4 watt power building
Discussion in 'The Workbench' started by zebrarock, Feb 24, 2020.
  1. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    Hi to all,
    i just built a low watt amplifier using 2x miniwatt tube NOS Philips EL91 in push pull for a total output power of 4 watt.
    I used a Hammond 125B OT for 8 ohm secondary and 22.5K primary impedance.
    the ampli sounds great, as i aspected, but i canno get 4 watt out of my secondary OT, but only 2.3.
    I configured tubes as datasheet suggests for class AB push-pull amplifier, i.e. 250V on the plates, 560 ohm as shared cathode resistor for a grid-to-cathode bias voltage of -13.5.
    Power stage is driven by cathodyne PI with a 6C4 tube which is not overdriving for the moment.
    Now for power test, i followd this procedure:
    Inject 1 KHz signal into ampli and turn up volume before the clipping point, where the wave form is a clear sine.
    Then measure voltage at the leads of 8 ohm dummy load and apply formula P = (V*V) / R.
    I am puzzling myself to know why but i am not understanding,
    could you please give me any suggestion o what may i check ?
  2. South Park
    1,714
    1,336
    The watt rating is for heat dissipation not power to speaker .
    thetragichero likes this.
  3. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    I knew that max heat dissipation was measured at idle state, the document shows that with no signal applied Watt are 0, and with 12 Veff of input signal is 4W...am I interpreting correctly ? They seem to be power rating values, not so ?
  4. South Park
    1,714
    1,336
    Tubes are valves the power to ground all the time . The voltage drop that drives the speaker does not increase the wattage of the tubes. Unlike solid state that goes from o to full power . It is a wired one how tubes work. It takes some time. Hope that helps . Read as much as you can about tubes it will makes sence
  5. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    Thank you South for you explanation, but I don't think I understand... :wallbash:
    what did i wrong on my interpretation ?
    Hence, getting 2.3 watts RMS from ot secondary could be right ? Don't i have to expect 4 watts RMS instead ?
  6. South Park
    1,714
    1,336
    the more time you study this stuff the better you get. None of this stuff is easy . You are on the fight track
  7. ampmadscientist
    16,538
    10,452
    Peak to peak sine wave / 2 = peak sine wave.
    Peak sine wave X .707 = RMS sine wave voltage.
    RMS voltage / 8 ohms = Amps (= I)
    I X RMS voltage = (what?)
    Is this how you are measuring ? because I don't understand if you are turning the scope wave form into RMS voltage.
    How many volts peak to peak are you measuring before clipping?
    South Park likes this.
  8. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    I am measurnig referring to my voltmeter which gives me rms values, right ? ... honestly i am not referring to oscilloscope wave, and i could try...
    what you wrote made me understand one thing about peak voltages that i did not understand before, thank you a lot !!!!
  9. ampmadscientist
    16,538
    10,452
    What is the RMS voltage at the load, before clipping?
  10. thetragichero
    Jun 6, 2010
    2,351
    570
    flo rida
    cathode bias generally produces lower output power than the same setup were it using fixed bias, no?
  11. johan.b
    johan.b Well-Known Member
    Feb 21, 2015
    1,649
    1,810
    Södertälje, Sweden
    250x250/22500=2.77...you need higher voltage or lower p to p impedance
  12. ampmadscientist
    16,538
    10,452
    Well we don't know if the measurement is right yet...he might have been doing it wrong.
  13. mickeydg5
    mickeydg5 Well-Known Member
    24,034
    11,021
    The specifications indicate 12V RMS signal to the power tubes. So all you have to do is make sure your signal is that, with a multimeter.
    You are measuring at 1kHz for 2.3W output. Is the grid input signal 12V RMS?
    The specifications do not specifiy but most likely the output measured is an average at frequency/fequencies for speech. Try something below 300Hz.
  14. ampmadscientist
    16,538
    10,452
    Yes because cathode bias is class A which runs the tube at 100% full time.
    And so the power has to be de-rated because there is too much heat.
  15. mickeydg5
    24,034
    11,021
    Baby Thomas likes this.
  16. ampmadscientist
    16,538
    10,452
    That's true the meter may not measure RMS accurately at 1KHz.
  17. mickeydg5
    24,034
    11,021
    If you look at the Philips specification data @zebrarock linked in the first post it indicates cathode biased with an output power of 4 watts.
    Everything he has mentioned is in relation to the Philips specification for two tubes push-pull, except for the frequencies of speech.
    And uh, nothing is perfect so allow at least +/- 20%.
  18. mickeydg5
    24,034
    11,021
    Most lower cost multimeters should handle 45-400Hz bandwith when measuring AC voltages. 1000Hz is high for the average multimeter.
  19. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    From my multimeter is 4.2 v ac
  20. zebrarock
    zebrarock Member
    Nov 7, 2017
    212
    14
    Italy
    Input voltage to power tube before clipping is 8.9 v ac rms... i though the 12 v from datasheet was peak to peak voltages, not so? It is written 12 Veff...
