Bias Problem Changing Valves On Tsl100
Discussion in 'Marshall Amps' started by Fabrizio, Jan 11, 2019.
  1. Fabrizio
    Fabrizio New Member
    Jan 11, 2019
    5
    Hallo everyone,
    For the first time i changed valves on my jcm2000 tsl100, and installed new JJ EL34. Testing the bias with a multimeter, from one side ( left pin and center pin) i read 90 mV which is ok, but on the other side (right pin and center pin) i read 300 mV. If i try to adjust it the minimum i can reach is 115mV which is too much as far as I've read.
    What is the problem? Anyone has a possible solution?
    Thanks in advance!
    Fabrizio
  2. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    3,835
    3,627
    Midwest, USA
    Oh boy...here we go again.. the dreaded bias drift due to defective circuit board issue amplified by cheap bias pots..cue ampmad in...2..3..1..
  3. Fabrizio
    Fabrizio New Member
    Jan 11, 2019
    5
    Thanks for your reply. But not sure i understood the answer (my tech english level is low), could you please explain again what needs to to done ?
    What risks do i have using the amp with a bias that high?
    Thanks!
  4. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,185
    3,896
  5. Jon C
    Jon C Well-Known Member
    May 29, 2017
    371
    498
    The guys are trying to tell you that the JCM2000 ( especially early production years ) had thin circuit boards, cheap resistors, and ran hot …… The heat can cause the board to actually become conductive ( NTC ) and then the bias will continue to change on it's own ( drift ) …… it sucks …… but it's such a common problem that the only real solution is to School Yourself on how and why this happens , test before you buy, ask a tech, and be a smart purchaser …… The toughest thing is that Not All of the 2000s do this …… Read This >>> http://www.desertamplifierrepair.com/project/marshall-jcm2000/
    ( it explains the common problem )
    Here is more info >>> http://www.hullerum.de/Marshall/TSL122repair.html
    ( lots of good knowledge about the issue )
  6. Jon C
    May 29, 2017
    371
    498
    He will be here shortly !!
  7. Mitchell Pearrow
    3,464
    3,080
    Welcome to the forum, as Gunner, and Jon C posted, it’s a known issue, and Ampmad is a member that will help you out, sorry I am not a tech :shrug:
    Fabrizio and Jon C like this.
  8. GT08
    GT08 Active Member
    May 31, 2016
    265
    155
    Does the Amp bias OK using the old Valves?
    El Gringo and Jon C like this.
  9. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    928
    614
    Shakedown Street
    now you are scaring the poor guy (just kidding )
    charveldan likes this.
  10. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    158
    105
    Levelland Texas
    About the only solutions for this is.
    1. Replace main board with ISS 20 board.
    2. Use the bias board mod from Dr. Tube(?)
    3. Replace amp.
    Personally I did the first and a few years later I still don't regret it. I have no experience with number 2 so I will not guess about it but that solution is mentioned a lot. As far as number 3 only you can decide if that is worthwhile.
    Fabrizio, Dogs of Doom and Jon C like this.
  11. Jeff Hudson
    Jul 10, 2016
    158
    105
    Levelland Texas
    Strange, he's usually more punctual than this.
    Gunner64 and Jon C like this.
  12. Jon C
    May 29, 2017
    371
    498
    I hate it when my Coefficient de la Temperature goes Negative
  13. thunderstruck507
    thunderstruck507 Active Member
    Apr 20, 2017
    176
    153
    I did the Dr Tube Bias board mod on mine and the amp sounds better than before, sadly I had already offered to sell my repaired TSL to a bandmate for $540 and bought my JCM 800 otherwise I might have kept the TSL and my credit card balance would be much happier.
    I do love the JCM 800 though, it has a ton more balls than the TSL and gets me that Marshall growl I really wanted.
    Do you know if the amp was biased correctly prior to replacing the tubes? Did you buy a matched set of tubes? If you move the tube pairs from side to side does the bias issue remain?
    Fabrizio likes this.
  14. Gunner64
    Nov 16, 2013
    3,835
    3,627
    Midwest, USA
    What they said, and I would not use it until you figure out that bias.
  15. Dogs of Doom
    16,973
    14,664
  16. Fabrizio
    Fabrizio New Member
    Jan 11, 2019
    5
    Thanks for your reply and links!!
  17. Fabrizio
    Fabrizio New Member
    Jan 11, 2019
    5
    The thing is that I replaced the old ones because one was not working anymore, so I can't figure that out
  18. Fabrizio
    Fabrizio New Member
    Jan 11, 2019
    5
    Actually I am totally new into this inside amps world, but I will try to learn as much as possible now:
    1 No, I don't know if the amp was biased correctly
    2 yes the tubes they were matched
    3 I checked and the problem is the same.
    I will order a new V20 of the motherboard and replace it.
    Jeff Hudson likes this.
