Attenuating a Marshall with an Effects Pedal
Discussion in 'Marshall Amps' started by John BNY, Dec 19, 2019.
  1. John BNY
    John BNY Well-Known Member Premium Member
    Jul 13, 2013
    1,943
    2,860
    New York
    I don't attenuate any of my amps, but recently, a friend bought one of my JVMs. But he was having a little difficulty controlling the volume in a small room. We stuck a TS-9 pedal, turned down the gain and volume, and we were able to attenuate the volume.
    So, are there any harmful effects in reducing the loud amp volume with a footswitch? Why do people buy attenuators when you can reduce volume using a footswitch? Thanks for your input.
  2. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    747
    423
    Different strokes for different folks. Using a pedal won’t hurt your amp, you can use it on the front end or in the effects loop.
  3. wmachine
    wmachine Well-Known Member
    Dec 18, 2015
    235
    332
    Ohio
    I'm sure more qualified answer will follow, but I think the gist of it is how you reduce the volume. I doubt the pedal reduces it like an attenuator meaning your altering other things (sound-wise) in the process with the pedal.
    BanditPanda likes this.
  4. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,221
    5,436
    Montreal
    Hi John..if I may answer a question with a question?
    I basically do the same thing i.e. I run my amp at 7 and then bring down the volume by use of the pedals on my board. I don't know if that is " attenuating " as we know it i.e. getting the power tubes to hum while keeping the volume out put bearable.
    By using a pedal are we not just reducing the signal reaching the pre amp and power amp sections and thereby preventing those tubes from getting the juice that makes them hum?
    BP
    Jethro Rocker likes this.
  5. El Gringo
    El Gringo Well-Known Member
    Jul 24, 2015
    1,539
    1,413
    Shakedown Street
    I have to think there is no harm to the amp by the method of using an overdrive like the TS9 versus a load reduction device which will wear the tubes out faster . I think it's safe and a good method to use .
  6. wmachine
    Dec 18, 2015
    235
    332
    Ohio
    I can tell you this. The point of the attenuator *is* to run the tubes at where the sweet spot is for the tone. Which is pretty much cranked. And cranked wears out tubes faster, yes, but that what you need to get the sound. If you're not going to crank the amp, you don't need a pedal to bring down the volume, just turn down the volume on the amp. A load box does not wear out tubes, a cranked amp does.
  7. Nik Henville
    Jul 18, 2018
    1,197
    1,945
  8. marshallmellowed
    Jun 26, 2009
    3,329
    3,595
    I'm a bit surprised to hear that someone was having trouble controlling the volume of a JVM. That aside, using a pedal to reduce a guitar level, or line level signal, is completely different than using an attenuator, which dissipates unused energy from a cranked amp.
  9. John BNY
    Jul 13, 2013
    1,943
    2,860
    New York
    I understand the coloring of the tone, so using an OD pedal may not be the best course. But let's say you want to crank the JVM volume to get the tone you want, but want to control the volume. If you were to stick an EQ pedal, and then reduce the volume, you can theoretically take that tone you want while reducing the output volume. Isn't that what an attenuator does?
  10. junk notes
    junk notes Active Member
    Dec 10, 2018
    244
    231
    Attenuating a Marshall with an Effects Processor:
    four cable method
  11. Nik Henville
    Jul 18, 2018
    1,197
    1,945
    No. Short answer.
    Slightly longer response...
    An attenuator allows you to drive the tubes (especially the Phase Inverter and output tubes...) into distortion (that's very loud) and then reduce that loudness to levels more suited to small venues, living room or even night-time apartment living... whilst keeping the dirt. It does this by changing some of the loud for heat, so that the signal the speaker gets is reduced. The downside of this is the tonal change brought about by the reduction in loudness as predicted by Fletcher and Munsen. No idea what any of this means???
    Then Google is your friend :cool:
    Mr. Natural and John BNY like this.
