70's Rock Tone At Lower Volume/which Marshall
Discussion in 'Marshall Amps' started by 05645, May 18, 2018.
  1. 05645
    05645 New Member
    May 18, 2018
    12
    4
    Good afternoon, all, new member, first post. I'm in my 60's, and mostly play in my home music room or out jamming with friends; I'm playing my 59 LP Special, 2014 LP Classic, 2007 57 reissue Strat, and 2007 MIM Tele through a Deluxe Reverb and a Vox AC15C1.
    I've wanted a Marshall for those classic 70's tones that can do so at a lower volume in a small room (14 x 14) I'm a bit overwhelmed by all the different models; what models would the group recommend? Thanks for the join
    05645
    eastsidecincy and EastTexas like this.
  2. anitoli
    anitoli Well-Known Member
    6,194
    6,612
    This is easy, 6100.
    05645 likes this.
  3. BanditPanda
    BanditPanda Well-Known Member
    Oct 19, 2015
    4,015
    3,223
    Montreal
    Marshall Origin series.
    05645 likes this.
  4. liontato
    liontato Well-Known Member
    Sep 24, 2012
    690
    546
    JMP 2204 Master volume. It does 70’s rock at decent volume. You’ll pay but it’s worth it.
    Trapland, eastsidecincy and 05645 like this.
  5. Len
    Len Well-Known Member
    Sep 13, 2009
    985
    748
    DSL40CR.
    Guitar Rod likes this.
  6. MonstersOfTheMidway
    May 1, 2008
    4,699
    2,063
    Vintage Modern 2266 head (available on used market only)
    Vintage Modern 2266C combo with stock 2x12 G12C speakers (available on used market only)
  7. Kinkless Tetrode
    Aug 17, 2017
    753
    834
    Mini Jubilee. You can run it 5 watt mode and it will play nicely with your guitars.
    curnla likes this.
  8. Deep Purple fan
    Nov 1, 2014
    2,361
    2,124
    Virginia
    Astoria Custom. It’s the real deal with no compromises.
  9. marshallmellowed
    Jun 26, 2009
    2,930
    2,549
    As you can already see, you're going to get hit with many suggestions. It may help if you elaborated a little further on your needs. Are you looking to buy a new amp, or used (many are only available used)? Do you need a multi-channel amp, or just a single channel? Do you need a built in solo (volume) boost? Are you looking for a head, a combo, or either? This type of info can help weed out amps that don't fit what your looking for.
  10. royslead
    royslead Well-Known Member
    Jan 19, 2011
    1,665
    1,035
    Wisconsin
    I will add- what groups or songs do you want to play? For instance, Black Sabbath tones are going to be different than the Eagle's. We can make recommendations that may somewhat cover both, but if you prefer one spectrum of tone over the other; it will help to know that preference.
  11. Dogs of Doom
    18,618
    17,893
  12. Len
    Sep 13, 2009
    985
    748
    Looks like you’re getting every amp recommendation under the sun. More info will help narrow down the options:
    - Budget?
    - Combo vs head/cab?
    - Number of channels?
    - Loop and reverb?
    - What songs are you trying to emulate? Classic 70’s means different things to different people.
  13. Len
    Sep 13, 2009
    985
    748
    IMHO JVMs have a more modern tone compared to the classic Marshalls. The midrange peak is in a different location.
  14. solarburnDSL50
    Aug 8, 2008
    15,443
    8,619
    Wetville
  15. Len
    Sep 13, 2009
    985
    748
    I’m not blaming the amp. Different amps have different tones. You can’t make a Mesa sound exactly like a Marshall. In this case you cannot make a JVM sound exactly like a JTM.
    solarburnDSL50 likes this.
  16. crossroadsnyc
    Feb 5, 2009
    20,121
    18,143
    :yesway:
    Short of going the NMV route (JTM45/1987/1959), this is probably going to be your best bet based on what you've already said. Though, I agree with the others in saying that a little more information would help narrow things down a bit. There are other terrific options out there like the YJM100 or Astoria, but you'll be looking at higher costs. On the lower end of the spectrum, you might want to consider the new Origin, but I admittedly do not have any experience with that amp, and based on clips I've heard, I'm not sure I'm comfortable recommending it.
    Questions to consider:
    * Budget
    * Needs
    * Desires (as silly as it sounds, don't overlook this component)
  17. 05645
    05645 New Member
    May 18, 2018
    12
    4
    Hey, thanks; I'd prefer new, a head ( I have a 4x12 Marshall Vietnam cabinet) 1 or 2 channels is fine, I prefer a model with a master volume to blend the "dirt"
    I don't need effects built in, I play blues/classic rock, no metal or heavy distortion needed. I have a number of good pedal including an Ibanez tube screamer, so need for built in boost. I don't really want to spend $2k, but if that's what it takes, then so be it. In a perfect world this amp would sound like Gary Richrath playing his LP in REO; I want that kind of tone in my music room at a reasonable volume. Thanks a bunch!
  18. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    4,777
    2,831
    Bay Area, CA
    Origin 20 Head...
    Georgiatec and assaf110 like this.
  19. frankyfal
    frankyfal Well-Known Member
    Sep 8, 2014
    722
    504
    Buy a Zvex double rock pedal and push the Deluxe reverb with it. If that isn’t Marshall enough push the AC 15 with it. If that isn’t the tone you are chasing return the pedal then invest in another amp. Marshall’s need to be played loud to shine imo. This pedal will allow the Marshall tone at low volumes and the two channel multi option drive or boost configuration gives you 3 stages of gain
    Set one for low gain psuedo jrm45 AC/DC
    Set one for med gain psuedo Plexi Led Zep
    Engage both for solo
    05645 likes this.
  20. solarburnDSL50
    Aug 8, 2008
    15,443
    8,619
    Wetville
    I knew what you were getting at. Disregard my post. It was over done.:D
