212 cab
Discussion in 'Cabinets & Speakers' started by Joe Reeves, Feb 16, 2020.
  1. Joe Reeves
    Joe Reeves New Member
    Jan 30, 2020
    16
    15
    Hey guys, I have a DSL20HR, using a Traynor DH 212 with greenbacks..
    What Marshall cab would sound good with this?
    The matching cab comes with 70/80's which I heard were not that good.
    Any insight or suggestions?
    netlocal and usednabused like this.
  2. Adieu
    Adieu Well-Known Member
    Jan 12, 2013
    1,711
    1,660
    You seem to have a good cab already? What are you looking to change? Louder? Flatter?
  3. Joe Reeves
    Jan 30, 2020
    16
    15
    Hey,
    I've never had a tube amp before... just SS combos so I dont know what tone differences I can get by using other cabs/speakers. I like to play hard rock metalish stuff.
    Should I be using V30's? G12T?
    Not sure if using the matching cab does sound different, more of how the amp was built to sound like.
    netlocal likes this.
  4. mickeydg5
    mickeydg5 Well-Known Member
    24,644
    11,590
  5. Adieu
    Jan 12, 2013
    1,711
    1,660
    Matching cabs for mid-level stuff are usually optimized for price points / profits, not quality
  6. FracStrat
    FracStrat Well-Known Member
    Jan 22, 2020
    400
    1,027
    Water Side of WA State
    See if you can find a 1966 Diag 2/12 …… Amazing Cab
  7. Joe Reeves
    Jan 30, 2020
    16
    15
    Hey,
    Should I be using V30's? G12T Not sure if using the matching cab does sound different, more of how the amp was built to sound like.
    Even those lower end Marshall's?
    Like the Code Origin or MX (DSL match).
    My Traynor is a closed back but has 2 removable pieces.. bought this used and 1 is missing, maybe I'll find something to cover it.
  8. mickeydg5
    24,644
    11,590
    You will be disenchanted by the cheaper models after using better speakers/cabinets.
    netlocal and Joe Reeves like this.
  9. Joe Reeves
    Jan 30, 2020
    16
    15
    20200216_222114.jpg 20200216_222435.jpg These are a couple tubes from my DSL20HR... bought used... 2 EL34's are printed in red and 1 is white. Is there a difference? Should I be looking for some upgraded tubes... 1 is also on a mad angle.
  10. Joe Reeves
    Jan 30, 2020
    16
    15
    Ya I thought so. They're cheap for a reason I suppose.
  11. ampeq
    ampeq Well-Known Member
    Sep 14, 2017
    991
    947
    These Peavey cabs are very good, https://www.sweetwater.com/c624--Peavey--Guitar_Amp_Cabinets
    The 1-12" cab and both black 2-12" cabs are great. The better one comes with a V30 & Creamback and the cab itself is oversize and made of pine. I have the 2-12" with Greenbacks and it to is pretty nice. The Peavey emblem comes off with 2 tiny screws and will match about anything. Another very good deal on cabs is from Eminence and you can get the empty or loaded. https://www.eminence.com/guitar-bass/ext-cab/ I have a 1-12" and a 2-12" and they are very nice, all black to match anything. They are also open or closed back so they are great for testing. 2 1-12" cabs on end would make an awesome mini-stack with that amp. With a V30 in one and a CB in the other you could get all kinds of tones depending how you ran them that day. Run both with CB on top, maybe one open back, one at a time, whatever. Always try to buy good cabs and speakers because you could have them for a long time.
  12. Joe Reeves
    Jan 30, 2020
    16
    15
    I live in Canada so ordering from sweetwater is expensive, any warranty is also hard to deal with.
    I was however interested in mixing speakers. Thought about getting a V30 to mix with 1 of the GB and also mixing a EVM12L Black Label but I know nothing about these things
  13. netlocal
    netlocal Well-Known Member
    Jan 16, 2012
    429
    952
    California
    I’d go with the matching cabinet. The seventy/eighty and G-12E speakers are fine speakers.
    I have a vintage 2045 with G12M blacks, and an early 1936 (same as the 2045 dimensionally) with G12H30 speakers. Yes they’re great sounding cabinets but to me they’re almost like Museum pieces. I tend to Baby them.
    The cabinet I took to the show last last Friday at The Redwood? Origin cab to match my Origin 50 head. Looks cool. Holds up to being fully dimed on 50 watt setting. Loud as hell. Takes the abuse with no worries, which I would be reluctant to do with top shelf vintage gear. Tone that cuts thru the mix just fine too.
    (I know you asked about 2x12... My ORI cab is a 4x12, sorry:shrug:)
    :hbang:
    2045 with G12M
    Joe Reeves likes this.
  14. netlocal
    Jan 16, 2012
    429
    952
    California
    That’d be Killer with the DSL20. Or a 1965, for that matter. Love those cabs.
    FracStrat likes this.
  15. netlocal
    Jan 16, 2012
    429
    952
    California
    The Red ‘EL34’ tubes are your Power Tubes. The white Ecc83 is a pre-amp or phase inverter tube. The white one that’s cock-eyed- I’d pull it out, make sure the pins are nice and straight. Then shine a flashlight into the socket to make sure you get a good look at lining the pins up, with the socket, when you re-insert it.
    KraftyBob and Joe Reeves like this.
  16. FracStrat
    Jan 22, 2020
    400
    1,027
    @Joe Reeves ……The 1965 is a Killer 4/10 cab while the 1966 is a diagonal 2/12 cab …… Both are just spectacular !!
  17. Joe Reeves
    Jan 30, 2020
    16
    15
    I can't have a 412. Would never be able to turn it up loud enough to enjoy that size.
    212 is the most I could use.
    FracStrat and netlocal like this.
  18. FracStrat
    Jan 22, 2020
    400
    1,027
  19. EndGame00
    EndGame00 Well-Known Member
    Mar 4, 2013
    5,319
    3,526
    Bay Area, CA
    Jet City 2x12. They're affordable.. if you're considering to upgrade the speakers, bear in mind some cabs are sealed with epoxy and might require a little poking and prodding with a flathead screwdriver to remove the seal...
  20. Filipe Soares
    Mar 8, 2019
    1,187
    1,878
