25 Watt Speaker in a 20 Watt Marshall?
Discussion in 'Cabinets & Speakers' started by scozz, Nov 20, 2019.
  1. Gene Ballzz
    Gene Ballzz Well-Known Member
    Feb 19, 2013
    1,887
    1,358
    Las Vegas, NV
    You Sir are absolutely correct on all points, right there!
    On a different note, please allow me to thank you for the knowledgeable expertise that you share here! I certainly don't want/intend to offend or put you off! Simply sharing opinions.
    Just My $.02 & Likely Worth A Whole Lot Less!
    Gene
    scozz likes this.
  2. Scumback Speakers
    Sep 16, 2016
    707
    942
    Los Angeles, Ca
    No worries! I just try to help when I can.
    tce63 and scozz like this.
  3. scozz
    scozz Well-Known Member
    Jul 20, 2008
    2,447
    5,377
    I'm an at home player, I mentioned that in the first post. The reason I mentioned it is because I thought it would lead everyone to understand I'm not playing this amp thru this speaker at gigging volumes. So that's the premise of my question,....is a 20 watt amp ok to be played thru a 25 watt speaker at home. Maybe I should've made that more clear, also I'm using an attenuator.
    tce63 likes this.
  4. scozz
    Jul 20, 2008
    2,447
    5,377
    Thank you, I appreciate that! :yesway:
    tce63 likes this.
  5. Metroman
    Metroman Well-Known Member
    Apr 29, 2014
    742
    423
    Of course its ok to use a 25w speaker with a 20w amp, if using an attenuator. But even at that, I do not think it is optimum.
    For me, theres no way Id use a 25w speaker with a 20w amp. I like all the speaker capacity I can reasonably get vs amp RMS.
    I hate any kind of funny business going on with a speaker.
    Speaker RMS is a Thermal Rating.
    Logically, does it make sense electrically to use a speaker that basically the same watt capacity as the amp, with the amp probably putting out a bit more than the 25w speaker capacity wit a cranked amp.
    At that rate, the ability of the speaker to absorb heat is basically the same capacity as the amp can put out cranked, thus never letting the speaker rest, and if played for long periods of time, is at least suboptimal.
    Take Hendrix with a 100w cranked Marshall, and 240w worth of speakers, he still blew speakers, and had MORE vs 2x the amp RMS.
    Makes ya wonder why you never see any old blown Fanes around, because they use 4-8 75-100w speakers ( 600-800w ) for a 100w DR103.
    You also never know when you may be able to crank your amp at some point, and wouldn't it be nice to know that the speaker you have will outlast the amp???
    That's also 1 thing I try and achieve. Knowing my amp will probably blow long before the speakers. But everyone likes what they like.
    I often use 2 x 1 x 12 Redbacks with a 38w Metro GMP45 head. The RB is a really really nice speaker, and is particularly good in an open/semi open back cabinet. Forget your amp is 20w, and the speaker is 150w. Makes 0 difference.
    Brian May says when he tours he carries a shitload of Celestion Blues for his Vox AC30s because he blows the crap out of them.
    I myself would get a 150w Celestion Redback.
    IMHO they are King for a 1 x 12, and the classic Celestion sound.
    If not the RB, a Scumback H55 PVC 65w
    T.J., tce63 and Scumback Speakers like this.
  6. obx351
    obx351 Member
    Oct 12, 2012
    79
    69
    FWIW, I have an 18 to 23 watt JTM 45ish combo with a '72 G12M 25 watt Celestion in it. I also have a PPIMV in the amp. I generally use the PPIMV as my vol and I never go above 60%. It's plenty loud and if I need more vol I output to a cabinet with a single Celestion Gold. Or I use my Blackstar Artisan 15 which has a Celestion Vintage 30 in it. My general rule of thumb is double the watts for the speaker to the amp, so a 15 watt amp should have a min of a 30 watt speaker.
    Metroman and tce63 like this.
  7. Scumback Speakers
    Sep 16, 2016
    707
    942
    Los Angeles, Ca
    Maybe I'm reading it wrong, obx351, but doesn't that speaker frame have T1281 stamped on it?
    GIBSON67 and obx351 like this.
  8. dro
    dro Well-Known Member
    Aug 1, 2015
    327
    426
    Blue Springs Mo
    2 Greenbacks stacked works great sounds sweet. Use the Orange ppc 112 Closed back cabs. Seemed to be the least expensive way to get a Closed back Birch cab with the most Air volume. Works great for me. Jubileestack.JPG
    tce63 likes this.
  9. obx351
    obx351 Member
    Oct 12, 2012
    79
    69
    I think it does. So the 55hz not 75hz? Either way, it's killer sounding.
    tce63 likes this.
  10. Scumback Speakers
    Sep 16, 2016
    707
    942
    Los Angeles, Ca
    Yes, T1281 would have come with a 55hz cone, not a 75hz. Label should read G12H30 15 ohms 30w 55hz on it.
    obx351 likes this.
  11. obx351
    obx351 Member
    Oct 12, 2012
    79
    69
    All good, & ty for the correction!
    Scumback Speakers likes this.
  12. Scumback Speakers
    Sep 16, 2016
    707
    942
    Los Angeles, Ca
    No worries. I sometimes cough up Txxxx numbers on the carpet when I have a cold...like this week. LOL
