Attenuator for really low bedroom level
Discussion in 'Marshall Amps' started by blase, Nov 11, 2019.
  1. blase
    blase Member
    Mar 19, 2013
    56
    12
    What is the best attenuator for really low bedroom level?
    I am considering riviera rockcrusher, but maybe you have something better?
    Hutch likes this.
  2. tce63
    Aug 6, 2018
    965
    2,374
    Sweden
    What amp are you going to Attuneat ?
  3. blase
    blase Member
    Mar 19, 2013
    56
    12
    class 5
    SV20
    I currently have a simple resistor attenuator
  4. JohnH
    JohnH Well-Known Member
    May 31, 2008
    3,666
    1,592
    Wilton NSW
    tce63 likes this.
  5. Thrane
    Thrane Active Member
    Nov 7, 2016
    126
    89
    Fryette Powerstation 2.
    I use it with my 1959HW, JCM800, JTM 45.
    It is really good! Also at bedroom level.
    Advantages:
    Stepless volumen-control.
    Build-in effectsloop.
    Different toneshaping options if needed.
    It can also operate as i 50W poweramp. That means you can turn lower wattage amps into 50W.
    Military quality.
  6. tce63
    Aug 6, 2018
    965
    2,374
    Sweden
    As @JohnH posted, the Weber Mini mass is great.
  7. ricksdisconnected
    Aug 11, 2019
    572
    893
    mini mass for the win.
  8. ampmadscientist
    14,271
    8,082
  9. Fierce_Carrot
    Fierce_Carrot Member
    Oct 30, 2019
    27
    38
    Honestly, if you need to get the volume that low, look at a digital amplifier like a Line6 or something of that kind. Attenuators really change the sound and the amp is not going to sound like you want it to.
  10. Hutch
    Hutch Active Member
    Oct 11, 2013
    150
    139
    Virginia
    I like riviera rockcrusher you get 8db to 20db cut then you can switch to studio setting and can take it to a wisper.
  11. purpleplexi
    purpleplexi Well-Known Member
    Feb 14, 2011
    441
    571
    Totally agree. To my ears you alway lose too much along with the volume. Marshall had gone a bit further and added say a half watt setting to that amp it really would've covered all the bases.
    tce63 likes this.
  12. Biff Maloy
    Biff Maloy Well-Known Member
    Mar 13, 2019
    285
    727
    "Really low bedroom level" is not attenuated tube amp territory to me. There are going to be several suggestions for attenuators that do a great job but i highly recommend a modeling rig for what you're asking. I'm a tube guy for sure but at the volumes you are wanting i get a much better tone with my L6 Helix into studio monitors. Again, this is from a guy who loves tube amps.
  13. Thrane
    Nov 7, 2016
    126
    89
    If you want a real tube amp, and play it at bedroom level, then the Powerstation 2 will do the job fine.
    I'm talking of experience.
    But ofcourse you will sacfice something tonewise whatever amp you play at low volume.
  14. Bke
    Bke New Member
    Nov 1, 2012
    12
    13
    Best for me is not really an attenuated but reamper. I use the boss tube amp expander. Keeps the feel and tone intact better than any other I’ve tried. Variable impedance selector allows you to change the j out impedance to suite your amp and can. Works for me. Also you can add effects (built in reverb, delay, compressor and eq) it’s pricey but you asked best.
    I’ve tried rock crusher, freyette ps2 and uad OX. Boss Tae works best for me by a margin.
    tce63 likes this.
  15. Jon C
    Jon C Well-Known Member
    May 29, 2017
    1,337
    2,290
    Wa State
    $200
    $400
    $800
    $1200
    what’s your budget ?
    All have been listed by others here…
  16. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    733
    669
    If your willing to spend $1200 to try and "fix" an amp, why not spend $1100 on a new amp that will do just what you want. Not only will it go down to a whisper but it will also blow the windows out if you want and sound incredible doing it.
    wakjob, tce63 and Mitchell Pearrow like this.
  17. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    5,056
    3,262
    C-137
    Attenuators...I've been through all this before.
    And I'll just say this...
    Try it for yourself.
    That's gonna be the ONLY way to know if you will like it.
    For some people, and with particular amps they will satisfy.
  18. blase
    blase Member
    Mar 19, 2013
    56
    12
    1. I am thinking about rockcrusher or power station, I read about power station:
    "I generally don't attenuate below 10-11 o' clock on the dial. It does get a bit wooly below that (but any attenuator I've used does).
    Be warned, it won't get a cranked 100W Super Lead down to bedroom volume."
    it's quite expensive - it's really not as good at very low level?
    2. boss tube amo is out of the budged
    "I’ve tried rock crusher, freyette ps2 and uad OX. Boss Tae works best for me by a margin."
    Was the difference between rock crusher, freyette ps2 and boss tube amp significant?
    tce63 likes this.
  19. Metroman
    Metroman Well-Known Member
    Apr 29, 2014
    731
    401
    For simple "Attenuation" Id look into the
    SPL REDUCER
    For added features, and Reamping, Id get the Power Station.
    Sailindawg and tce63 like this.
  20. anitoli
    anitoli Well-Known Member
    6,787
    7,623
    Even with an attenuator it can get loud depending on where you set the attenuation level and the output level. I use Rockcrushers not to get it to bedroom levels but to get the power amps into their sweet spot and knock off excess volume. For bedroom level i'll play an acoustic.
