Advice on haze 40 verses origin verses dsl
Discussion in 'Marshall Amps' started by tomykoz, Feb 17, 2020.
  1. tomykoz
    tomykoz Active Member
    Mar 13, 2010
    157
    58
    I’m 64...probably will never play out again but the hope is always there....that being said I’m trying to find an easy to carry gig rig.....I have owned many haze 40 amps in the past and to me they sounded better than the dsl line and they always worked and sounded great after the bugs were worked out electronically ....but before I buy another I was curious if the origin 50 or Dsl20hr and 2x12 cab and pedalboard would sound better?....I love the new dsl40cr combo but it’s too heavy for me to haul around....any veteran guitarists out there with advice on a cheap gigable versatile classic rock/blues lightWeight amp
  2. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    5,570
    6,101
    Montreal
    Lots of love around for the Origin 20.
    BP
  3. Kinkless Tetrode
    Aug 17, 2017
    1,120
    1,398
    Reports are that the Origins work great with pedals.
  4. RCM 800
    RCM 800 Well-Known Member
    Dec 20, 2019
    153
    272
    Im playing country/rock with one of my bands. Im able to get over the drums on the 5 watt setting on my Origin 20h with a 1x12. At home I use the 1/2 watt setting. Amp is set so that it is right on the edge of distortion so if you really thwack the strings it overdrives. I use a boost and then overdrive to push it into AC/DC like overdrive and then full distortion. I dont like the built in boost its flubby sounding to me.
  5. LPMarshall hack
    Nov 18, 2009
    10,432
    9,221
    San Diego, CA
    Mitch...this thread needs you!!!!
  6. renips
    renips Well-Known Member
    Nov 15, 2010
    770
    564
    Pembroke Pines, Florida
    I have had a HAZE 40C for 11 years. Great compact design. I changed out the speaker and tubes and it really is a good amp to take to practice or gig. It takes pedals very well also.
    tomykoz, black knight, tce63 and 2 others like this.
  7. black knight
    black knight Member
    Sep 17, 2014
    40
    45
    If you can live without an effects loop, the Haze 15 would be a great and cheap solution. They can be had for $250 used and sound good stock but with a couple of component swaps, sound great. Through a 1x12 with a G12H-30 it sounds huge. Well maybe not huge but definitely bigger than the little stack looks. Go less efficient with the speaker like a V30 and it's lighter and less loud but will still hang easily in a full loud band situation. I find these amps sound more vintage than the dsls. To my ears they can sound plexi-ish or early mv-ish. A good OD in front and you can cover a lot of ground. And again, $250.
  8. Mitchell Pearrow
    9,761
    15,815
    Origin 50H boost at 7
    Presence 10 bass 5. mids 8
    Treble 8 tilt at 5-6, SD1 set as a clean boost, FX send into instrument in on the clean channel of a 3210 lead 100 mosfet, Origin in full 50 watt power volume at 4-5 loud as hell.
    Cheers to no flub, mud of any kind.
    Mitch
    kustombob, gkterry, scozz and 6 others like this.
  9. Mitchell Pearrow
    9,761
    15,815
    Dsl40c’s on the clean channel, with a Vox Tone Lab, using delay, tube overdrive, and 68 UK amp sim, Gibson LP Traditional
    TV volume
    MarshallDog, scozz, KraftyBob and 2 others like this.
  10. Mitchell Pearrow
    9,761
    15,815
    Dsl40c’s, MXR 10 band eq,
    Ultra channel 1 gain at 4-5
    Presence 6 bass 5, treble and mids at 7 resonance 5
    Cheers Mitch
  11. Mitchell Pearrow
    9,761
    15,815
    2 Origin 50H’s MXR 10 band eq
    Boost on both amps at 7
    Presence 10 mids 8, treble 8, bass 5, tilt 6, no pedals,
    Gibson LP Traditional.
    Cheers
    Mitch
  12. Mitchell Pearrow
    9,761
    15,815
    I think these are decent examples of the tones that I use.
    Cheers
    MarshallDog likes this.
  13. Mitchell Pearrow
    9,761
    15,815
    On it brother I posted a number of clips to give a reference.
    Thanks
  14. Mitchell Pearrow
    9,761
    15,815
    I have zero experience with the haze , but I do have some experience with the Origin’s and the Dsl40c’s, I posted a couple of clips in here. Thanks
    Mitch
  15. ricksdisconnected
    Aug 11, 2019
    2,379
    3,272
    of all the marshalls made ever, i think the haze is talked about the least. i dont know why though.
  16. LPMarshall hack
    Nov 18, 2009
    10,432
    9,221
    San Diego, CA
    Great tone Mitch!
  17. Mitchell Pearrow
    9,761
    15,815
    Thanks brother I appreciate you taking the time to check out my clips ...
  18. Chris-in-LA
    Chris-in-LA Well-Known Member
    Jul 19, 2018
    873
    559
    I hate to say this here as I’m a Marshall/Fender tweed kinda guy, but, the Fender Deluxe reissue might suit your needs unless you play with a very loud drummer.
    tce63 likes this.
  19. SteelLucky
    SteelLucky Active Member
    Mar 14, 2016
    113
    103
    Never touched a Haze. Been around Super Leads and JCM800’s since I was a kid. My current amp is a DSL20HR and 2x12 and I am not sure I’d need a different amp in today’s world. This amp gets plenty close enough to multiple different Marshall amp tones that I am extremely happy with it as my main amp. The Origin 20 is a nice amp but I just find the DSL20HR has more versatility.
    netlocal, Antmax and Mitchell Pearrow like this.
  20. Kinkless Tetrode
    Aug 17, 2017
    1,120
    1,398
    The dirt channel is not bright like an 800, but dark, and it is not high gain. It did not have much appeal to the modern hard rock/metal crowd. The clean channel has a plexi preamp signal path, though, and takes pedals well. The channels are starkly different in voicing.
    The series II DSL that replaced it in the line up have starkly different sounding channels too, but they also have a very high gain mode and are voiced bright.
