Anybody use Code as interface to record with mic?
Discussion in 'Marshall Amps' started by Msharky67, Feb 22, 2020.
  1. Msharky67
    Msharky67 Well-Known Member
    Mar 12, 2012
    952
    615
    Queensbury ,NY
    I was wondering if anybody uses there Code amp to record with? Wouldn't you be able to run a mic in the input and set up a clean or neutral patch and then to the PC? Then maybe add effects to in the amp through the amp? Is this a good way and does it work well? Just a thought!
  2. ampmadscientist
    17,851
    11,887
    You are saying that you want to use it as an A to D converter, then record the digital output?
