Another 2204 Build
Discussion in 'Building the Classics' started by Matt_Krush, Oct 26, 2019.
  1. Matt_Krush
    Matt_Krush Well-Known Member
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Well, my first JCM 2204 build, there are many like it, but this one is mine.
    It started as all stock then, well, you know how that goes...
    Deviations from Stock.
    1) 1st pair of Power Capacitors are 100uf (not 50uf)
    2) Added MojoTone Effects Loop
    3) Modified Tone Stack (see Pics Below)
    4) Added 120VAC Receptacle on back to power other crap
    5) Switchable Bright cap (on/off), Negative Feedback Resistance (100k or 200k), and V1b Cathode (10k to 5k)
    6) DSL 100W Power Transformer (in case I added other stages and needed the current)
    7) External Bias point and control, with capability to run EL34, 6L6, 6550, KT88 variants.
    Tone Stack Mod
    GuitarIV likes this.
  2. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Circuit Board
    Other Guts
  3. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Panel/Top
  4. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Some Sounds if your interested..
    Cell Phone recording
    Gibson Studio, Dimarzio Super Distortion Pick Up
    1960B Cabinet.
    No other gear...
    nkd, tce63, GuitarIV and 2 others like this.
  5. Joey Stockton
    Joey Stockton New Member
    Mar 12, 2018
    21
    15
    Tulsa, OK
    That thing is a beast! Tasteful mods and well executed. What effect does the increased filtering have on the tone?
    tce63 likes this.
  6. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Little no 'sag' when pushing really hard/loud.
    which for my type of music is what I want.
    tce63 likes this.
  7. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    well, I couldn't leave well enough alone.
    Is it just me...or is really hard to put the soldering iron away and quit tinkering?
    Plate resistor for V1b: 220k from 100k
    Coupling caps 1st 2 stages: .047 from .022
    Removed Bright cap switch (no longer needed and that pot was acting flaky)
    Think I am done now (other than a head-shell and I guess a name)...really tamed the harshness, EQ more responsive, smooth distortion.
    I don't think an overdrive pedal is needed...LOL
    Ignore the white board mess..it was for a 4 channel preamp I built...
    tce63 likes this.
  8. Exojam
    Exojam Well-Known Member
    May 31, 2017
    617
    395
    Looks very nice!
    I have to say I love the work bench and also that white board you have.
    I am trying to get the inside of my shed/workshop finished up and that gives me a few ideas.
    How long did it take you to bust it out?
    tce63 likes this.
  9. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Total Time...I don't know...started a month or two ago, get a couple nights...then it'd be a week or two before getting back at it.
    Which sucks, because I'm the guy that doesn't keep good notes...all in my head (until it isn't).
    I'd say it should be doable 5 days, 3 hrs at a time...
    The bench...it was a mess...whenever I do a just because build, it seems like a guitar or my gig rig has something crap out, then I get multiple projects scattered on the bench and parts all over. Scope and signal generator are in the left corner, and yes they are an indispensable tool for amp building.
  10. Exojam
    May 31, 2017
    617
    395
    Like it!
    My 2204 clone took me awhile longer as it was my first build but it came out nice and love the sound of it.
    I just put the SIR #34 mod in it but I cannot stand the sound of it so it is coming out as soon I get some time to remove it.
    Correction: mine was a 50 watt clone build not a 2204.
  11. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    I am not familiar with the SIR #34 Mod...what I could find...looks like adding a .1uf cap in parallel to the 10k cathode resistor of the second stage?
    I experimented with a variety of caps there as well, but it sounded best (to me) without any filtering.
    I can say, with the changes i have made, I like I am getting!!
    I realize it may not be for most people, but it can be dialed back to the classic tones pretty easily.
  12. Amadeus91
    Amadeus91 Active Member
    Apr 9, 2019
    115
    159
    Great job, tailoring the amp to get what you want from it.
    What a rhythm chugging riff machine!!!!!
  13. South Park
    1,229
    925
    Some mods work some don’t. Minor gain mods I think work best
  14. Exojam
    May 31, 2017
    617
    395
    This was some information I had sent over to another member about it.
    These were the changes I found that make this change:
    The SIR #34 mod is pretty simple, IIRC -- according to my notes, it's a standard JCM800 with a
    470p cap across the V1b plate resistor, a
    100n cap across the V1b cathode resistor, and a
    680n cap across the V2a cathode resistor.
    What I found interesting is I also found other instructions for the #34 here on this forum that are as follows:
    .1uF over 10K cathode of the 2nd stage
    470 pf across the 100k plate resistor of the 1st stage (at least 500V cap)
    820 cathode resistor changed to 1k
    .47 over this 1k
    .68 on the presence
    150K resistor from the wiper of the gain pot to ground
    1n bright cap
  15. gldtp99
    gldtp99 Active Member
    Nov 29, 2010
    341
    184
    Arlington, Texas
    Nice job !!
    Here's a 2204 type build I did last year---- I also doubled the value of the first filtering stage filter caps---- also some moderate preamp gain mods and a fixed Resonance mod in the NFB loop.
    I used a higher mA/lower voltage rated Edcor PT and a stock type OT.
    My friend made this vid ---- he plays a modern Hi Gain style called Grindcore in his band so some of his playing style comes through even though he tried to make a Classic Rock/General Purpose type of vid.
    You can see how the EQ and other knobs are set in the vid:
  16. Exojam
    May 31, 2017
    617
    395
    Can you PM me the mods you made?
  17. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    Modded Pre-amp Schematic:
    C3 & C7: .047uf from .022uf
    R7: 220k from 100k
    R6.2: 10k switched on/off via the master volume push/pull pot
    C10: 250pf from 500pf
    R15: 47k from 33k
    C12: .047uf from .022uf
    Negative feed back select-able between 100k & 200k via treble push/pull pot
    Only other Mods is the MojoTone effetcs Loop.
    Oh and 100uf+100uf for the fist set of power capacitors.
  18. Exojam
    May 31, 2017
    617
    395
    Thank you!
  19. South Park
    1,229
    925
    A larger choke will lessen the voltage sag to
  20. Matt_Krush
    Dec 14, 2015
    1,127
    861
    Saginaw MI
    I almost went with the jubilee tone stack.
    Next time...I will, and it'll likely be a lunchbox 20-30watter.
