Bias issue on TSL yes I know but this is weird
Discussion in 'Marshall Amps' started by John T, Sep 20, 2019.
  1. Dogs of Doom
    21,491
    23,043
    yeah, funny, this is my 3rd TSL. 1st 2 were stolen. When I bought this one, I wasn't aware of all the issues, as I never had any issues w/ mine. My last one got stolen in '04. So, I hadn't even thought about 1 for a long time. When I saw this one for sale, I didn't think to go looking for caveats, because the 2 I had were fine & I had no reason to look for warnings...
    Once I started looking, after the issue, I noticesd a bunch of footswitch issues, then I found that TSL site that describes the nightmare, before Marshall started issuing replacement boards. Now, the last one I guess is ISS 21. If things start to go downhill after this, I might just get ISS 21 & see if I need the bias board mod. If so, I'll assemble them before installing & go...
    I might then also do the Merc Mag trannies/choke too & it'll be a high performance TSL.
  2. Dogs of Doom
    21,491
    23,043
    ok, so, I'm waiting on the resistors for R6 & R9 to come in, & am getting the amp ready to swap those out.
    I clipped the wire retainer straps, so I could move the output board out of the way & I find this...
    Couldn't see it before. I was just thinking of clipping the wires & soldering the new leads to the ones sticking up, like piggy-back, but removing the resistor. This looks like there's some carbon, from something on the underside.
    I'm not a tech, so I was hoping to just getting it to the point of troubleshooting, then I could either go to the tech, or if I have to, start pulling connector cables & pulling boards, just buy ISS21 board & the bias kit, then I'd have a new amp.
    Admittedly, I used to be good at soldering, but, since the newer solder concoctions, I have a hard time getting it to melt, w/o putting a lot of heat to it, so if I have to start soldering on this, I'l leave it to someone who can do it...
  3. Dogs of Doom
    21,491
    23,043
    Ok, so, I got a brush out & brushed it off, & noticed that it seemed to brush, so I got a toothbrush & some 90% alcohol & brushed around & it appears to have cleaned up.
    I'm guessing the carbon is from the resistor when it went?
    I don't see any residue on the resistor it's self...
  4. mickeydg5
    mickeydg5 Well-Known Member
    24,644
    11,588
    So it was from a previous burnout?
  5. Dogs of Doom
    21,491
    23,043
    I didn't take the board out. It cleaned up (2nd pic) using a brush & alcohol. I'm wondering if it was from the resistor in there that isn't any good. I don't see anything on that though. I'm thinking when the resistor failed it shat on the board?
    I was supposed to get the resistor today, but UPS failed me...
  6. mickeydg5
    24,644
    11,588
    Check for spots or cracks underneath when pulled.
    Dogs of Doom likes this.
  7. Dogs of Doom
    21,491
    23,043
    ok, got resistors today...
    all 4 measure 1.4 ohms on pin 8 from chassis ground...
  8. Dogs of Doom
    21,491
    23,043
    there was a black blowout hole on the underside of the resistor, that blew the carbon on the pcb...
  9. Dogs of Doom
    21,491
    23,043
    I checked everything out, got it to match -42 on all tubes pin 5.
    When I power on, it drops to -41.5
    When I install the tubes, the bias points read 52mVdc w/o adjustment.
  10. Dogs of Doom
    21,491
    23,043
    here's the underside of R9:
  11. Dogs of Doom
    21,491
    23,043
    I think the bias pots might be bad though...
    I got it to bias at around 79.5mVdc/side.
    It moves around a bit though, like it climbs up to 80mVdc & drops to around 78.8mVdc
    or... the dreaded bias board issue.
    It doesn't seem to drift. I plugged it into an 8 ohm cab to bias & play for about ½ hour, before testing it again. It stayed stable, w/in that same climb/drop range.
    jmp45 likes this.
  12. ampmadscientist
    18,093
    12,135
    All seems normal, but replace bias pots recommended.
  13. Dogs of Doom
    21,491
    23,043
    thanks you guys!
    @mickeydg5 @ampmadscientist @marshalltsl @jmp45
    I attached the resistors to the old legs, by making a small loop on the new legs, then making a solder pad. Then I melted the pad & pushed the old leg through. Tugged on it & seemed solid/stable.
    Eventually, I'll have someone solder new ones to the board pad direct (I bought a pack of 10 of the R6/9 variety & 100 of the R21 - same cost :shrug: ) later, but, it should be good enough for jamming around making noise for now...
    I didn't do anything to the ground on the Cliff Jack, but, it seems to be ok for now, as I'm using an 8 ohm cab & it runs ok...
    Looks simple enough, since that board comes right out anyway...
    marshalltsl and jmp45 like this.
  14. mickeydg5
    24,644
    11,588
  15. Dogs of Doom
    21,491
    23,043
    ok, I found my footswitch, so I'm ready to test this...
