4 watt power building
Discussion in 'The Workbench' started by zebrarock, Feb 24, 2020.
  1. mickeydg5
    mickeydg5 Well-Known Member
    24,633
    11,573
    Ha, ha, ha. Ok. :)
    But do take into consideration what I mentioned earlier, Philips did not have a clean sine wave at 4 watts output. :yesway:
    zebrarock likes this.
  2. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    Due to 3.2% of distortion parameter, right?
    I will try to join all your suggestions to perform some test and modification, then i will post result for a opinion, thanks to all !
    mickeydg5 likes this.
  3. AMPPILOT
    AMPPILOT Active Member
    Jan 7, 2011
    146
    165
    fo watt ...my hear n aid is mo pwr den dat .
  4. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    Hi, here my last measurement with all precautions you suggested:
    1) Input signal 100mV @ 1 Khz - Output signal 4.2 V RMS (measured with my multimeter)
    2) Input signal 100mV @ 1 Khz - Output signal 14.3 V peak-to-peak or 4.9 V RMS => 3 watt @ 8 ohm dummy load (measured with scope)
    From inverter tube (6C4) into grid of the two power tubes (EL91) i get 29 V peak-to-peak until overdrive or 10.25 V RMS. When there are 12 V RMS on grids
    the two tubes are already overdriven and signal is clipped
    2) Input signal 100mV @ 300 Hz Output signal 3.7 V RMS (measured with my multimeter)
    3) Input signal 100mV @ ~3 Khz Output signal rise until 5.3 V RMS with a total output power of 3.5 W and as rises fq rises the output voltage too, ~5 Khz i get 4 Watts output power.
  5. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    So, i start getting 4 watt output power on high fq ~5 Khz, not at 1 Khz....
