Appropriate Cab for DSL40C?
Discussion in 'Cabinets & Speakers' started by Kevin Mitchell, Jan 20, 2014.
  1. Kevin Mitchell
    Kevin Mitchell New Member
    Jan 20, 2014
    4
    Hey everyone this is my first post here in regard to the lack of info on matching a cab with this beautiful combo amp. It's not that I am dissatisfied with the combo itself. I'm very pleased with it! But I'm fixing an idea to find that perfect Marshall cab to expand the current rig. I wish I could find one with appropriate dimension and look (white piping, matching tolex & grill).
    Does anyone know the ACTUAL dimensions of the MX212? Seemingly this would be the easiest/cheapest choice. But info on this box is inconsistant here on the web. My best guess is just under 30inches matching with the DSL100H.
    Found on this sales page
    Is it even worth it to extend the 40C with an additional cab?
  2. Micky
    Apr 29, 2010
    20,110
    16,139
    Vermont
    Yes, it is well worth it to attach a cab to the DSL40c.
    It adds a depth that is sometimes missing with an open-back cab.
    Marshalls new site has all the dimensions for their cabs.
    The MX212 is 750 x 545 x 315, but it is an 8-ohm cab.
    You would not be able to use it in conjunction with the internal speaker.
    (that is unless you rewired it with different speakers...)
    steveb63 likes this.
  3. Kevin Mitchell
    Jan 20, 2014
    4
    Yeah modding the mx212 to run both combo and cab is seemingly a fair option and really wouldn't cost much.
    What are some good alternatives?
  4. mickeydg5
    21,262
    8,933
    Hello Kevin
    You could always get the MX112 or a custom 1x12 or 2x12 at 16 ohm to use with the combo and its 16 ohm speaker.
  5. Kevin Mitchell
    Jan 20, 2014
    4
    How about the JVMC212? The dimensions seem good aside from being a little wider in length. I would like something wide, preferably matched specs so I can stack the two.
    Maybe I should consider building my own Marshall replica cab with perfect dimensions?
    SG~GUY and Micky like this.
  6. mickeydg5
    21,262
    8,933
    The JVMC212 is a great cabinet with a great sound but is open back.
    Micky likes this.
  7. Micky
    Apr 29, 2010
    20,110
    16,139
    Vermont
    Kinda sad really the offerings Marshall does NOT have for cabinets.
    Most of their lower-priced cabs are 8-ohm, and generally contain speakers no one in their right mind would normally use.
    Personally I like the 1922, but it is mono 8-ohm and stereo 16-ohms each side.
    Another major fail if you ask me. To top it off it has 12-75's in it.
    Same way for the MX212, MDF construction with Seventy-80's loaded into an 8-ohm cabinet.
    Looks like Avatar is the way to go to get something you really want, let's say, a 2X12 made with birch plywood, loaded with greenbacks. Or WGS V30's. Wired for 16-ohms mono (no stereo opiton that no one ever uses).
    Don't even get me going on dimensions... Marshall doesn't make a SINGLE matching (size) cab for their combos. Go figure...
    whitecloud and SG~GUY like this.
  8. Kevin Mitchell
    Jan 20, 2014
    4
    I've decided to make a replica Marshall with 2 x 10inch 16ohm speakers. I'd construct it to match the dsl40c width and depth. Haven't made a cab yet but with some ingenuity I think it'll be a great extension. Doesn't seem too complicated.
  9. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,688
    1,059
    Las Vegas, NV
    Kevin,
    Just a couple of thoughts/opinions.
    A - While I like a combo for the "grab & go" convenience of going to a quick jam, I really don't like the sound of open back speaker setups.
    B - It is my opinion that much of the benefit gained by adding a closed back extension cabinet is defeated by running it in conjunction with the combo's open backed speaker.
    C - I think you would be best served by considering your extension cab to be used by itself and ONLY use the combo speaker when doing a "grab & go." This also makes the combined impedance factor less of an issue.
    All that being said, I have several combos and two very old 4x12 cabs loaded with greenbacks and these cabs are guaranteed to bring out the best of any combo by ignoring the combo's speaker!
    JMHO,
    Gene
  10. dmagalhaes
    dmagalhaes New Member
    Dec 27, 2013
    11
    7
    I see the DSL 40C as only being partially open back as it doesn't have a huge opening like in some other combo amps. That being said, any of the custom cab builders could no doubt build a solid back panel for short money.
  11. Micky
    Apr 29, 2010
    20,110
    16,139
    Vermont
    There is no top vent on the DSL40c, so you need an open back for ventilation.
    I wish it was that easy...
  12. Gene Ballzz
    Feb 19, 2013
    1,688
    1,059
    Las Vegas, NV
    You beat me to it!:wave: To add to that, even if we ignore the ventilation issue, just slapping a back cover on a possibly improperly sized box will not necessarily achieve the desired result.;)
    JMHO,
    Gene
  13. hbucker
    hbucker New Member
    Oct 3, 2013
    206
    105
    HAmmer likes this.
  14. batmanrb89
    batmanrb89 Member
    May 13, 2013
    31
    4
    Basking Ridge, NJ
    Just curious. Any luck with the DSL40C and MX412? I've been considering this combination until I get the DSL100H.
  15. Swede
    Swede Well-Known Member
    Jun 18, 2014
    4,489
    4,138
    SmelLA
    Adding an extra 1X12 to the DSL40 certainly made the amp BIGGER for me.
    lordquilton and HAmmer like this.
  16. batmanrb89
    batmanrb89 Member
    May 13, 2013
    31
    4
    Basking Ridge, NJ
    I'll be plugging the DSL40C into the MX412A tonight. Will post review in a few days
  17. batmanrb89
    batmanrb89 Member
    May 13, 2013
    31
    4
    Basking Ridge, NJ
    Quick pictures of how it looks with DSL40C on top. Will post sound clips soon.
    HAmmer likes this.
  18. Swede
    Jun 18, 2014
    4,489
    4,138
    SmelLA
    home made
    Crunchifyable, SG~GUY, HAmmer and 2 others like this.
  19. morbe
    morbe New Member
    Feb 10, 2015
    11
    2
    San Antonio
    My first Marshall! after years of owning Fender and Fender type amps im on official Marshall owner!
    Im in the same boat. I just got the dsl40c and love it. The volume level is nice but I would like it to push more air. There is a guy in town that is telling me that pluging into a cab would be a waste of the combo speaker and though I would love to use the combo speaker in combination with a 16 ohm 12 cab making the amp a 2x12. But from what ive read do I not want to mix open and closed speakers? Im not opposed to buying an entire 4x12 cab but my intention is to still have the convenience of a grab and go amp but also have the option to increase the volume of air if need be with a cab. My next comment im sure is blasphemous but I mainly play the clean channel with no gain but I was really hoping to beef this up a bit.
  20. JEB
    JEB Active Member
    Sep 16, 2013
    101
    77
    West Virginia
    I had mine setting on a (I think) 1965a 4x10 and the dimensions seemed to fit perfect.
    Also sounded outstanding as I could run both the cab (16 ohms) and the internal combo speaker.
    Jon C likes this.
