Another Restoration Candidate...
Discussion in 'Let's Talk Vintage' started by pleximaster, Feb 12, 2017.
  1. pleximaster
    pleximaster Well-Known Member
    Feb 6, 2012
    1,248
    1,138
    This amp was totally modded by a notorious Swedish modder with 4 channels, effect loop and footswitch in the 3 of the 4 hole inputs. Above each pot there were two additional minipots drilled through the front. The board did not contain much original parts but above all it was drilled beyond repair.
    I have "cleaned" out the amp, replaced the preamp sockets as two were replaced and one bad. Thanks to Rikard I got a set of vintage potentiometers as these were replaced. And our all favourite Neikeel is providing me with a original board!!!! :)
    The transformers wergeld but I changed the MT out for a rewound one since I have another amp that was in presitine condition except the MT. I switched them around.... :)
    Will be a cool player
    plexi
  2. tomsvintage
    tomsvintage Active Member
    Jun 11, 2012
    538
    232
    JTM45 Headquarters
    Restomaster is at it again !!!!:agreed::applause::dude::hbang::wave::woot:
  3. troyvod
    troyvod New Member
    Jan 18, 2016
    23
    2
    newcastle
    imagine how much it cost to originally mod it to that extent! Would've been cheaper to buy another amp!
  4. pleximaster
    Feb 6, 2012
    1,248
    1,138
    No fun! :) And I have other amps... :) :) :)
    plexi
  5. coldengray
    coldengray Active Member VIP Member
    May 19, 2011
    404
    180
    I can't wait to see this come together...subscribed!
  6. pleximaster
    Feb 6, 2012
    1,248
    1,138
    tomsvintage likes this.
  7. troyvod
    troyvod New Member
    Jan 18, 2016
    23
    2
    newcastle
    i was more implying the original owner who had the amp modded. I understand why you are restoring it.
    pleximaster likes this.
  8. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,137
    724
    Södertälje, Sweden
    ..yeah, i always wondered why people keep sending him their amps. .there's always a few amps moded by him at the sale site "blocket" and it doesn't seem like the mods really add to the perceived value of the amps...?...
    j
  9. pleximaster
    Feb 6, 2012
    1,248
    1,138
    Some update...
    plexi
    v846, tomsvintage, liontato and 2 others like this.
  10. Kris Ford
    Kris Ford Well-Known Member
    Jan 3, 2015
    1,050
    743
    Detroit FTW
    NICE!!
  11. MarshallDog
    MarshallDog Well-Known Member
    Nov 28, 2010
    7,547
    4,468
    Taintville
    Thats one hell of a good job man! Looks awesome!!!! Cant wait to see it in a cab and all complete. Where did you get the face plate?
  12. neikeel
    2,184
    938
    Looking good!
    Are you going to try your hand at hand-lacing the loom now?
    How does it sound?
  13. pleximaster
    Feb 6, 2012
    1,248
    1,138
    Yes I will but I seem to have lost the lacing wire I got! :) I´ve been moving parts around and this thin cord are somewhere among the those thinks, probably in a good place where I won´t misplace it... :) :) :)
    It sounds great But I´ll have some tweaking to do I think...
    plexi
  14. pleximaster
    Feb 6, 2012
    1,248
    1,138
    eBay
    It is ok but not 100% font wise when compared to the original. It is also printed slightly off centered and all text and stuff should have been a bit more to the right, to be right.
    plexi
  15. Kris Ford
    Jan 3, 2015
    1,050
    743
    Detroit FTW
    Plexi Palace? That's were I got my JMP plate
  16. pleximaster
    Feb 6, 2012
    1,248
    1,138
    It originates from music ground just like Vic's...
    Music Ground sells stuff on uk eBay under londonvintage
    Plexi
    Kris Ford likes this.
  17. MarshallDog
    Nov 28, 2010
    7,547
    4,468
    Taintville
    Not sure where you are located but MojoTone makes some real nice high quality faceplates and they are rather low cost. Check them out...here is the link, I have used them and the QC is excellent.
    http://www.mojotone.com/Laser-Engraving
  18. clutch71
    clutch71 Well-Known Member
    Sep 26, 2007
    1,374
    730
    Columbus, Ohio
    What no hair or mold? This one is barely a challenge!
    All things being equal though...I'll sit back and watch your progress...like I always do.
  19. pleximaster
    Feb 6, 2012
    1,248
    1,138
    F@ck I said it was a bit off centered printed. More that a tad too much... :( :( :(
    plexi
  20. Marshallhead
    Marshallhead Well-Known Member
    Jun 3, 2009
    1,367
    530
    It's not printed off centre - it's just the wrong type of faceplate for your chassis.
    You need a JTM45 MKII faceplate - the JTM black flag and JMP faceplate amps have all the holes for the hardware punched a little more to the right of the chassis.
    If you compare your chassis to Neil's from the PP thread, you'll see for instance that your toggle switches are closer to the chassis end block, and your input Jack's correspondingly further away than his. It's only a few mm but enough to make a difference.
