Amp Build: Ceriatone Kraken 50
Discussion in 'Building the Classics' started by FourT6and2, Jun 25, 2017.
  1. FourT6and2
    FourT6and2 Active Member
    Dec 3, 2010
    229
    73
    From ValveWizard
    neikeel likes this.
  2. FourT6and2
    Dec 3, 2010
    229
    73
    It's time for everybody's favorite part of building an amp—heaters!
    JK, it's the worst.
    Decided to run DC on V1 and V2; regular AC on V3-V6.
  3. jensvonbustenskjol
    Feb 5, 2012
    526
    175
    Norway
  4. neikeel
    1,967
    804
    Looking great, but I only see 3 preamp and 2 power valves - where is V6?
  5. FourT6and2
    Dec 3, 2010
    229
    73
    It's a ghost valve
    neikeel likes this.
  6. maxxi
    maxxi Active Member
    Oct 9, 2011
    414
    181
    belgium
    very clean work :agreed:
  7. FourT6and2
    Dec 3, 2010
    229
    73
    More progress today. Finished up the power section and did the power tube sockets, bias test points, impedance switch, and a few other things here and there.
    jensvonbustenskjol and Ghostman like this.
  8. Ghostman
    Ghostman Well-Known Member
    Jan 29, 2012
    8,292
    8,072
    Sosnovsky, Kyrgyzstan
    That is one clean looking build. Pure circuit porn. Nicely done.
    jensvonbustenskjol likes this.
  9. FourT6and2
    Dec 3, 2010
    229
    73
    A bit more today. Having routed a bunch of stuff now, I'm making some notes about how to do it better the next time around. And by better, I mean more OCD lol.
  10. FourT6and2
    Dec 3, 2010
    229
    73
    Preamp tubes all done. In the home stretch now.
  11. FourT6and2
    Dec 3, 2010
    229
    73
    All done!
    Just doing some testing now. I'm using a 47K 5W pot wired as a variable dropping resistor. This way, I just clip it to the filter cap and I can tune all the voltages in the amp. Typical value is 10K. I set it to 18K, which is what the Yeti uses (higher voltages). And my B+ is a whopping 515vdc! That's without power tubes though. Once I stick some in, it'll probably come down a bit. I don't really have a set goal in mind. But I'll play it with a few of the resistor values I have on hand and figure out which one to use.
    I also got some new Tefzel hookup wire in some fancy colors for the next build. And I'm going to try to make the lead dress a little better next time around. I wanted to get this one done so I can start testing a few things first, tone wise.
    Current voltages with no power tubes and 18K dropping resistor:
    MAINS: 124.4VAC
    AC FILAMENTS: 3.47VAC
    DC FILAMENTS: 6.09VDC
    BIAS/PI SPLITTERS: -50 to -36VDC
    PT SECONDARY: 375VAC
    V1:
    1: 151VDC
    2: SIGNAL
    3: 1.47VDC
    4: FILAMENT
    5: FILAMENT
    6: 274VDC
    7: SIGNAL
    8: 2.47VDC
    9: FILAMENT
    V2:
    1: 226.1VDC
    2: SIGNAL
    3: 1.26VDC
    4: FILAMENT
    5: FILAMENT
    6: 381.5VDC
    7: 226.1
    8: 228VDC
    9: FILAMENT
    V3:
    1: 257.3VDC
    2: 26.2VDC
    3: 42.24VDC
    4: FILAMENT
    5: FILAMENT
    6: 245.2VDC
    7: 27.6VDC
    8: 42.24VDC
    9: FILAMENT
    V4/V5:
    1: 0
    2: FILAMENT
    3: 511VDC - 515VDC
    4: 509VDC
    5: -50VDC
    6: 509VDC
    7: FILAMENT
    8: 0
    B+: 515VDC
    SECOND CAP AFTER DROPPER (18K): 381VDC
    BOARD CAP AFTER DROPPER: 366.8VDC
    V1a: 151.7VDC
    V1b: 274VDC
    johnfv, wakjob and jensvonbustenskjol like this.
  12. wakjob
    wakjob Well-Known Member
    Dec 29, 2011
    4,345
    2,553
    C-137
    Man, that turned out great.
    Can't wait to hear your thoughts after final tuning.
    What kind of wire is that, and where did you get it?
    I'm fixing to redo my 5e3 with a turret-board and some mods, and I don't think I'm gonna use the original cloth covered wire this time.
  13. FourT6and2
    Dec 3, 2010
    229
    73
    Here's a clip. This is with a 10K dropping resistor. Probably my favorite value so far. The volume is as loud as I can get it without clipping the mic on my laptop, sorry lol. I'm working to upload the other clips with different voltages too. But it takes a long time for YT to process 'em. I'm still toying with a few parts here and there.
    Geeze, Ghostman, wakjob and 1 other person like this.
  14. jensvonbustenskjol
    Feb 5, 2012
    526
    175
    Norway
    Nice tone!
    Black dog is such a rich song. Nailed very well :)
  15. FourT6and2
    Dec 3, 2010
    229
    73
    I just love that rhythm riff lol. I always use it to test an amp, even high-gain ones.
  16. FourT6and2
    Dec 3, 2010
    229
    73
    Some cleans-ish
  17. Marshee
    Marshee New Member
    Sep 10, 2017
    7
    I'm amazed
  18. ampmadscientist
    5,750
    2,124
    If you change the filament wire layout....there is no need for DC heaters.
    It is possible to get 100% of the noise out by re- positioning the filament wires.
    B+ voltage:
    Means nothing with the tubes out. There is no load on the power supply.
    The more the supply is loaded: the lower the voltage will drop.
    Bias setting: will literally control the B+ voltage.
    The hotter the bias is...the lower the B+ will drop.....because the B+ is loaded more.
  19. Copperheadroads
    Copperheadroads Member
    Oct 6, 2012
    99
    26
    On a Rock in the North Atlantic
    Very neat work , wow .
    One thing i would do in the future builds would be if possible ,to have the values that are printed on the the components facing up as it will make troubleshooting easier .
