Amp Stands
Discussion in 'Cabinets & Speakers' started by Emtbreid, Aug 19, 2019.
  1. Emtbreid
    Emtbreid Well-Known Member
    Oct 22, 2018
    583
    608
    East Coast, USA
    Couldn’t really think of a more appropriate section for this....
    For those who use combos, how many here use amp stands? I have a 40 watt combo and started out with the amp on the floor, when someone recommended grabbing a stand. I’ve used it for a few months now but I’m not quite sure how I feel about it. I understand the reasoning Benin’s using one (pointing the sound more towards your head and dispersing the sound through the room a bit easier). Just curious who else uses them, or if you don’t use one, why?
    netlocal and SkyMonkey like this.
  2. ampmadscientist
    14,845
    8,710
    When you raise the speaker above the floor, you lose the low frequency.
  3. anitoli
    anitoli Well-Known Member
    7,003
    8,009
    Play a real amp, a 100w half stack, and you will not need to contemplate this again.
    Frodebro and Crikey like this.
  4. JeffMcLeod
    JeffMcLeod Well-Known Member
    Sep 28, 2017
    1,357
    1,869
    Makes all the difference in the world. Use an amp stand.
    :hbang:
    netlocal and Kookaburra like this.
  5. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    I get what you’re saying but for now my “real” 40 watt tube combo is all I can afford. A 100 watt head doesn’t make much sense for me to have in the little room I play in.
    netlocal, CraigP and Filipe Soares like this.
  6. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    That’s what I’ve seen. It sounds a lot more trebly off the floor, and generally not good. I’ve had it on the stand for 5-6 months, but I’m in the process of taking it down and redoing everything to try on the floor again.
  7. anitoli
    7,003
    8,009
    Sure it does. It's looking forward. If you pursue music you will need a bigger amp eventually so get it done and enjoy the headroom.
  8. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    It’d be nice no doubt, but not anytime soon I’m afraid.
  9. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    I’m liking what I’m hearing being back on the floor so far. This is also a pretty small room I’m in, so not sure how much a stand would matter...
  10. Kostas
    Kostas Member
    Apr 1, 2009
    70
    48
    Athens, GR
    Any speaker should be at ear height. With studio/HiFi speakers the tweeter is the one that should be in ear height. The lower a speaker is, the more you will raise the volume to hear it. We are listening with our ears, not our legs. I don't have a combo but I would raise it even if I'd lose some low frequences. I have a half stack and the cab is raised.
    netlocal likes this.
  11. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    That’s what I initially thought... but recently it just didn’t sound right to me. Almost muddy sounding despite Eq tweaking.
  12. MarshallDog
    Nov 28, 2010
    12,565
    12,214
    Taintville
    I play mainly combos now and never lift them up. If I cant hear it I just turn it up more.
    harleytech likes this.
  13. pedecamp
    13,623
    9,919
    What do you have the DSL40? Consider getting an extension cab the same size as the amp preferably a closed back, not only will it look cool it will raise your amp off the floor while maintaining your lows, and no more bending over to get to your knobs for adjustments, you'll have a fuller sound.
    I think stands kill your sound, I had an AC15 combo I used to put on a milk crate for easy reach of the knobs, it sounded better on the floor. Also built a custom 1x12 cab with a collapsible stand built into it, it never sounded as good as the cab being on the floor.
  14. SkyMonkey
    1,390
    1,531
    England
    @pedecamp has it right. I have used a Marshall 1912 1x12 cab under my combos for years. This is the best of both worlds, the sound just gets richer with more speakers. My 1912 is matched to a VS65R at the moment and I am saving for a larger 1x12 for my DSL40CR (bit precarious with the smallish 1912). You may get a good deal on a second hand 1x12 cab, and from there you can start to experiment with different replacement speaker combinations.
    KraftyBob, Emtbreid and pedecamp like this.
  15. Alter
    Alter Active Member
    Jan 29, 2019
    108
    186
    I only use them for small 15 watt or solid state combos, because you need to work on positioning the amp just right, tilt and all, to hear yourself adequately on a gig. When its a bigger tube amp it's the floor or i might use a chair or something similar that they have on the gig.
    The sound changes of course, the less contact the amp has with something the less bass you'll have.
    Emtbreid likes this.
  16. pedecamp
    13,623
    9,919
    The amp has to be coupled to the floor to get the best tone, maybe a tilt back stand would be better?
    Jethro Rocker and Emtbreid like this.
  17. BftGibson
    BftGibson Well-Known Member
    May 28, 2018
    1,293
    3,236
    might seem ..well a stack freak..BUT...the tilt back legs on my fender's radically changed things recently...the sound is where i need it ..not over at my neighbors house....the floor level is way down at practice ..in a contained room...what a dif ..my stacks are parked..might dump em...for more Supers Optimized-southload1 (2).jpg
  18. BftGibson
    May 28, 2018
    1,293
    3,236
  19. Emtbreid
    Oct 22, 2018
    583
    608
    East Coast, USA
    Yeah, it does sound a LOT better down here. It’s a DSL401, Jcm2k. I’d like to get some kind of cab for it, be it a 1x12 or a 2x12. I rearranged it all last night and moved it permanently to the floor... big difference.
    pedecamp likes this.
  20. KraftyBob
    KraftyBob Well-Known Member
    Sep 5, 2017
    1,146
    1,374
    Chicago Suburbs - USA
    I have the DSL40C and used an amp stand for a while but felt it lacked bottom end. Eventually I put it on top of a 1x12 closed back and now I have a speaker that's higher up and one on the floor for the bottom end, plus the controls are much easier to see/use.
    Emtbreid, pedecamp and BftGibson like this.
