50 Watt Plexi Build W/lar/mar Having Problems
Discussion in 'The Workbench' started by tooloud, Jun 12, 2018.
  1. tooloud
    tooloud New Member
    Jun 12, 2018
    I built the amp over 10 years ago worked good since built, but now volume is low and when I turn the treble control it changes the volume.... got new Voltage measurements see low voltage on 12ax7 V3 Pin 1 should be around 200 vdc but getting 55 vdc
    V1 1=128 2= sig 3=0.814 4=H 5=H 6= 165 7=sig 8=1.55 9=H
    V2 1=137 2= sig 3=0.814 4=H 5=H 6= 235 7=137 8=139 9=H
    V3 1= 55 2=sig 3= 48 4=H 5=H 6=220 7=sig 8=48 9=H
    V4 1=G 2=H 3= 411 4= 404 5= -36 6= 410 7=H 8=G
    V5 1=G 2=H 3= 412 4= 405 5= -36 6= 409 7=H 8=G
  2. mickeydg5
    22,737
    9,986
    Have you tried replacing V3 with a known good tube or at least swap with V1, V2 to see what changes follow?
    neikeel likes this.
  3. ampmadscientist
    14,277
    8,090
    You might think that 1 of he preamp tubes is bad....so try swapping preamp tubes 1 at a time and see if the voltage comes back.
    Also, the resistor is suspect:
    But it is pretty rare for that resistor to fail.....probably a bad preamp tube.
  4. tooloud
    tooloud New Member
    Jun 12, 2018
    I will try the preamp tubes one by one tonight and report back....
  5. ampmadscientist
    14,277
    8,090
    Well what can drag down the voltage?
    The tubes, a bad filter cap, a bad resistor, a shorted coupling capacitor.
    Un-plug the preamp tubes one at a time, and see when the voltage goes up again. Since V3 has the lowest plate voltage, it could be a bad phase inverter tube.
    I am thinking V3 is bad.
    Or, the coupling caps for V3 (pins 1 and 6) are shorting out? This would also throw the bias voltage off.
    But don't replace any parts till you narrow it down more.
  6. mickeydg5
    22,737
    9,986
    Also do not forget to swap V3 and let us know what changes are found there if any. :D
    Check the bias on the power tubes while you are in there too.
  7. neikeel
    3,528
    1,966
    Given the voltages in the rest of the amp the only low one is the 82K PI plate resistor. Did you use a carbon comp there? Has it drifted up badly? Pin 6 (the other plate resistor at 100k seems ok)
  8. tooloud
    tooloud New Member
    Jun 12, 2018
    well it was V3 tube I replaced it, it had a JJ 12ax7s in it I put an RCA 12ax7 in it ........ amp working agian.......
  9. mickeydg5
    22,737
    9,986
    Oh my freaking gosh! :woot:
    Good for you. :)
    tooloud likes this.
  10. ampmadscientist
    14,277
    8,090
    I just need to add 1 more note to this: there is nothing wrong with JJ tubes. Any tube used in V3 can go bad, even GE.
    So please do not associate failure with the JJ tube, cause that would be unfair to say so.
    In these amps with PPIMV, the V3 tube gets pushed really hard...
  11. ampmadscientist
    14,277
    8,090
    He's so excitable.
  12. mickeydg5
    22,737
    9,986
    AmpMad, its all excitable. It is good to have more than one opinion along with extra thoughts and details. I am glad he got it sorted and it was an easy fix. :yesway:
