2019 DSL 100 crapped out early on.
Discussion in 'Marshall Amps' started by Michael Jacob, Apr 5, 2020.
  1. Michael Jacob
    Michael Jacob Member
    Jul 13, 2019
    15
    32
    I bought a brand new DSL 100 in Feb 2019. Before I had to go back to work I bought 2 preamp tubes and tried them with no positive results. When I strum the strings on my guitar it just makes some scratchy noise. I just measured the plate voltage on all 4 power tubes, 437 volts, grid voltage is -35 volts and filament voltage is good. Could it be one or more power tubes is bad?
  2. Mitchell Pearrow
    10,237
    17,075
    Did you try the preamp tubes one at a time through the all slots ?
    Dbl check with both of your spares, I say this because one of my mullard preamp tubes was DOA..
    Cheers to getting your amp back up and running.
    Mitch
  3. Lance Chambers
    Jun 23, 2019
    1,408
    2,143
    The Land That Time Forgot
  4. Michael Jacob
    Jul 13, 2019
    15
    32
    I don't have a way to check the spares except to put them in the amp and yes I did change them one at a time.
  5. Mitchell Pearrow
    10,237
    17,075
    Ok I am no tech but that’s the way I have found my problems, have you checked the obvious ? Cable, instrument inputs , last night one of my amps was not making a sound at all and it was a bad speaker cable !
    Cheers
    Michael Jacob, Bull Rock and tce63 like this.
  6. Michael Jacob
    Jul 13, 2019
    15
    32
    Thanks yes I've don't all that.
  7. dslman
    dslman Well-Known Member
    Apr 15, 2012
    2,790
    1,301
    Prolly power tubes.
    Michael Jacob and Bull Rock like this.
  8. dslman
    Apr 15, 2012
    2,790
    1,301
    All tube amp owners should have spares. IMO.
  9. Michael Jacob
    Jul 13, 2019
    15
    32
    What brand do you recommend?
  10. pedecamp
    14,481
    11,383
    Check all your fuses first to see if thats the problem.
    Pull the inner two power tubes and see if it works, if not put them back and pull the outer two power tubes and see if it works. Also dont play it this way, just do a quick strum of the guitar to see if you get sound. If you find it works in one of these ways you can start juggling tubes to figure which is the bad tube and order one replacement power tube instead of a whole set.
    After that Im out of ideas. Do these have a 5 year warranty?
  11. Bull Rock
    Bull Rock Well-Known Member
    Aug 27, 2015
    1,644
    2,342
    Canada Eh
    In my experience... If the amp is making noise of any sort and not completely dead sound wise.... Is usually tubes. Ymmv.
  12. Lance Chambers
    Jun 23, 2019
    1,408
    2,143
    Yes! :agreed:
    If you are the original owner, purchased from an authorized Marshall dealer and register it within 90 days of purchase. :erk:
  13. Michael Jacob
    Jul 13, 2019
    15
    32
    Thank you very much. I knew that 2 tubes are in parallel but didn't think of doing that. Yes it has some kinda of warranty but it's 50 bucks to ship it one way.
  14. Michael Jacob
    Jul 13, 2019
    15
    32
    Probably gonna buy 4 new matching power tubes. What brand do you recommend?
  15. Bull Rock
    Aug 27, 2015
    1,644
    2,342
    Canada Eh
    Tubes are like girls n cars. Everyone likes something different. JJs are marshall standards for a reason. But there are many other good brands. Someone with your amp will chime in for sure. I like JJ, tads, and believe it or not EHX. Any new tubes will be great.
    Michael Jacob likes this.
  16. Bull Rock
    Aug 27, 2015
    1,644
    2,342
    Canada Eh
    Ps, welcome to the fold MFer
    :cheers:
  17. pedecamp
    14,481
    11,383
    If you like the way your amp sounds get the same tubes. If you can figure out which is the bad tube youll have 3 spares the same brand. :yesway:
    Bull Rock and Michael Jacob like this.
  18. Michael Jacob
    Jul 13, 2019
    15
    32
    I can get a matching set of JJ's off Amazon for 76 bucks, probably gonna do that. Thanks for the welcome. I'm about to retire but have to go back on one more boilermaker job to make sure I'll have enough money. To date I've built 10 guitar kits and 7 of them are really good. My passion in life was to play a guitar just like a ringin a bell. I'm in good shape and might have enough time left to make it happen. Like this website and gonna do my best to hang here more often.
  19. Michael Jacob
    Jul 13, 2019
    15
    32
    Thanks, I'll make sure and do that. In my 20's and 30's I was an electronics technican. Worked on Motorola 2-way radios, and worked on 1000's of tube radio's.
  20. Bull Rock
    Aug 27, 2015
    1,644
    2,342
    Canada Eh
    Nice! Glad to hear you're doing good. If you want to share pics or your creations... We'd all like that. Stay healthy my friend.
