Bias issue on TSL yes I know but this is weird
Discussion in 'Marshall Amps' started by John T, Sep 20, 2019.
  1. Jethro Rocker
    7,943
    9,097
    I think any meter accurate to like 5 Mv would be totally fine. A digital meter should absolutley do it.
  2. Jethro Rocker
    7,943
    9,097
    Yes good point. I keep volumes at zero as well. Also on full power not VPR on.
    Lance Chambers and anitoli like this.
  3. anitoli
    anitoli Well-Known Member
    7,565
    8,977
    But if there is a VHF oscillation occurring the meter may not read properly. I have witnessed this first hand with ha fender dual showman.
    Jethro Rocker likes this.
  4. Lance Chambers
    Jun 23, 2019
    1,434
    2,191
    The Land That Time Forgot
    I bought mine from Amazon.
  5. ampmadscientist
    18,186
    12,191
    Do not troubleshoot with the tubes installed.
    Pull the tubes out.
    Turn the power on and leave standby in "warm-up" position.
    Set meter for DC volts.
    Connect black probe to chassis and red probe to pin 5 of output tube socket.
    Read all output tube sockets pin 5.
    Report the DC readings of all output tube sockets pin 5.
  6. mickeydg5
    mickeydg5 Well-Known Member
    24,657
    11,591
    Do any of you search for information?
    This is classic crappy cathode bias monitor resistor behavior. Those 1 ohm 1W resistors crap out constantly.
    Check R6 and R9, both 1 ohm at 1W.
  7. mickeydg5
    24,657
    11,591
    Here is a partial schematic.
  8. Jethro Rocker
    7,943
    9,097
    No I don't. I went with what I kjow about mine. Past that, it wasn't really my issue. Amd I'm lazy. And surly...:D
    And not that clever.
    mickeydg5 likes this.
  9. ampmadscientist
    18,186
    12,191
    Well the way I look at it I test the bias first with no tubes installed.
    if the bias won't hold steady there is nothing else worth doing first but replace pots / board or modify board.
    True the 1 ohms do go bad,,,but the adjustment pots have gone bad in almost 8 out of 10.
  10. South Park
    2,236
    1,811
    Pull out the power tubes. Check the voltage from the grids to the high taps. That bias drift is from a bad circuit board
  11. mickeydg5
    24,657
    11,591
    I know, I know.
  12. mickeydg5
    24,657
    11,591
    It could be the bad board issue but I would rule out the cathode resistor first.
  13. John T
    John T New Member
    Sep 20, 2019
    15
    17
    it is set to DC only
  14. John T
    John T New Member
    Sep 20, 2019
    15
    17
    I'm wondering if I swap the tubes (left two with the right two) if the problem will follow to the right side. I will try that later today.
  15. Gunner64
    Nov 16, 2013
    6,041
    7,708
    Midwest, USA
    It could just be a tweaked bias pot.
    Dogs of Doom likes this.
  16. Dogs of Doom
    21,508
    23,082
    do it, it doesn't cost anything...
    neither does what ampmad suggested...
    nor, what Mickey suggested.
    Just make sure you are careful inside the amp. The TSL supposedly drains cap's, on power down, but, you should always check for yourself, to be sure. If the drain isn't working, you can get a lethal shock...
  17. Jeff Hudson
    Jeff Hudson Active Member
    Jul 10, 2016
    228
    205
    Levelland Texas
    You may have two matched pairs instead of a quad, get a new matched quad and see what happens, unless you have access to a tube tester.
  18. RickyLee
    May 22, 2010
    9,968
    3,389
    Riverside CA U.S.A.
    As the pros here mentioned, you need to check/monitor the bias supply voltage going to each side of the push pull/pins 5 on the power tubes. You can check it in standby with tubes in, or just pull the tubes. On these types of issues, you definitely need to stop playing the amp until you figure this out.
    As Micky stated, it sounds like your ground reference on that odd high reading side is bad, meaning the 1 ohm bias resistor is bad.
    I would thoroughly check the bias supply circuit front to back as well, mainly those trim pots.
    If the 1 ohm bias resistor(s) measure fine with amp OFF, then it could be acting up when in operation only. If bias supply voltage to pins 5 is correct, then you can install a jumper across that 1 ohm bias resistor giving you good cathode to ground connection. Then you have to check the bias on that side via BiasRite type tube sockets or check bias by output transformer windings voltage drop divided into the ohms of the output transformer winding on that side. That will point to the 1 ohm bias resistor as a problem if bias measures correct at that point.
  19. Mitchell Pearrow
    10,310
    17,281
    Welcome to the forum new MF’r I am confident you will get your answers here on this great forum!
    Cheers Mitch
    Lance Chambers likes this.
  20. John T
    John T New Member
    Sep 20, 2019
    15
    17
    Ok so I did the stable bias mod with a new bias board form the UK and still the same issue. Left side (V7 V8) goes right to 22V which the standby is switched. The other side is rock stable where it should be. Marshall suggested removing connector 20 from the lead board but that did not change anything. I tried removing C46 across the pins on V8 as I heard this can cause issues but no luck. I swapped tubes 1 and 2 with 3 and 4 and the problem did not follow. I check the bias with the tubes out and the right side is rock steady at.1mv. The left side goes to -12mv. I put an ohm meter on the pots when I was working on the board. Both pots read the same value. Any ideas where that voltage could be coming from? I have heard that the coupling caps (c6-c7) could be leaking but I think they were bypassed with the stable bias board.
