Behringer pedals?
Discussion in 'The Tone Zone' started by SkyMonkey, Dec 5, 2019.
  1. SkyMonkey
    1,386
    1,522
    England
    I could finish building my proposed pedalboard at a stroke for less than £60 if I got some Behringer pedals!
    I want a decent reverb (DR600), a chorus (UC200), and a graphic EQ (EQ700).
    I know they are cheaply built BOSS copies, but they would just sit on a home pedalboard.
    So should I get them as placeholders until I can afford to get better originals?
    Or are they really that $h1te!
  2. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,728
    1,119
    Wisconsin
    I have used the EQ pedal in rehearsal many times. It works just fine; but the cables can slip out of the jacks relatively easy, if things get moved around a bit. Otherwise, no problems.
  3. Lance Chambers
    Jun 23, 2019
    804
    1,144
    The Land That Time Forgot
    For your answers; go here:
    :band:
    stringtree and SkyMonkey like this.
  4. SkyMonkey
    1,386
    1,522
    England
    Been watching that YT vid again and the Behringer reverb seems to be the most different from the original (RV-5).
    The EQ and chorus are claimed to be dead on though.
    I might have to try one.
    stringtree and Lance Chambers like this.
  5. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,126
    860
    Saginaw MI
    another budget copy option is Joyo brand.
  6. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,582
    1,669
    Södertälje, Sweden
    People complain about the plastic case, but they're tuffer than you'd think.
    My main problem is with the delays and reverbs.. it's fx blend and not fx level. Result is when you turn up the delays, dry signal goes down. It works but it makes it harder to get the level just right.... but at the price, might be something you can live with...
    J
    Ps this might not apply to the vintage style analog delay..
  7. Lance Chambers
    Jun 23, 2019
    804
    1,144
    I agree! I have sixteen of their pedals and not one of them has failed. I can even change the battery in roughly thirty seconds.
    FWIW: Their "PB1000" board is the best! :2c:
    SkyMonkey and stringtree like this.
  8. Wildeman
    Wildeman Well-Known Member
    Oct 2, 2016
    1,338
    1,534
    I think there's better choices, somebody's mentioned Joyo already and check out TomSline/Aroma pedals, some of them are killer. I had a Beringer Super Fuzz and it was Super Shitty.
    SkyMonkey likes this.
