2204 and metro zero loss loop
Discussion in 'Marshall Amps' started by Adamguitar, Jan 27, 2020.
  1. Adamguitar
    Adamguitar New Member
    Jan 24, 2020
    5
    4
    Hi, long time lurker, 1st time poster. Anybody installed the metro zero loss loop and then regretted it? Alter the sound? I have a pristine 80’ 2204 that I’ve had for about 15 years and was thinking of adding this loop for time based effects and a volume/lead boost. This was the only reason the amp didn’t get much use over the years being in cover bands and needing those effects. Been using a 900 mkIII for the loop and dual master, but really prefer the 2204 sound. Just not sure about hacking it up. Plan on keeping, but you never know when bad luck strikes and you have to sell. Btw, great board with lots of good info. TIA
    -AG
  2. Gunner64
    Nov 16, 2013
    5,480
    6,640
    Midwest, USA
    No. Don't hack it up. Build a clone, or buy one already built and hack that..:)
    I built a clone just for that very reason. I hate to see a great amp like that with extra holes drilled in it..and stuff.:cool:
  3. coolidge56
    coolidge56 Well-Known Member
    Jan 30, 2019
    350
    764
    Purchase an aftermarket rear face plate and hack that up instead. This would avoid drilling 2 holes in the factory original face plate which would hide the 2 holes in the chassis if ever you wanted to return it to stock.
  4. Mitchell Pearrow
    9,099
    14,042
    :welcome: To the forum, I would not hack it, nor mod it, it will get pissed and do something foul.
    Cheers Mitch
    scozz and Gunner64 like this.
  5. pedecamp
    13,819
    10,217
    Spend a little more for a Bad Cat Unleash then you'll have an outboard effects loop, no amp hacking necessary. :yesway:
  6. Adamguitar
    Jan 24, 2020
    5
    4
    Thanks. That’s my worst fear, monkeying with the thing and then noticing that it sounds different. I may just go old school effects thru the front. I might have to try to use my JHS modded ge7 backwards, off for boost and on for rhythm with slightly scooped EQ.
    -AG
  7. South Park
    1,438
    1,080
    Unless you are a amp tech. You will need help . The signal chain is not something you want to alter. If you build a clone you can mod it when you got what is going on
  8. Matthews Guitars
    1,084
    1,413
    I installed one in my 2203. I went for a no holes drilled installation. I used speaker jacks 3 and 4 to mount the loop, and for the switch I used one of these from Stewart-MacDonald, in place of the master volume pot. (Resistive element swapped out for a 1 M from a new CTS pot, because those switched pots don't come in 1M but they're CTS.) This makes for a 100 percent reversible installation IF you have two spare speaker jack positions spaced on 1.5" centers.
    The loop works very well. No tonal alteration that I've heard.
    Axeplyr and Mitchell Pearrow like this.
  9. shooto
    shooto Well-Known Member
    Oct 22, 2011
    1,931
    1,048
    Denver, CO
    You can house it off the chassis so you don’t have to drill it...that what I did with the loop in my 2204
  10. shooto
    Oct 22, 2011
    1,931
    1,048
    Denver, CO
  11. pedecamp
    13,819
    10,217
  12. spacerocker
    spacerocker Well-Known Member
    Feb 6, 2009
    1,510
    905
    UK
    This is why I bought a JVM410 in 2009. I have a 1980 2203 Which I loved the rhythm tone of - but found it too limited for the reasons you suggest.
    A stock JVM410H on Crunch orange or red sounds similar to a 2203/4, but a few simple mods can make it almost indistinguishable. If you can afford it - go down this route? You would then have a 2203 type crunch channel, a proper clean channel and a lead channel (OD1 or 2) plus 2 masters and a loop! I still have my 2203. I don't use it anymore - just keeping for posterity!
  13. Filipe Soares
    Mar 8, 2019
    773
    1,178
    I have a 2203KK with the metro fx out of the chassis. try that. the installation is pretty simple if you're into soldering and in my case there was no difference in the tone. it took me some days to figure it out because there's no much information about the kk with the fx loop around, but I think with the 2204 will be pretty straight forward.
  14. neikeel
    3,787
    2,200
    The loop is completely transparent. I no longer install with a switch. if you have a 70s 2203 or 1959 with x4 jacks you are sorted, as Matthews Guitars pointed out, I like Structo’s solution too.
    The loop interrupts the preamp out to pi ( treble wiper wire) so it is possible for it to be totally reversible. The loop does need a power supply you can take from the choke/screen feed turret by varying the series dropping resistor size (comes in the kit).
  15. RCM 800
    RCM 800 Active Member
    Dec 20, 2019
    68
    110
    Just pipe them in the front.
  16. ampmadscientist
    15,494
    9,382
    It definitely changes the tone, it's not "transparent," It's FET transistors. (most loops are solid state no matter which)
    I found it didn't sound too bad when I tweaked the levels to match the amplifier.
    It really doesn't match all effects pedals, especially high level professional effects units.
    I didn't use the "bypass." I just left it in the circuit as part of the amp.
    I also made a balance control for series/ parallel/bypass which I though really helped a lot and I liked the final result.
    (we used pro effects not DOD, etc...) Most cheap effects from China I consider a joke anyway and would never waste the money.
    South Park likes this.
  17. Adamguitar
    Jan 24, 2020
    5
    4
    I’m not an electrical guy by any means. I’ve done pickups, pots and switches in guitars but nothing like this. A lot of cool ideas, but sounds complicated for a hobbyist like myself.
  18. Jethro Rocker
    7,410
    7,789
    I second at least tryjng a Bad Cat Unleash. Extra channel for boosts plus a loop. I notice a slight drop in low end when using mine. Put an EQ in loop.
  19. herbvis
    herbvis Active Member
    Jul 8, 2010
    151
    150
    I have one in my metro 2203. Excellent loop. no issues. Wouldnt drive without it.
  20. Filipe Soares
    Mar 8, 2019
    773
    1,178
    if you can solder and follow instructions you have 90% what it takes to do it.
    herbvis likes this.