  12. pedecamp
    13,788
    10,173
    You can do this but with a pedal think of it like rolling back your guitar volume knob, this is doing the same thing. An attenuator takes your overdriven signal without "rolling it back" and keeps all that overdrive but at a lower volume. Lets use a real life example, I run my SV20H volume dimed and have a pedal in my effects loop to control volume, I get an edge of breakup tone with it set like this, now if I were to turn off the pedal and keep my amp volume dimed like it is my volume would blow the roof off and I'd have tons of gain in my tone.
    Anyway, I've played JVMs many times and have a hard time believing your friend cant get good tone at low volume. He's doing something wrong. :scratch:
  13. RLW59
    RLW59 Well-Known Member
    Nov 30, 2017
    604
    458
    At least 2 companies sell a simple passive volume box to plug into fx loops. Literally just a pot, a knob, and 2 jacks. If the amp's existing knobs are touchy and abrupt, yes it can help you dial-in the preamp sweet spot.
    But it's just an additional master volume. It's a signal attenuator, not a power attenuator. It lowers the signal that's going into the power tubes -- it doesn't take the power coming out of the power tubes and turn it into heat like a power attenuator does.
    Power tubes distort when they have a big input signal that drives them to try and produce more power than they can. Lowering the input signal to the power tubes reduces the power tube distortion.
    With earlier designs like Plexis, power tube distortion is a significant part of their iconic tone. If you have one with a loop (modded or reissue), a volume control in the loop reduces the power amp distortion. The only way to get all the amp's distortion is to run it crazy loud, or put an attenuator between the amp and speaker. An attenuator lets you get a distortion component that only happens when the power tubes are trying to put out more than full volume at a reduced volume.
    JVM's and many other modern amps are designed to get all their distortion from the preamp. Most people say they sound worse if you crank them loud enough for the power tubes to distort heavily.
    So since you don't really want power tube distortion with a JVM, few people use attenuators with them. You can get full distortion at lower volume just by turning down the master.
    If you find the controls abrupt or touchy to set, a volume control in the loop is fine. Totally safe. Set the regular knobs then use the loop volume to raise or lower the volume.
    But it reduces how hard the power tubes are working by lowering their input signal. It doesn't let you get power tube distortion like an attenuator.
    It doesn't let you get any tone that's not already available via the amp's existing knobs. It just makes it a little easier to get those tones.
  14. John BNY
    Jul 13, 2013
    1,943
    2,860
    New York
    You definitely can play the JVM at low volume, but he was trying to get to whisper volume. On the clean channel, the MV volume at 1 is decent volume, though it didn't seem like it in my studio. But, if seemed very loud at his house. I tried going on the OD channel, and then reducing the pedal volume to very low, and I was able to get decent tone at a whisper volume. But, I get what you guys are saying -- you are not getting the proper tube tone at a lower volume by going this route.
  15. ricksdisconnected
    Aug 11, 2019
    1,238
    1,825
  16. pedecamp
    13,788
    10,173
    Whisper volume, most people dont know this but tell youre friend those times he needs whisper volume he can plug a guitar and headphones into any OD or distortion pedal and get in some whisper volume guitar play. :yesway:
  17. RLW59
    Nov 30, 2017
    604
    458
    I've never played a JVM so I don't know how touchy the master is.
    But there are amps like the first gen Fender HRD where the master goes from silent to too damn loud between 0~1. Very hard to get "just right" at bedroom volumes.
    A volume in the loop works great for that. Lets you easily fine-tune low volume settings.
    If your buddy is needing to play so quietly that just touching the master makes the volume jump up too high, an extra volume in the loop is fine.
    ricksdisconnected and John BNY like this.
  18. Sustainium
    Sustainium Well-Known Member
    Oct 4, 2019
    267
    503
    Lapeer, Michigan
    Very interesting, I’m definitely one of the “most people”.
    marshalltsl and pedecamp like this.
  19. tallcoolone
    tallcoolone Well-Known Member
    Mar 7, 2011
    766
    1,215
    “Whisper volume” and 100w tube amps don’t go together. At those levels a Code 25 will sound a lot better than a JVM
  20. pedecamp
    13,788
    10,173
    A multi-effects pedal works extremely well and some even have a headphone jack like the Digitech and a drum machine built in. :yesway:
