Anyone Running An Eq Through Their Fx Loop?
Discussion in 'Marshall Amps' started by Kutt, Jul 25, 2018.
  1. Kutt
    Kutt Well-Known Member
    May 27, 2010
    982
    1,229
    Massachusetts, USA
    Noticed an uptick in chatter here and there about running EQ pedals through FX loops on amps. This is something I've never tried but I'm going to.
    If you're doing this, what's your EQ of choice, and on what amp?
    *Feels like more of an amp question than a pedal question, so I'm posting in the amp section. Please move the thread if I have judged in error.
  2. xeizo
    xeizo Member
    Dec 2, 2017
    82
    60
    Stockholm, Sweden
    I haven't, but I will try this tomorrow with my DSL20HR at rehearsal. Just received my Boss GE-7 :) I guess I will run my other pedals in front, but the EQ seems smart to run in the loop.
    Kutt likes this.
  3. Ufoscorpion
    Ufoscorpion Well-Known Member
    May 4, 2013
    1,736
    1,473
    Yes , if it’s got a loop then it gets a boss GE7 stuck in it .
  4. LRT#1
    LRT#1 Well-Known Member
    948
    1,396
    Yes I've recently started using a older boss ge7 through effects loop and have been impressed I've been able to get a closer sound out of my jcm900 fo the dsl what I don't know is what other pedals can be run through effects loop in series with the ge7
  5. JimiRules
    JimiRules Well-Known Member
    Feb 24, 2010
    2,905
    2,852
    Back when I was in a 2 guitar band I ran a Boss GE7 in the loop to boost my volume when I needed to stand out for solos, fills, etc. The amp I was using at the time was a Carvin Legacy. I've since moved onto Marshalls and I'm the lone guitar player in my current band, so I haven't needed to boost my volume.
  6. tmingle
    tmingle Active Member
    Jan 24, 2008
    298
    242
    Mifflintown, Pa.
    I use an MXR 10 band in the loop of my 40C to tweak tone at lower volumes.
  7. LRT#1
    948
    1,396
    As you know a jcm900 doesn't start to get its tone and punch till about 6 or 7 on the volume so the eq alow me to mostly get there through effects loop ar lower wolume
  8. Micky
    Apr 29, 2010
    20,451
    16,710
    Vermont
    Doesn't everyone run their EQ pedal thru the loop?
    I use a GE-7
  9. Kutt
    May 27, 2010
    982
    1,229
    Massachusetts, USA
    Nice. At the moment that's the pedal I'm eyeballing. I like that it has Gain and Volume sliders to compensate as needed.
  10. jstich
    jstich Well-Known Member
    Dec 18, 2016
    436
    291
    Micky, I put my eq
    after my dirt box and gate, then into the front of the amp. Works great .
  11. tmingle
    Jan 24, 2008
    298
    242
    Mifflintown, Pa.
    Watch GC. I got mine used for $75. The frequencies are well selected.
  12. ampmadscientist
    14,969
    8,798
    MonstersOfTheMidway and Kutt like this.
  13. marshallmellowed
    Jun 26, 2009
    3,284
    3,479
  14. ricksconnected
    Sep 29, 2015
    13,388
    6,632
    everywhere you wanna be.
    yes yes yes
  15. Rockcity
    Rockcity Active Member
    May 24, 2012
    166
    94
    Tried thru 1987x. Pretty boring comparing to EQ direct to input jack
  16. BowerR64
    BowerR64 Well-Known Member
    Nov 23, 2014
    4,628
    2,549
    What about a sonic maximizer?
    Adrian R likes this.
  17. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,494
    865
    UK
    Yes I use a dbx 131s 31 band EQ in the loop of my JVM!
    I am a big fan of running an EQ in the loop. It is possible to transform the sound of an amp this way. I used to use internal mods (like the 2203 treble-peaker circuit) as part of my changes to make the JVM more 800-like, but for tonal changes, I find an EQ in the loop simpler and more effective!
    The 31 band EQ is completely over-the-top, but I got it because I wanted the high head room and a 1U rack unit. I boost frequencies in the 2-6kHz range and some around 500Hz for a convincing 800 sound. The dbx does give very fine control, and was not much more expensive than an MXR pedal!
    I'm not a big fan of the Boss GE7, and recently sold mine (I sometimes use an EQ infront of the amp as well for certain songs). I found a cheap "Caline" 10 band pedal (MXR10 Clone) works better, and is less noisy than the boss!
  18. matttornado
    matttornado Well-Known Member
    Mar 14, 2012
    978
    438
    I also use a GE7 in my fx loop with my new DSL 40CR. I use it for a le3ad boost but the problem I have i that the level control is so sensitive that it's hard for me to find the right level. I'm looking for something else with knobs! lol
  19. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,131
    864
    Saginaw MI
    TC Electronics G-Major & a Behringer Ultra graph.
    I use the G-Major EQ for taking some of the high end off the delay/reverb effects when they get too bright and I use it to really shape the tone instead of the knobs on the head.
    Why?
    I set my head EQ to noon (straight up). If a knob gets tweaked in transport or by an asshole, just set it back to 12 o'clock. No guessing where it was.
    The presets in the JVM don't get bumped.
    The Behringer...is set flat...but if I get to some place that really need serious tweaking that can't be sorted out on the head, those sliders are easier to move than reprogramming patches.
    If I was a pedal person...the MXR 10 band. The con is that it uses 18VDC power supply...No battery compartment. The MXR 6 band is junk. Don't buy it. Noisy and the frequencies I like to adjust aren't there...(I owned one).
    I am sure there are other good pedals...I haven't used them.
  20. Jethro Rocker
    7,348
    7,644
    I used to use a Boss GE7 but now run the one on my Zoom G3 multi. I use it with the Silver Jubilees ro get a boost for leads without addinh yet mire level to the front. It makes for a clean boost for volume.
    Also use it sometimes with other amps just ro give a different tone to it. Select it at will.
