97 jcm 2000 dsl 100 issue with red channel
Discussion in 'The Workbench' started by Mike cooper, Jan 12, 2020.
  1. Mike cooper
    Mike cooper New Member
    Jan 2, 2020
    26
    5
    So I posted this problem on the other board and before I had researched and looked in here,I think the workbench would be a better place to post.i bought this used a year ago and been like this ever since,my 1997 jcm 2000 dsl 100 watt head when I’m on the green clean channel the red lead channel led with be dimly on,when switch to red lead channel the green light goes completely off,the only other thing is when I go back to green channel it make a slight pop noise,I’ve spent 2 hours today on the forum searching and found other people with the issue but no success repairs and one member said the fix was on here but I can’t find it,there’s a yellow round cap that’s soldered in that doesn’t look factory and compared to online pics it doesn’t look factory and wonder if that is the reason?ill post the pic,thanks in advance
  2. South Park
    1,232
    927
    The popping sound is the channel switching relay. The ic mite be at fault.
