Baffle Material And Type Question
Discussion in 'Cabinets & Speakers' started by KraftyBob, Jul 9, 2018.
  1. KraftyBob
    KraftyBob Active Member
    Sep 5, 2017
    157
    95
    Chicago Suburbs - USA
    I'm going to start the rebuild project on my speaker cab pretty soon. I'm converting a headless MG250DFX 2x12 into a 1x12 cab for my DSL40C so I need to make a new baffle. I was going to use 3/4" Birch ply and reached out to a friend of mine who has a nice home shop to see if he can help me with the speaker cut out. He said he has Maple I can have and that it's characteristics are somewhat similar to Birch. He thinks he might have both solid and ply.
    I did some checking and from what I can find Maple has a similar high end resonance of pine and the low end thump of birch ply. The only drawback was weight but for my project it's just the baffle so I'm not concerned about that.
    Pretty much everything I read defaults to birch for the baffle and there isn't much else on maple. Also, a lot seem to suggest ply vs solid. I don't know if it's a cost thing, or functional, or both?
    Part of me is wondering if I'm over thinking it because the rest of the cab is MDF. I'm just trying to avoid having to redo it if maple is not a good option.
    What say you Marshall forum?
  2. GIBSON67
    GIBSON67 Well-Known Member
    Sep 8, 2008
    7,997
    3,633
    Lakeland, TN
    Maple should be good enough! But in what thickness? Half inch would be a minimum, I would think.
    I think the solid vs ply thing would be because most solid wood planks only come in 12 in wide boards, so ply could be anything wider, basically.
  3. Dogs of Doom
    16,000
    13,321
    build a whole new cab w/ maple... :)...
    The reason for ply vs solid, is warpage. Plywood has less tendency to warp, once assembled & if it does, it won't disfigure the cab, or leak air. If the baffle warps it will either leak air, of disfigure the speaker.
    Birch & maple are both used for drums, as a standard.
    Look at @Geeze 's cab's he's built. Sell the MG for $50 empty (if you can get it) to pay for the wood. You'll be much more happy, than cutting down an MDF cab...
    Geeze likes this.
  4. KraftyBob
    Sep 5, 2017
    157
    95
    I'm using 3/4". The baffle will be about 17 1/2" x 26" so it needs to be strong. Dogs of Doom echoed what I've been finding online about solid woods while researching this afternoon - warping. 26" is probably to large a span for a solid wood - even if it's several pieces - because if it warps due to humidity/temp changes, and it pulls on the speaker frame it could cause the voice coil to rub.
    @Dogs of Doom - I originally thought about building a cab because there aren't many 1x12 options wide enough for the DSL40's 24" width. The problem is I'm very limited on time for the foreseeable future so that could easily take 6, maybe 9 months to complete. When I came across the headless MG online I grabbed it because it would save months on this project. Heck, I bought the MG over a month ago and am now just getting to the planning stage. Time building the cab means less time playing guitar so I'll take playing over building right now.
    BTW, if you're thinking that I can enlist my friend who has the shop to help build the cab - he's also my jamming buddy and we've had little time for that lately. Maybe some point in the future when I have more down time.
    So to answer my questions: If my friend has Maple ply I'll use that. If not, I'll buy the birch ply.
    Thanks for your responses.
    Metroman likes this.
  5. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    834
    1,128
    Floating above Dallas in Marshall Heaven
    If your buddy has maple ply - it will work fine. Solid - if you are 5/8" to 3/4" you'll probably be fine unless you're in an area with large humidity swings. I'd cut the solid maple into planks that cover at least a 1/3 of the height and reverse the center section and glue with a Titebond II or III type glue. I only edge glue after experimenting with dados, biscuits and dowels - not found it necessary with Titebond. Just need to rip the edges square and straight.
    I've done some very crazy shit with solid wood strips, chunks and planks for guitar cabinets and not had anything warp or delaminate.
    Russ
  6. KraftyBob
    Sep 5, 2017
    157
    95
    I’m back... Just heard from my friend. After a quick look at his stock the 3/4” Maple ply he has is only 15” wide. I need 17 1/2”. He said he could biscuit join two pieces. He does have 1/2” & 1/4” maple ply that would fit and he could glue them together for a 3/4” piece.
    He also has 3/4” Red Oak that would fit but I know very little about this. I did read that Red Oak has no acoustic properties - but some say that’s good because you don’t want the wood to color the sound. Someone also said that if red oak is not properly sealed it gives off a gas that corrodes. Said it ruined a friends speakers. Sounds like BS to me but who knows - stranger things have happened.
