Go for it.
    I think you can get a generic one for under CDN$30 on Amazon CA.
  17. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,618
    1,562
    Wilton NSW
    The other (better) guitarist in our band had one, to feed into his clean Solid State Fender FM212. We called it 'The Spaceship' on account of it's complication. Good sounds available though
  18. guzzis3
    guzzis3 Member
    Aug 24, 2019
    80
    81
    Brisbane Australia
    Hi,
    Thank you for the thoughts. I accept buying mine (new) was possibly a mistake but I've never been much of an effects person. I had no illusions this was any sort of ultimate solution I just figured it'd so me, and it does. It's work, more than I'd like, but there are satisfying results in their if you dig.
    By the time I sold mine and bought something else it just wouldn't be worth the trouble.
    What does have me baffled though is how my "practice" setup sounds now. 2003 american std strat (left) into GT8 into marshall 8008 (ss power amp) into 412 celestion super 65s. Stereo series 16 ohm. It's not a sound anyone would strive for but it's actually ok. There is a bit of chimey distortion, not much, but I can't for the life of me figure out where it's coming from. I've turned off everything I could find on the GT8, checked universal settings, yet still it's there... Should be quite sterile...
    Anyway it's all good. I know no one cares but I'll be off air for some time from wednesday.
