Anyone Here Car Mechanically Inclined?
Discussion in 'The Backstage' started by Barfly, Jan 11, 2019.
  1. Barfly
    Barfly Well-Known Member
    May 6, 2012
    1,352
    1,322
    NYC, NY
    One of my older cars sometimes acts like the car battery is dead. Occasionally I turn the key and I hear 1 click. If I turn the key rapidly 6 or 7 times it starts. Lights and dummy lights look strong... old battery was doing the same ( I just replaced w/ new batt)
    Mechanic's are useless so far.. I understand. They say. if it starts when we do it we can't be certain of the cause.. Thoughts???
  2. Vinsanitizer
    Vinsanitizer Hi. I'm new here. VIP Member
    Oct 19, 2012
    25,144
    17,212
    Sorry Barfly, I'm in IT. Not Auto mechanics. :shrug:
  3. Micky
    Apr 29, 2010
    19,638
    15,471
    Vermont
    Sticky starter solenoid...
  4. Gunner64
    Gunner64 Well-Known Member
    Nov 16, 2013
    4,015
    3,923
    Midwest, USA
    My old Cherokee did that. The Battery termials needed a clean and tightening.
  5. pedecamp
    11,745
    6,690
    Make sure your battery wires are snugged tight, check both ends. Alternator possibly going bad. Could be your starter has a bad spot. Im no mechanic so dont listen to me....
    Barfly and Jethro Rocker like this.
  6. Dogs of Doom
    17,205
    15,125
    yeah, pretty much the chain to inspect:
    battery/cables
    starter
    solenoid
    voltage regulator
    alternator
    How old a car? The one thing that voids out everything is the computer. A computer can cause that as well.
    jimmyjames and Barfly like this.
  7. Barfly
    May 6, 2012
    1,352
    1,322
    NYC, NY
    Hahahah I love it.. !!!
    pedecamp likes this.
  8. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    557
    1,134
    what is year and model ?? i can give an ignition /key knowledge on that being an Auto Locksmith, you have the correct signal path up above posted to start diagnosing..just curious if you have a model with a known ignition switch issue
    Barfly likes this.
  9. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    What car is it?
    Battery cables: the connectors on the battery terminals, the terminals that connect to the starter can corrode.
    The starter relay can wear out.
    And you are correct:
    most mechanics don't know shit about troubleshooting electrical. Most of them are total idiots when it comes to electricity.
    They guess, they replace parts randomly, and charge you up the ass.
    Most of them could not use a volt meter, ohm meter or current meter, they haven't got even a clue how to use test equipment.
    Most of these guys could not pass electrical 101.
    Barfly and AMPPILOT like this.
  10. Barfly
    May 6, 2012
    1,352
    1,322
    NYC, NY
    Its a 2006 Saturn Vue. I have a new alternator and battery. Brand new. I just know from life experience.. probably Starter.. but mechanics were unsure of anything and I am not a young musician.. lol. I can pay! I have a 2019 I bought a couple of months back but I don't want to drive it to work because I am in a Sanitation garage. All kinds of bumps and bruises happen every other day to my other cars
    The lights are all bright as hell so that makes my non mechanically inclined mind think the alternator is charging the batt.
    ibmorjamn likes this.
  11. Barfly
    May 6, 2012
    1,352
    1,322
    NYC, NY
    Dude!!! Hahaha You cannot do this to me when I am bombed and my wife is next to me watching netflix... ahahahahhahhaha Dog house!
    Vinsanitizer likes this.
  12. ibmorjamn
    ibmorjamn Well-Known Member
    Nov 3, 2012
    6,095
    3,206
    North
    More than likely the starter. What vehicle and year ?
    If it were the battery a new one should have fixed it . Old starters get worn out and the bendix will no longer function
    ingaging the pinion gear. The old trick was to bang on the side of starter to get it to go. Not a fix just a temporary thing.
    If in fact the alternator is bad it will not charge the battery. Easy check with a ohm meter. Check voltage before you start. Should be a bit above 12 V running around 14.8 V with the lights on.
    If the battery was always low or the starter is bad the worst thing is it could wear out a spot on the ring gear. (Not a easy fix)
  13. Trumpet Rider
    Trumpet Rider Well-Known Member
    Nov 8, 2016
    1,330
    1,863
    New alternator and battery pretty much eliminate the alternator and battery. The strong light reinforce that, although, lights don't take as much juice as pushing that motor over. I have seen weak batteries that light up the lights just fine but don't spin the starter.
    I am thinking starter or switch, but I would still clean up the battery terminals before doing anything else. That is easy and costs nothing. If you still have the problem then I would look at the switch next. Go from easiest to hardest and hope it's something easy. A little contact cleaner sprayed into the switch might be all it needs. I guess around here I better recommend Deoxit. :)
  14. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    Probably the starter relay, or the connections to the starter are corroded.
  15. mickeydg5
    18,969
    7,035
    Given what you said if it aint the battery it is most likely the starter. If your clicken the battery and relay aint sticken. Ah, I do not know anything.
    Although, I have not had a starter go bad since my 1978 Ford. But :shrug:.
  16. ampmadscientist
    10,366
    4,595
    Whereabouts Unknown
    The starter (could) contain a solenoid and when the solenoid contacts fry out, the power does not reach the motor.
    Key switch> starter relay> Solenoid> motor
  17. Dogs of Doom
    17,205
    15,125
    as bft said up above, it could also be an ignition thing...
  18. Gutch220
    Gutch220 Active Member
    Feb 19, 2018
    346
    155
    NJ
    yea, start from the switch, relay, and work back to the solenoid/motor assembly. luckily none of these things are expensive.
  19. LRT#1
    LRT#1 Well-Known Member
    567
    642
    If it clicked it tells me that ignition is ok. Cant say for the ECU but I'd say it's fine.
    Like everyone has said check connections including at starter.
    My guess is the solenoid isn't moving the armature far enough to engage the contacts. If it happens and there is another person around try tapping the starter with a hammer. That's if you can. As the starter is being tapped hold ignition in star position. If car starts then replace starter and you should be fine.
    Good luck
  20. Jon C
    Jon C Well-Known Member
    May 29, 2017
    544
    783
    Solenoid/Bendix …… smack it with a wrench …… see if it spins out
