Boost
Discussion in 'Marshall Amps' started by Thrane, Nov 28, 2019.
  1. Thrane
    Thrane Active Member
    Nov 7, 2016
    126
    89
    Hi,
    LP->1959HW->Fryette PS2->1960AX.
    It's pretty cool for early rythm rock tones. But i want to play some Guns n Roses solo stuff also.
    Amp settings is:
    Presence: Noon
    EQ: All noon.
    Volume 1: app. 6. (Plugged into upper left input)
    What tricks will make this amp get more gain and sustain? Like Sweet Child o mine.
  2. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,184
    4,753
    If your referring to pedals, almost any Tubescreamer will work, as a clean boost or a more overdriven tones. I also really like the TC Spark Boost, the 4 knob one. That pedal is great imo, and also the EHX SoulFood.
    I just got the SoulFood a couple of days ago and man what a phenomenal overdrive pedal, great overdriven tones that don't color the tone of your amp, a very transparent pedal. I highly recommend the SoulFood Overdrive.
  3. Thrane
    Nov 7, 2016
    126
    89
    Hi,
    Thanks.
    I know that a good drive pedal will work, But will it also make a good sole tone without a extra booster like MXR MC401 ect.?
    tce63 likes this.
  4. scozz
    Jul 20, 2008
    2,184
    4,753
    Well I don't know much about the MXR 401, but isn't that strictly a boost pedal? I mean it'll boost your amp but it doesn't really add any overdrive tones to thicken up your sound does it? The pedals I mentioned will thicken your tone, isn't that what you're really looking for, or maybe I'm not understand you?
    wntbtw and tce63 like this.
  5. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,002
    5,027
    Montreal
    Sorry I deleted the link 'cause after watching the whole thing there were no boost O/D or boosts used.
    Post it here again if you're interested.
    Sound Like Guns 'N' Roses - By Busting The Bank
    Mitchell Pearrow and Phony iommi like this.
  6. Phony iommi
    Phony iommi Well-Known Member
    Mar 16, 2019
    227
    378
    Good points from scozz here. You are also using an attenuator so I presume you have tried dialing that in for more gain? While you dial back the volume on the lp a bit?
  7. pedecamp
    13,621
    9,916
    Throw an EQ pedal out front to boost your signal I like a GE7 for that, or get an OD pedal like an SD-1. If you want distortion use a Rat pedal. One of the best overall pedals if you dont own any pedals is a Fulltone OCD. :yesway:
  8. ricksdisconnected
    Aug 11, 2019
    989
    1,539
  9. tschrama
    tschrama Well-Known Member
    May 15, 2010
    1,060
    379
    Netherlands
    GE-7. soo flexible, especially good for GnR tone by boosting the 1kHz and up
  10. Thrane
    Nov 7, 2016
    126
    89
    Thanks for the replies.
    I don't want to change the tone of the amp.
    I have read a lot positive feedback about germanium treble boosters.
    Maybe it should try one out - also a OCD, GE7 or SD-1.
  11. scozz
    Jul 20, 2008
    2,184
    4,753
    Well, I can tell you from experience the Boss SD1 WILL color your tone, it is NOT a transparent pedal.
    Mitchell Pearrow and wntbtw like this.
  12. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    347
    754
    Brother you would have add a 4th preamp tube and 2 more gain stages.
  13. MonstersOfTheMidway
    May 1, 2008
    4,894
    2,405
    :agreed:
  14. Phony iommi
    Mar 16, 2019
    227
    378
    Mxr 133 gain booster. Worth a look, boosts your existing gain without coloring the tone. Around $80 I think. Mxr makes great stuff.
  15. marshallmellowed
    Jun 26, 2009
    3,281
    3,474
    I had one for about a week, didn't do anything for me. Opinions on pedals, just like opinions on amps, are all subjective. I have the same advice for selecting pedals, as I do with amps, you have to try them for yourself. So many friggin pedals out there, it's overwhelming. I bet the pedal manufacturers look at guitarists the same way a drug pusher looks at a crack addict.
  16. ricksdisconnected
    Aug 11, 2019
    989
    1,539
    you got that shit right. funny thing for me is there arent but a few that are even usable to me.
    to many clones of other pedals out there. 4 dirt boxes and i bet one can have most bases covered
    for that tone. a lot of rinse and repeat thats for sure.
    wntbtw, Mitchell Pearrow and scozz like this.
