Are These Tube Close Enough?
Discussion in 'The Workbench' started by BowerR64, Mar 10, 2019.
  1. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,211
    2,093
    These came in a used JetCity Amelia i got friday.
    This is what the lowest one was set at when i got it.
  2. 67Mopar
    67Mopar Well-Known Member
    Jun 14, 2011
    663
    756
    No more than 8mA variance is recommended, but they're fine. I like mine a bit out of spec, as it seems to add a certain something.
  3. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    Looks like the amp has something wrong with it.
    Screen resistor blown?
    Why is there 0 plate volts?
    0 plate volts indicates the OT is bad.
    anitoli likes this.
  4. anitoli
    anitoli Well-Known Member
    5,279
    5,109
    Why does the first pic show no plate voltage?
  5. 67Mopar
    Jun 14, 2011
    663
    756
    Hey, AMS... Wouldn't the plate voltage be the same on both?
  6. BowerR64
    Nov 23, 2014
    4,211
    2,093
    nvm now i know i need to replace em. i dropped the one reading 14. and now its at 30. the dang probe box slid off the cabinet and pulled the tube and it hit the carpet still warm now its double what it was reading
    its just a matter of time now right?
  7. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    OT bad?
  8. 67Mopar
    Jun 14, 2011
    663
    756
    Oops! Dropping hot tubes is a no-no. Well, dropping tube is a no-no...
  9. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    Unless the OT is toast...
    myersbw and 67Mopar like this.
  10. BowerR64
    Nov 23, 2014
    4,211
    2,093
    You know ive had this probe do that before in the past when taking pictures of the screen. Im thinking that it shows the display in pulses or something and i just happen to snap the image when the display is pulsing off.
    Ive wiggled the wires and it has no shorts its just sometimes when taking a picture the voltage will show 000 like its rechecking the voltage. Its never showed 000 with the naked eye.
    MarshallDog likes this.
  11. 67Mopar
    Jun 14, 2011
    663
    756
    I ran tubes with a 10mA variance for a couple of years, and never had an issue. The amp actually sounded better than when I used a closely matched set. Both sets were =C= brand.
  12. charveldan
    charveldan Well-Known Member
    Jan 31, 2010
    7,379
    4,179
    With 468 plate voltage your bias should be 37ma.
  13. BowerR64
    Nov 23, 2014
    4,211
    2,093
    These are the stock jet city china tubes they say "electron tube" EL34-B
    Damn i cant believe i dropped it, what a bone head move.
    Oh well i found a matched set so ill put em in when i get em.
    This is the second JetCIty ive had the first one was a JCA50H and it was about as funky as this one.
    The way the pots taper feel weird on these amps. Some of the pots have a slow taper and dont seem to do anything in some positions and some work like what ide expect.
  14. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    9,588
    6,961
    Taintville
    And...That’s what I was wondering?
    That’s very strange!
  15. mickeydg5
    19,221
    7,234
    Then you should have returned them.
    As said, something is very wrong, the probes and maybe the power tubes if not more.
  16. BowerR64
    Nov 23, 2014
    4,211
    2,093
    Let me explain again.
    When i look at the bias probe with the naked eye i always ALWAYS see a plate voltage its only when im taking a picture of the probe i seem to get a no plate voltage reading. I went round and round with you guys over this shit one other time with a different amp and you guys swore up and down something was wrong with that amp too, then it was the probe, then it was the website i got it from or something.
    It has something to do with the refresh rate of the display or something with the flash. Like i said ive wiggled the wire ON THE PROBE and it never goes blank like that it just seems if i time it just right when taking the picture it shows 000
    Some times the display does this also, but it didnt look that way when i look at it with the naked eye.
    This is digital shit, digital camera, digital display, flash, 60 cycles hell i dono
    This is one probe and 2 different images cropped together the one with no plate voltage was just bad timing. (the first image in the original post to clarify so there is no more confusion)
  17. ampmadscientist
    10,752
    4,941
    Whereabouts Unknown
    The tubes should be about 3 ma apart or less really if the tubes are matched.
    We think something is wrong based on the readings which is understandable considering what we see on the meter.
    If the readings show a big difference check the screen grid resistors.
  18. BowerR64
    Nov 23, 2014
    4,211
    2,093
    i got the new ones today im done messing with it
    The higher one is pictured the other one is slightly lower at 31.1mA-DC
  19. charveldan
    Jan 31, 2010
    7,379
    4,179
    Seems you need to change the bias resistor.
    Did the amp originally have 6L6's or something other than EL-34's ??
  20. BowerR64
    Nov 23, 2014
    4,211
    2,093
    now why would you say that?
    i already posted what it had above
