Bias issue on TSL yes I know but this is weird
Discussion in 'Marshall Amps' started by John T, Sep 20, 2019.
  1. John T
    John T New Member
    Sep 20, 2019
    15
    17
    OK 2002 TSL 100w. Just got this amp and I am very aware of the issues with the bias. So I am checking it and one side I can adjust the POT and get it to 90mv which does increase after time like we know. But the left side will not adjust with the POT and the meter reads 15.00 volts not MV but V! Bad POT?? Not red plating at all so what would you experts think? I am not an expert.
    Thanks
    JT
  2. Jethro Rocker
    7,136
    7,072
    Hmm. Are the tubes 2 matching pairs? Shouldn't read V like that. Something amiss.
  3. John T
    John T New Member
    Sep 20, 2019
    15
    17
    Well like I said I am not the original owner but by looking at the tubes they are RUBY tubes and I do not know if they are matched. But even if they were not matched 15.9 volts seems a tad high. I double triple checked my connection to the amp and I can not see where I made a mistake. Ill try to post a YTube video if I can.
  4. John T
    John T New Member
    Sep 20, 2019
    15
    17
  5. Jethro Rocker
    7,136
    7,072
    Oh thats extreme yes. Could be something at the bias points or circuit. That's where I bow out!
    Sorry was able to watch with audio. That helps! I don't get this at all...
  6. John T
    John T New Member
    Sep 20, 2019
    15
    17
    The meter is auto ranging. Yes DC volts. Read Ma at 200 left side .1 right side .2. The thing that makes me think I'm not screwing up is the right side works as advertised. I'm just puzzled why the left side reads so high. I am planning on pulling this amp apart in the next several days and fixing the bias issue with a replacement board but this is weird. I'll let you know what i find if anything.
  7. Lance Chambers
    Jun 23, 2019
    627
    835
    The Land That Time Forgot
    You have the volt meter on the wrong setting. Change it to the 100 mA setting then redu the bias.
    FYI: 70% saturation would be 34-36mA per tube. Set each side to 72-76 maximum.
  8. South Park
    699
    433
    Try to trace out the bias circuit from the high voltage tap to the grids .
  9. John T
    John T New Member
    Sep 20, 2019
    15
    17
    ok why does it work on one side and not the other?
  10. Lance Chambers
    Jun 23, 2019
    627
    835
    One side is too high thats why the reading is off. The TSL bias adjust is a push-pull type. Turn clockwise will lower that side then raise the other.........vice verse!
    Make small adjustments.
  11. John T
    John T New Member
    Sep 20, 2019
    15
    17
    Putting it on a mA setting does nothing on either side. The right side works like it should setting 90 Mv. the left side does nothing. I will try to look at the amp further tomorrow. It still sounds great though.
  12. Lance Chambers
    Jun 23, 2019
    627
    835
    Important........verify all fuses are the correct values.
  13. Jethro Rocker
    7,136
    7,072
    Yes but not 15 volts. Way too high. Should read in Mv range. Plus the TSL is recommended at 90 per side. I set mine around 84. It should never read even 1 volt.
  14. John T
    John T New Member
    Sep 20, 2019
    15
    17
    If I turn the right side all the way down to 24Mv the left side goes up to over 15V. If I turn up the right side to 100Mv the left side goes down to 14.8 V
  15. Jethro Rocker
    7,136
    7,072
    In layman's terms it's f&cked! :D
    Great sounding amps though.
    Adieu and Lance Chambers like this.
  16. Lance Chambers
    Jun 23, 2019
    627
    835
    I use a Fluke 21 and set it to 300. I also use a socket meter on each tube.
    TSL's are finicky! :wallbash:
  17. John T
    John T New Member
    Sep 20, 2019
    15
    17
    they are
  18. John T
    John T New Member
    Sep 20, 2019
    15
    17
    I have looked at those on Amazon and really did not think I needed one. Do you think they are worth it?
  19. anitoli
    anitoli Well-Known Member
    6,613
    7,312
    Set the meter to read DC only. Is it the same? If there is an oscillation issue an auto ranging meter will read f'ed up.
    Mitchell Pearrow and Force235 like this.
  20. Dogs of Doom
    19,267
    18,937
    @ampmadscientist has a post somewhere around here, where he tells you to pull the tubes & take some readings. Maybe he'll be along shortly...
