Anyone Here Put The Bias Trim Pot On The Outer Back Of The Chassis?
Discussion in 'Building the Classics' started by Rick Lee, Feb 8, 2017.
  1. Rick Lee
    Rick Lee Active Member
    Jan 24, 2012
    468
    136
    AZ
    Will try to get a clip up soon, but it's not coming out of the headshell again for a little while. I want to log some hours on this amp before deciding if it needs to be modded to get to a lower voltage with the Variac switch. I'm not real happy with the headshell, an eBay score that was not well photographed or described. Might get another one.
  2. fusionbear
    fusionbear Member
    Oct 12, 2016
    58
    99
    Here is my JTM45/100 inspired build with the Bias pot in the back:
    May get a locking one later....
    4Horseman likes this.
  3. Gblev
    Gblev Active Member
    Nov 9, 2008
    480
    137
    Tampa, FL
    Here's what you need for the bias trim pot:
    https://www.tedweber.com/wp253l-slot
    EDIT: That's actually a pic for a 50k, but the link is for the 25k and it looks the same as the one in this pic. I believe these are locking and you need a screw driver to turn them. I'm actually getting ready to do this mod to my 2203.
    jensvonbustenskjol likes this.
  4. Big Mike
    Big Mike Member
    Nov 15, 2007
    58
    21
    Raider Nation - SFO Bay Area
    I like them facing the top of the chassis just to be safe. I don't believe those ones on the weber link are locking.
  5. myself80
    myself80 Active Member
    Apr 3, 2015
    269
    41
    Nassau, Long Island
    I mounted the bias pot on the back panel of my 50 watt build. I believe I got it from Weber, however it does have a locking cap on it. It works real nice. No problems with the bias. It is stubby and does not stick out far. Even the occasional bump will not turn the thing. The one thing that i noticed is that not matter how much I tighten the locking nut, the pot will still turn w/ a screwdriver. Not easily, but it will turn. I am glad I did it. I try different tubes a lot and like not taking the amp apart every time.
    Gblev likes this.
  6. Gblev
    Gblev Active Member
    Nov 9, 2008
    480
    137
    Tampa, FL
    They claim on their site they are. I used this one (25K) on the back of my amp and you can only turn it with a screwdriver. It is very smooth turning, and has the right amount of torque. It's hard to explain but it is very nice. This makes biasing so fast, simple, and much safer. Never again will I have to pull out my chassis to bias my amp, as I also added external bias test points.
    For those that are worried about it not locking, or maybe it getting bumped, you can always use a thicker nut on the outside so the screw adjustment is more in-set. But it doesn't stick out a whole lot to begin with.
  7. johnfv
    johnfv Well-Known Member
    Sep 29, 2010
    5,633
    4,193
    Austin TX
    Old story: Guitar player had a vintage JTM45 with the bias pot added on the back (a "normal" pot with a knob). Producer thinks it's a master volume and cranks it up. JTM45 smoked...
  8. Gblev
    Gblev Active Member
    Nov 9, 2008
    480
    137
    Tampa, FL
    I've heard this story so many times. Most producers/recording engineers ask the guitarist himself to adjust settings as needed. As we know most guitarist are sticklers about their amps, and tone. Not to mention, a lot of the finer adjustments that need to be made can be made at the board without having to adjust the amp. Besides, only an idiot would look to the back of an amp to make an EQ or volume adjustment.
  9. johnfv
    Sep 29, 2010
    5,633
    4,193
    Austin TX
    Not sure what stories others have heard, the one I mentioned I know the guitarist. I saw the amp many times and it did get repaired (I should've bought it when I had a chance). I met the producer but he passed away long ago. You do realize a lot of drugs got consumed in studios back in the day right? :)
  10. myself80
    Apr 3, 2015
    269
    41
    Nassau, Long Island
    jmp45 likes this.
  11. Gunner64
    Nov 16, 2013
    5,460
    6,597
    Midwest, USA
    Mount it on top of the chassis so its behind the back panel...no issues. The back needs to come off to retube anyway so I don't know whats gained by having it on the back faceplate as opposed to the top of the chassis.
  12. Gblev
    Gblev Active Member
    Nov 9, 2008
    480
    137
    Tampa, FL
    I meant no disrespect, maybe it was the incident you witnessed that has become folklore. But I have heard this same exact story many times in various forms.
    As far as the drug thing, oh yeah, I know it. There was a lot of remixing going on the following day at many studios!;)
    johnfv likes this.
