Best way to achieve some depth?
Discussion in 'The Tone Zone' started by John Finnerty, Nov 15, 2019.
  1. Trelwheen
    Trelwheen Well-Known Member
    Nov 18, 2017
    1,529
    2,237
    Texas
    Bend her over in the caravan!
    MickeyJ and Mitchell Pearrow like this.
  2. Wildeman
    Wildeman Well-Known Member
    Oct 2, 2016
    1,350
    1,562
  3. MonstersOfTheMidway
    May 1, 2008
    4,907
    2,423
    Like others has said, delay and/or reverb are a good place to start.
    Both delays and reverbs have many different choices. For delay, you can usually choose from digital, tape, analog, reverse, multi-tap, etc. With reverb, you usually choose from spring, room, hall, plate, digital, etc.
    Usually, rack and multi-effects systems offer you the most choices, but there are some small pedals that features some of these same great choices in and all-in-one pedal. Look around and see what works best for you.
  4. Marshall4Metal
    Marshall4Metal Well-Known Member
    Jul 28, 2016
    314
    347
    Chorus /Flange . Reverb/Delay. I use the Corona Chorus it's very transparent dry and can be set very subtle on up from there . For lead a good Delay I would suggest the Mooer Reecho digital analog it's a great pedal only 60 bucks. If moneys not an issue Dispatch Master or an Echoplex.
    BanditPanda and Mitchell Pearrow like this.
