2 x 16 ohm parallel speaker jacks
Discussion in 'Cabinets & Speakers' started by mtm105, Nov 20, 2019.
  1. mtm105
    mtm105 Well-Known Member
    Feb 11, 2014
    3,929
    3,715
    NW NJ Exit 25
    I hook two separate Amps running at 16 Ohms.
    Or two separate Amps at 8 Ohms?
    Am I able to run just one Amp, while other is still plugging in and off? Can I play two Amps simultaneously at 16 Ohms?
    These Eminence speakers I believe are G12-75 clones. Bang for the buck, best little Cab going IMO.
    No matter how hard I try to escape Crate, it morphs and keeps hanging around...
  2. mtm105
    Feb 11, 2014
    3,929
    3,715
    NW NJ Exit 25
    Nevermind...
    1 Amp into Cab at 8 Ohms sent into equal Cab.
    NOT two Amps simultaneously.
  3. Jethro Rocker
    7,329
    7,599
    Because they are parallel inputs. If it was "stereo" and had a separate input for each of 2 speakers, you could.
  4. ampmadscientist
    14,778
    8,605
    No you cannot plug 2 amps to the same speaker.
    (unless) as Jethro pointed out:
    a stereo speaker which has 2 separate isolated inputs:
    to drive 2 separated discreet sets of speakers.
    (the 2 separate sets of discrete speakers might be in one single cabinet)
    Dogs of Doom likes this.
