6550s In A ‘78 2204?
Discussion in 'Let's Talk Vintage' started by Taylor Ramey, Sep 15, 2018.
  1. Taylor Ramey
    Taylor Ramey New Member
    May 24, 2017
    14
    2
    i just picked up a 1978 JMP 2204 50 watt from a buddy of mine. Upon taking the back panel off, I noticed it’s got a set of 6550s in the power section.
    I know some older Marshalls shipped to the US with 6550s, but I always thought that was in the 80s. However, the tube diagram on one of the transformers shows EL34/6550
    Anyone care to chime in with some info?
  2. Taylor Ramey
    May 24, 2017
    14
    2
  3. Taylor Ramey
    May 24, 2017
    14
    2
  4. mickeydg5
    19,736
    7,603
    Nope, it was in the mid 1970's to maybe early 1980's or something like that. Its looks to be set up for 6550.
    MarshallDog likes this.
  5. Taylor Ramey
    May 24, 2017
    14
    2
    Could it have been modded to 6550s or does it look stock?
    Forgive my ignorance, I’m a newbie when it comes to these kinds of things.
  6. danfrank
    danfrank Well-Known Member
    Mar 5, 2015
    958
    486
    Looks stock for 6550s. Look at the two 150K bias resistors. If it was configured for EL34s it would have 220K resistors instead.
    If it was made for the USA market it came with 6550s.
    Mitchell Pearrow and MarshallDog like this.
  7. soundboy57
    soundboy57 Well-Known Member
    Dec 27, 2009
    2,608
    2,130
    Oregon
    Marshall put 6550's in the US export amps from approx. '74 to '86. Glad to be corrected on the exact years.
    The were more robust than the available EL34 at the time, and they were having warranty issues.
    I have heard that the US distributor actually swapped them in, however, the solder joints
    on any that I have had looked factory.
    Back in the day, seems everyone did the bias resistor mod and put EL34 back in (I did), however these
    days the 6550's sound damn good. Louder/clearer, but a bit more sterile, IMHO.
    Especially compared to the original Mullard EL34 :)
    CoyotesGator and MarshallDog like this.
  8. ampmadscientist
    11,220
    5,257
    Left Coast
    This amp came stock with 6550s in USA, the 150K bias split resistors confirm that.
  9. gldtp99
    gldtp99 Active Member
    Nov 29, 2010
    322
    167
    Arlington, Texas
    Yes, a factory 6550 amp.
    It has the 120k Bias Supply resistor (vs the 220k in an EL34 amp)
    And the 47k Bias Range resistor in series with the Bias Trim pot (vs the 56k in the EL34 amp).
    And the previously mentioned 150k Bias Splitter resistors (vs the 220k in the EL34 amp).
    I had to restore my '81 JMP 2204 to the 6550 specs because someone had done the crude "piggyback" bias resistor mods to run EL34's.
    In doing so they heat damaged the surface of the PCB----- not bad enough to effect function but enough that it won't just clean off.
    I wanted to run a pair of Sylvania 6550's I had on hand:
  10. Geeze
    Geeze Well-Known Member
    Jul 25, 2015
    1,061
    1,593
    Floating above Dallas in Marshall Heaven
    I have a '78 2203 that came with the original [maybe] GE 6550's. I liked the sound of them but two wouldn't bias anywhere near what I consider normal. Contemplated changing to '34s but stuck in a set of 6550 Ruby's instead - very happy with the sound into Greenbacks and Creambacks.
    Russ
  11. Ned B
    Ned B Member
    Nov 19, 2012
    94
    61
    6550s started appearing in US shipped Marshalls as early as 1973.
    Mitchell Pearrow and soundboy57 like this.
  12. solarburnDSL50
    Aug 8, 2008
    15,092
    7,876
    Wetville
    I love 6550's in a classic Marshall circuit.
    Congrats on a killer amp.
  13. Taylor Ramey
    May 24, 2017
    14
    2
    Thanks for all the help guys...
    Does the fact that it’s all oriinal(minus the tubes) and not modded make it worth more?
  14. Taylor Ramey
    May 24, 2017
    14
    2
    Also, I have the matching 4X12(straight) that came with it...
    Signed by Jim Marshall on the inside and loaded with G12M “Blackbacks” (T1221s).
    I’ve cleaned the tolex up on both and now the tolex looks good as new.
    The head only has a couple dings... no snags.
    The cab has a couple dings as well a snag on the back cover of the cab. The Marshall logo on the cab is cracked and the speaker cloth has a stain... is there a way to clean it up?
  15. Taylor Ramey
    May 24, 2017
    14
    2
    This is a black and white picture from my buddy’s Instagram... I’ll post a color one later... the stain is visible, it sits at the very bottom of the cab’s speaker cloth.
  16. Taylor Ramey
    May 24, 2017
    14
    2
  17. eastsidecincy
    eastsidecincy Active Member
    Jan 22, 2011
    165
    148
    Yep...my 73 SuperLead had 6550's in it...sounded great..