    Thinking I’ll just go back to my original plan and get a sheet of birch ply.
    Thoughts?
  7. KraftyBob
    Sep 5, 2017
    157
    95
  8. Dogs of Doom
    16,000
    13,321
    ½" would work for a 1x12. It's an open back MDF cab, right?
    TBH, you're not going to get a lot of anything special tonally. The cab is already tuned a certain way. You might get a little brightness from the baffle being a harder wood (than MDF), but, the cab will deaden out vibrations on the top/bottom/sides & the open back will let the pressure escape out the back.
  9. KraftyBob
    Sep 5, 2017
    157
    95
    Actually it’s a closed back cab. I’m making the new baffle taller so it covers the slot where the head used to be. But the speaker area is fully enclosed.
    I have the G12M-65 Creamback in my DSL and bought a used G12T-75 for the cab. From what I’ve read the T-75’s like closed back cabs and I thought it would pair up nicely with the Creamback. I tested it when I bought and like what I hear so far.
    So you think a 1/2” maple ply baffle will be ok if it’s 17 1/2” H x 26” W?
  10. ampmadscientist
    7,675
    2,967
    Maple is just a waste of money.
    Birch plywood ("gap-less birch") aircraft grade birch, marine grade birch plywood has no air pockets.
  11. KraftyBob
    Sep 5, 2017
    157
    95
    The reason for Maple is my friend has extra stock laying around his shop and said I could take what I need so there is no cost. He doesn’t have birch so maple or red oak are my only “free” options.
    If those don’t work I’ll buy a piece of birch.
  12. KraftyBob
    Sep 5, 2017
    157
    95
    While I have you guys... in a 1x12 closed back cab is it bad to center the speaker? I ran across some threads that said you should offset the speaker by 3/4” - 1” so frequencies don’t get messed up/cancel inside the cab. But looking at a lot of 1x12 cabs online (good name brands) it appears that the speakers are centered.
    On the other hand, the speaker on the DSL40C is mounted off center to the right when looking at the front of the amp. Which puts it directly under one of the power tubes and closer to the power transformer (I think that's what it is?). If it was centered there would still be plenty of clearance for the OT which is on the other side of the chassis. Being a partial open back I would think that frequency cancellation wouldn't be an issue?
  13. Geeze
    Jul 25, 2015
    834
    1,128
    If you're a pounder a 1/2" baffle in a closed back cab wouldn't be my first choice due to baffle flexure. Home Creepo has multi ply 24x48" 11/16" unknown wood that works as well as birch. Don't buy into the tone wood debate - on an acoustic guitar, OK. On a cab [built 22 to date] I've yet to see / hear anything that leads me down the deep dark hole of tone wood. I pick 'em for pretty.
    I don't have a definite answer on the centered / not question - but, there is too much application of HiFi sound reproduction engineering and practices that don't apply well to the LoFi of guitar amp sound creation. Do what appeals to you.
    BTW - the Wood Database is a great source for wood strength, work-ability and hazards [if any].
    http://www.wood-database.com/red-oak/
    Russ
  14. KraftyBob
    Sep 5, 2017
    157
    95
    Thanks again, Russ - I greatly appreciate. I think I’ll give the Oak ply a shot then. Worse case I yank it, get some HD Ply and redo the baffle.
    I’ll update at a later date when I’m done and let you guys know the results.
  15. FutureProf88
    FutureProf88 Well-Known Member
    Oct 2, 2012
    1,671
    653
    St. Louis metro area
    I built a birch baffle for a repaired/repurposed/homebuilt 212 once. It is is an MDF cabinet and the whole thing turned out fairly well. PM me if you have any questions.
  16. KraftyBob
    Sep 5, 2017
    157
    95
    Thanks for the offer. I’ll keep that in mind as I’m doing this.
  17. pedecamp
    10,743
    5,455
    Being the cab has MDF sides I'd go with ply for the front and back. I find mixing the two create good sound out of a cab. I always build ply cabs with MDF front and back for best sound, all ply sounds boxy to me.
  18. tschrama
    tschrama Well-Known Member
    May 15, 2010
    890
    294
    Netherlands
    In my experience the front baffle is best kept non resonant.. very thick ply.... or mdf.
  19. KraftyBob
    Sep 5, 2017
    157
    95
    I'm going with the 3/4" Oak ply. Worse case I don't like it and build a new baffle out of Birch. I'm not gluing the grill cloth so every thing I'm doing is fixable/reversible.
