70's wha question
Discussion in 'The Tone Zone' started by tone seaker, Jun 13, 2019.
  1. tone seaker
    tone seaker Well-Known Member
    Jan 20, 2011
    3,033
    3,205
    Where the Rock Rolls Hard and the Blues Rains Down
    i have a 70 wha that was modded a long time ago to true bypass and then years latter it was modded back to no true bypass. The problem is even when the guitar cables are unpluged it drains the battery. The only thing changed and changed back was the switch to a true bypass switch and back to the original switch I believe. any ideas thks :) DSCF4823 (2).JPG
  2. mirrorman
    mirrorman Well-Known Member
    Mar 30, 2014
    714
    831
    Canada
    Is there any particular reason the battery is taped to the connector?
    Is it possible the connector is pooched and shorting out?
    One other comment -- it doesn't look like there is much if any grease on the pot gear - you might want to add some.
  3. Dogs of Doom
    18,614
    17,885
    you need to use alkaline batteries, or lithium, not cheap heavy duty batteries. You'll be lucky to get an hour from one of those...
    Phony iommi likes this.
  4. ampmadscientist
    12,680
    6,568
    Left Coast
    When the cables are unplugged, it's supposed to shut off the battery.
    And so it's probably wired wrong at the input or output jack.
  5. Sdunn
    Sdunn Member
    Jun 3, 2019
    30
    13
    Looks like the input jack is a replacement. Has it been wired correctly?
    The input jack should have 3 tabs.
    1 is the input (tip)
    1 should be battery negative.
    1 should be circuit ground
    If this correct and you're battery is still draining mirrormans suggestion of a short may be right.
    fifteenohms and tone seaker like this.
  6. tone seaker
    Jan 20, 2011
    3,033
    3,205
    Thanks after compairing to my other one a 1969 V846
    I realized the input jack was wired wrong and two of the terminals were soldered together :)
    Dogs of Doom likes this.
  7. Sdunn
    Sdunn Member
    Jun 3, 2019
    30
    13
    Good spot. Hopefully that will sort the issue you're having.
    :cheers:
    Some nice wah's there!
    tone seaker likes this.
