Another 2204 Build
Discussion in 'Building the Classics' started by Matt_Krush, Oct 26, 2019.
  1. neikeel
    3,651
    2,075
    I see you used 0.047uF couplers early in the preamp. Did you use those in the PI too. Think of a smaller capacitor as a smaller diameter hose, so the smallest caps in the signal change are limiters to your signal bandwidth...............
  2. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,126
    860
    Saginaw MI
    ^^^ Yep, that's next...I just had the 2 in my stash and didn't want to parallel another set of .022uf
  3. South Park
    1,220
    920
    The smaller the coupler cap the more signal gets thru. A little more gain.
  4. neikeel
    3,651
    2,075
    Oh, rully? Do explain:agreed:
    Guitar-Rocker likes this.
  5. Exojam
    Exojam Well-Known Member
    May 31, 2017
    617
    395
    So this is what you are getting for your tone stack?
  6. Exojam
    May 31, 2017
    617
    395
    Having never modded a tone stack, what would you not something more like this one? Mine on top and yours on the bottom.
    Or am I thinking to much like wanting the output of a subwoofer; being a more flat response?
  7. South Park
    1,220
    920
    The graph is the frequency that gets thru the circuit . It is a old gain mod the smaller you go on coupler caps the easer the signal gets thru the cap. Less resistance
  8. Exojam
    May 31, 2017
    617
    395
    I understand what it is and what it does, I have a feeling you did not understand what I was asking Matt.
  9. Matt_Krush
    Dec 14, 2015
    1,126
    860
    Saginaw MI
    @Exojam.
    Yes the 1st graph above is what I went for. I used that calculator.
    I was intentionally trying to bring the mids down and get a wider range of control...and shift the control frequency for mids.
    Exojam likes this.
  10. Exojam
    May 31, 2017
    617
    395
    Thank you very much for explaining why you went in that direction for your tone.
  11. South Park
    1,220
    920
    The tone shaping is done a little bit along the whole preamp circuit. Not just in the tone stack. The pick up produces a lot of mids to start with.the stock Marshall tone stack takes that into account. It can alter the gain to
  12. ampmadscientist
    14,840
    8,705
    Sag happens because the voltage of the power supply filter cap is loaded (for a period of time) and then the voltage starts to drop because it has used up the available current.
    The voltage drops down, that's when sag happens.
    As the guitar note decays, the available voltage charges the filter cap back up again.
    A larger choke does not increase the available current.
    The available current remains about the same, but the resistance of the choke will only drop more voltage, not increase available voltage (it's not a magic thing that makes more voltage)
    Exojam likes this.
  13. junk notes
    junk notes Active Member
    Dec 10, 2018
    206
    190
    Chokes more or less affect feel. Has some play on tone.
  14. Matt_Krush
    Dec 14, 2015
    1,126
    860
    Saginaw MI
    Almost complete.
    Just need to add the shielding for the head shell...
    A couple more 'check-overs'
    some tube rolling...
    make the rear screen...
    And it'll be ready for full use.
    even though its no longer a Marshall, I kept some of the Marshall styling so it still well on a Marshall Cab..
    Head came out pretty good...I need a pneumatic stapler for the piping (it isn't Marshall tight in the corners...but what the hell, looks good from a distance)
  15. ampmadscientist
    14,840
    8,705
    (south park said)
    "The smaller the coupler cap the more signal gets thru. A little more gain."
    Smaller in size, or smaller in uF?
    And if I use a little tiny itty bitty micro mini cap I will get mega monster gain?
    Exojam and neikeel like this.
  16. proxy
    proxy Active Member
    Sep 2, 2010
    529
    189
    Sounds great Matt
  17. Exojam
    May 31, 2017
    617
    395
    Matt,
    Would you be so kind as to tell me what chassis and front/rear panels you are using?
    Thanks, James
  18. Matt_Krush
    Dec 14, 2015
    1,126
    860
    Saginaw MI
  19. Exojam
    May 31, 2017
    617
    395
    Thank you very much!
