6550 tubes in a Jubilee?
Discussion in 'The Workbench' started by JacksonCharvelAddict, Aug 19, 2019.
Tags:
  1. JacksonCharvelAddict
    Mar 4, 2016
    1,516
    1,440
    I was wondering if anyone here has ever tried running 6550s in a 2555x or oryer model Jubilee. I know that they have a lot more headroom than el34s but I have also heard that they allow a wider frequency range. I thought maybe with the versatile EQ of the Jube it could benefit from this. I have some 6v6s I have been tempted to try as well.
  2. scozz
    scozz Well-Known Member
    Jul 20, 2008
    1,456
    2,820
    I was thinking about those tubes as well in my Jcm800 Studio, but when I heard about the more headroom part I moved on. I’m not interested in getting more headroom, I like the balance I have now.
    I’m completely happy with the EL34s I’ve got in there now. Although I must say I’m very interested in Tong-Sol EL34B. :hmm:
  3. JacksonCharvelAddict
    Mar 4, 2016
    1,516
    1,440
    There are so many tubes to choose from for different purposes. I think the increased headroom would be handy for anyone that uses the Jubilee as a power amp. I frequently use my Kemper through the loop return and the increased headroom may help that at higher volumes.
    Adrian R likes this.
  4. Adrian R
    Adrian R Well-Known Member
    Jan 28, 2009
    6,177
    4,198
    Far North Chicago Burbs'
    Duuuudde! I never thought of that before...holy crap...got gas now..damn... That's what's great about the new Jube...the ability to run any power tube. I will have to try some out...
    Thanks man...
  5. RickyLee
    May 22, 2010
    9,433
    2,927
    Riverside CA U.S.A.
    I have 6550 in my Jubilee Clone. My Clone has much beefier/higher power rated transformers though. Getting increased headroom in an EL34 spec'ed 50W/100W amp might not be fully attained to a 35W 6550, but be careful biasing them up regardless.
    As for the new Jubilee? I am not sure what the power supply is spec'ed for.
  6. DonP
    DonP Member
    Jan 28, 2009
    79
    32
    Cincinnati, OH
    You can't just stuff whatever tubes in an amp unless the amp allows for them.
    6550's require a more negative bias. In order to use them in older JCM800's, you would have to modify the bias circuit. I don't know if the 2555X requires the same mods.
    On the other hand, my Randall RM100LB is designed to allow any power tube to run in it, and even mixed tubes. Each tube has it's own bias circuit.
    6V6's can only take so much B+ voltage. Sticking them into an amp with too much B+ will make them pop.
  7. Gunner64
    Nov 16, 2013
    4,774
    5,264
    Midwest, USA
    The 2555x can use 6550s, and others. There's a tag next to the bias points that has a chart for settings. 2939fb1f-ae8c-4800-b226-5e53578a0ab5-jpeg.jpg
    MarshallDog likes this.
  8. MarshallDog
    Nov 28, 2010
    11,224
    9,709
    Taintville
    Now that’s a great feature!
  9. Gunner64
    Nov 16, 2013
    4,774
    5,264
    Midwest, USA
    Yea, it's pretty cool. All Amps should have this set up.
