Any Work Around For Dsl40cr And 91016 Footswitch?
Discussion in 'Marshall Amps' started by lovehifi, Jul 14, 2018.
  1. lovehifi
    lovehifi Active Member
    Jun 4, 2014
    194
    121
    Bought a new DSL40CR and 91016 footswitch. Amp is great but using it with the 6 position footswitch not so great. Seems to work fine when I first turn it on but if I press #3 or #6 the footswitch lights turn off and it becomes nonfunctional unless I turn the amp off and back on. I also tried a different cable and still no luck. The OEM footswitch seems to work except when plugged in I can not switch channels on the amp but only on the footswitch. Maybe that is normal?
  2. Snowdogyyz
    Snowdogyyz Member
    Feb 19, 2018
    64
    66
    Sounds like a dud. My 91016 works perfect. Do either your amp or switch is defective!
  3. lovehifi
    Jun 4, 2014
    194
    121
    Maybe its the footswitch. It was bought as a demo from Sweetwater. Hope its not the amp. I can get the amp swapped too but what a hassle.
  4. lovehifi
    Jun 4, 2014
    194
    121
    Noticed that the 91016 foot switch works perfectly when in standby but as soon as I try using it with power on in 20w or 40w mode it fails when selecting Master Volume or FX loop on the footswitch. Sometimes when just trying to change channels via the FS. Strange since the OEM foot switch works fine.
  5. cvansickle
    cvansickle Member
    Jun 20, 2018
    32
    28
    I'm not having any luck with MIDI. I can plug a MIDI controller into the DSL40CR's MIDI jack, and the straight 1-4 program changes will change the amp channels perfectly, and of course repeat every four digits. But I'm trying to go further. I want to use a MIDI Solutions Event Processor to map multiple program changes from the controller to one of the four that the Marshall will accept, but apparently the Marshall's inner circuitry isn't sophisticated enough to handle it.
  6. oldmanrockin
    oldmanrockin Member
    Feb 22, 2017
    78
    39
    When the foot switch is plugged in, you can't change channels with the amp, only with the footswitch. I have 3 different dsls and and they all seem to work this way.
