Avt 100 Four Button Foot Switch Fault
Discussion in 'Introduce Yourself' started by Kevin Whittle, Mar 31, 2019.
  1. Kevin Whittle
    Kevin Whittle New Member
    Mar 31, 2019
    4
    Hi guys
    Please help!
    My pedal works individually but when on the clean channel if I try to go from clean to OD 1 nothing happens. However if I press clean first then OD1 it switches. Or if I press clean and OD1 at the same time it switches. I can not go from clean to OD2. But once OD1 is made I can then switch between OD1 and OD2 no problem. I can go back to clean but once in clean the problem starts again. FX works as it should. The amp buttons all work ok so fault is somewhere in the pedal. All LEDs light up when the channel is activated. I have looked inside and all the wiring is intact. Only the clean relay has a capacitor wired to it.
    Any help or a wiring diagram will be very welcome
    Cheers
  2. Jon C
    Jon C Well-Known Member
    May 29, 2017
    923
    1,563
    Wa State
    How many conductors are there in the cable for the 4 button Footswitch ?
    If there is less than 5 then you have an IC Multiplex
  3. stringtree
    stringtree Well-Known Member
    May 21, 2016
    708
    1,154
    :welcome:to the forum! :dude:
    Sometimes an amp needs to be set on a certain channel for it to work properly. I don't know if this is true for your amp but worth a try.
    Unplug the footswitch and set the amp on the first channel, then plug in the footswitch. See if this helps.
    If it doesn't, be patient, and I am sure there are those that know more will help.
  4. Trident
    Trident Well-Known Member
    Mar 8, 2018
    732
    773
    Paradise in FLORIDA
  5. Mitchell Pearrow
    5,258
    6,368
    :welcome:To the amazing Marshall forum, where no question goes un answered, I cannot answer your question but be patient there are others here who can/ and will! Cheers Mitch
    stringtree likes this.
  6. Wooferhead1
    Wooferhead1 Well-Known Member
    Jan 19, 2019
    344
    609
    Ohio
    Welcome!:hbang:
  7. Micky
    Apr 29, 2010
    19,780
    15,692
    Vermont
    Greetings!
  8. Kevin Whittle
    Mar 31, 2019
    4
    Thanks guys
    I’ll try string trees suggestion and come back to you.
  9. Kevin Whittle
    Mar 31, 2019
    4
    Hi Jon
    Sorry but I don’t understand you question
  10. Kevin Whittle
    Mar 31, 2019
    4
    No, makes no difference where the amp is switched before connecting the foot pedal.
    The cable is a 15 pin socket each end.
  11. Jon C
    May 29, 2017
    923
    1,563
    Wa State
    Get a multimeter out and set it to 200vdc …… map out the pins and check everything until you find the common ground and note the voltages on all of the pins as you test …… you may find that you actually discover what does what as you test …… start there and let us know what you find …… BTW ……you do not have a Multiplex IC Switcher
  12. Dogs of Doom
    17,763
    16,323
